Question about Akai LCT2785TA 27 in. LCD Television
Akai LCT2785TA 27 in.LCD tv
My tv will not come on,have to attempt 20-30 times to get it to come on. At times it will turnoff on its own.
  • Akai Master
  • 5,568 Answers
If it's failing to turn on reliably, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core (no laminations as with a line-frequency part) transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself but it will likely have the same problem eventually unless they have altered the design.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Posted on Nov 26, 2008
We have had our 27 Inch Akai LCT2785TA for almost 2 years, just today we cannont get it to turn on the red light will just flash when we try to turn it on. Can you give me an explanation and a fix for this...
We have had our 27 Inch Akai LCT2785TA for almost 2 years, just today we cannont get it to turn on the red light will just flash when we try to turn it on. Can you give me an explanation and a fix for this problem
Sep 08, 2009 | Akai LCT2785TA 27 in. LCD Television
AKAI 27 Model #LCT2785TA
The message you are seeing means that the tv is not receiving a signal from the source. Try hooking up a different source such as a DVD player or a Cable Box to that same input on the tv. If you have picture and sound then the problem is with the original source. If that does not work then you have a bad Main bd.
Jul 10, 2009 | Televison & Video
Akai troubleshooting
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}Hi
You have power supply problem. Please go to ebay and buy cheaper price:
AKAI LCT2785TA POWER SUPPLY BOARD MLT186
Thanks
GEORGE
Mar 15, 2009 | Akai LCT2715 27 in. LCD Television
Akai LCT2785TA troubleshooting
Open the back of the TV,and look at the can shaped items called capacitors on the circuit boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Mar 15, 2009 | Akai LCT2785TA 27 in. LCD Television
Akai LCT2785TA Capacitors blown out
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Nov 25, 2008 | Akai LCT2785TA 27 in. LCD Television
Akai LCT2785TA has a black bar in the middle of the sceen.
Nine did this also. If you change the Closed Caption settings it goes away. Know not why.
Aug 28, 2008 | Akai LCT2785TA 27 in. LCD Television
Akai 27 lcd remote control
it would seem the akai remote codes you have are not programed in the remote you should wright to akai and tell them 1000s of people you have chatted to have the same problem is there any way you could send me a replacement please or could you give me the codes and i will program them my self thank you hope you get this email or letter or phone call what have you to lose.
Oct 29, 2007 | Akai LCT2785TA 27 in. LCD Television
Akai LCT2785TA 27 in. LCD Television Logo
181 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
