Question about Video Game Consoles & Games
Mag turbo force part number GC-FBW7
I bought the above item second hand and it did not come with the power supply. I need to know the input voltage.
  • Anonymous Nov 09, 2008
    i have a aitek R440 rumble wheel but don;'t have power supply. what volt does it take?
I have one of these - just about to sell it on ebay. The power supply output is 20V D.C 750mA 15VA. centre of the pin is + and outer is -.
Hope this helps
Posted on Nov 30, 2008
Need a replacement power supply for a Evernote scanner
Sorry Gregory, gave you the wrong number.
You could try something like this. Various voltages and currents with different adapter plugs. This is on Ebay UK but I would think there are others, don't know where you are.
Ebay item number: 201154296095
Specs:
1.Rated Input Voltage: AC 110V or AC240V
2.Vibration Input Voltage Range: AC95V-265V
3.Input Rated Current: 0.4-0.6AMP
4.Input Power: 90W
5.Efficiency: >88%(TYP)
6.Out Power: 90W
7.Output voltage: 15V/16V/18V/19V/20V/22V/24V(0/+0.5V NOLOAD): DC15V-24V
8.Output voltage: 15V/16V/18V/19V/20V/22V/24V(-0.4/0.5V@rating load): DC15V-24V
9.Output current: 15-20V/4.5A@22V-24V/4.0A: 4.5AMP(max)
10.Overload protection: YES
11.Short Circuit Protection: YES
Dec 17, 2014 | Office Equipment & Supplies
Have a brookstone thera spa CORDLESS massager older model, precurser to the turbo massager ... the charging unit that came with the corless massager is missing (lost) can i purchase a replacement
I have a similar Brookstone model, cordless with heat and cold options. I gave up finding the cord and purchased a dual model charger from Amazon that allows me to chose the voltage of the charge to the item. It appears to be working find now. I did have to play with the input voltage until I found the correct amount in spite of what the charger said. The unit I bought is a Hosa Technology power charger. Number ACD-377. Hope this helps you too.
Jan 02, 2011 | Brookstone Theraspa Turbo Massager
What voltage power supply do need for the momo force feedback wheel i go one second hand and it was missing the power supply please could help?
Hi, Here all the specs of the Power adapter you looking for. Thanks and have a nice day ! J -
- Adapter model: ADP-18LB C
- Adapter Input: 200-240 V / 50-60 Hz ~ 400 mA
-Adapter output: 24.0 V - 0.75 A Output Plug - Outside Diameter (mm): 5.50
- Output Plug - Inside Diameter (mm) : 2.10
-Output Plug - Barrel Lenght (mm) : 12.00
- Output Plug - Polarity : Center positive.
thanks and have a nice day J -
Mar 30, 2010 | Logitech Momo Force Racing Wheel PC
Any updates for avb mag turbo force racing wheel for rfactor cars all over the place not good for this game help
got new logitech wheel avb had no driver updates for 6 years or for sims racing games thanks for your help bobby metler got avb wheel for sale 20.00 works great on anlog and older games thanks again!
Jan 06, 2010 | American Anko AVB Force Feedback USB...
No Power Supplies
It is a 17 VDC 900mAmp power supply.
The positive is center pin (negative to shield surrounding center pin).
I have the same wheel.
Apr 04, 2009 | American Anko AVB Force Feedback USB...
Power supply for logitech driving force steering wheel
It's OK to use a power supply with a bigger current capacity than needed. If you find once with, say, 24V and 1.0A then that's usable - the wheel will draw as much as it needs.
Therefore:
Same voltage (24V)
Same or greater current (=>0.75A)
Same polarity (positive centre) __________________
Same as the Momo Racing Black, positive inside, negative outside.
The G25 power supply output is stronger: 24Vdc, 1.75A, same polarity.
As long as output voltage, polarity, amperes and connectors are the same you should be fine using a compatible unit, if you find one. In your case it would be 24V, 0.75A, positive inside, but if I were in you I'd wait for some American Driving Force owner to confirm this to be completely sure. The American psu model should however be GAD-SLU-240A8, 110V input, same PSU as Driving Force Pro. Take a look at this for more info. I received this from a forum with people that had the same issues as you and I hope this helps. It seems like they're saying that a store bought universal power supply may mess up your wheel so be careful. If this helps, please leave feed back. FIXYA!
Feb 14, 2009 | Logitech DRIVING FORCE FEEDBACK STEERING...
MAG INNOVISION
The socket for the AC power supply is located RIGHT ON the cord that plugs into your tower/graphics card. I just bought one today at the thrift store, ** power cord, but was looking for the input myself and found it there. Hope that helps.
Feb 18, 2008 | Mag Innovision InnoVision LT 765S 17" Flat...
MAG 786PF - Does its resolution good for Digial camera?
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 17, 2008 | Mag Innovision InnoVision 786 PF 17" CRT...
Problem in Vista
if ya find out let me no as mine don't work ether
Oct 01, 2007 | American Anko AVB Force Feedback MagTurbo...
CE 21895GE3-A
If you did not get a DC power supply with the phone then it is either an optional item or it does not have the option. Does it have a DC power input jack? If it does, most (but not all) will be labeled with the polarity and voltage. If it is labeled, you could bring your phone to Radio Shack and get help picking out the right power supply.
Jul 24, 2007 | GE 29490GE2 Corded Phone
Video Game Consoles & Games Logo
540 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
