Question about Olympus Stylus 710 Digital Camera
No flash pictures
My camera can't take pictures when the flash is enabled. The flash does not go off and it does not even take the picture. It can take perfect pictures when the flash is disabled though. I'm not sure what exactly is wrong with it. I did drop it (about 3-4) though so that is probably the cause of the problem. I was just wondering if it is possibly just the light bulb that is broken or if it is something different that I need to get fixed. Thank you very much kevin
  • joeyt1983 Nov 11, 2007
    Mine does the same exact thing, and I didn't drop it. I was using it all night, but then I went to turn it on and take a picture and nothing. Does this mean I'm out $350???
  • mcgunny Dec 07, 2007
    Camera works great without the flash; but whenever the flash is activated it the charging light just keeps on flashing and the camera will not take pictures. I have to switch to no flash for it to work. I have not drop it or damaged in any way. One day it just decided to stop working!! Any ideas/solutions!!! it might be more expensive to fix than to get a new one... but I'll make sure it wont be the same brand, this camera is only about a year old!!!
  • 188 Answers
By dropping you can damage the charging circuit of the flash unit. flash tube is the later part. it seems that the charging circuit of the camera is not working thus it hangs the camera when flash is switched on.
Posted on Oct 11, 2006
We have olympus camera of model no. 1010. The problem with this camera is that whenever we take any picture we dont' get flash, even if the flashlights are on. Kindly give solution.
If you are sure that the flash is enabled (not automatic, enabled!), then I'd say it must be a hardware issue regarding the flash circuitry. I would contact Olympus support if the camera is not too old. Or take it to a camera repair shop, the repair shouldn't be expensive.
May 18, 2011 | Olympus Stylus 1010 Digital Camera
HI i HAVE A SONY DSC W55 camera. My Flash light on the camera is not working. When I click a picture with flashlight ON, a yellow light just on top right side of the display turns on steady. Once the...
If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances: When shooting MPEG movies When shooting in the Twilight or Handheld Twilight mode If shooting with the Burst or Multi Burst mode If an external flash is connected. Please make sure that the Camera is not set to any of these modes. You can check the manual to get the information to change the setting..
If the issue persists, please reset the Camera and make sure that battery is fully charged. If the issue persists after performing all the above mentioned troubleshooting steps, service is required. If you feel that the above Troubleshooting steps, helped you. please rate my answer positively. Thanks for understanding.
Jan 16, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
I have a cannon powershot a720is and will not take pictures in low light conditions, when i press the button to take picture the orange light comes on, but it does not take picture. When in a bright light...
This sounds like a flash issue.
From page 64 of the user manual, make sure that you have the flash enabled on the camera. Page 64 shows you how to enable and disable the flash. Most likely, the flash was turned-off by mistake and is causing your issue.
If the flash is enabled and you're still having a problem, then there's a good chance that the flash feature has failed on your camera and will need to be repaired.
Dec 29, 2010 | Canon PowerShot A720 IS Digital Camera
I bought a Sony DSC t700 approximately 6 months
If the built-in flash does not function, then the camera may be set to Auto and will only flash when taking pictures in poorly illuminated environments.
To set the camera to the Forced flash setting so it will flash regardless of the surrounding brightness, press the UP ARROW on the control button until a lightning bolt icon appears on the LCD screen.
When set to the Twilight mode
If in the Burst or Multi Burst mode
Please touch the MENU option on the screen of the Camera.
Then, select the REC MODE under the MENU.
Then, select NORMAL under the REC MODE.
If you're not able to select the NORMAL under the REC MODE, try Initializing the Camera.
First, please touch the HOME on the LCD screen of the Camera.
Then, select the SETTINGS in the HOME menu.
Then, select the MAIN SETTINGS under the SETTINGS.
Then, select the Initialize under the MAIN SETTINGS.
If the issue still persists after performing the troubleshooting steps provided above service of the Camera is required.
It's required to physically examine the Camera to determine the exact issue at the service center.
Jun 16, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Night pictures do not come out
To take night photo's you need to use a tripod. this will enable you to take long exposures without the blur. If you use flash it will only illuminate objects near the camera.
Nov 16, 2008 | Nikon D50 Digital Camera
Flash not working
"Forced on" means the flash is forced. Try "Forced OFF". Note that there are several options and scenes when the flash is enabled by default.
Oct 23, 2008 | Panasonic Lumix DMC-LZ7 Digital Camera
How are images stored in the camera?
images are stored in either internal flash memory or optional removable, reusable CompactFlash cards. Providing both internal and removable storage offers users maximum storage flexibility. Internal camera memory ensures that the camera is always ready to capture pictures, even if the optional memory cards have been misplaced, lost or damaged. Optional storage cards enable users to expand storage capacity according to their usage needs. Since the pictures are stored in flash memory chips, pictures can be retained for up to one year without power.
Sep 13, 2005 | Epson PhotoPC 700 Digital Camera
Sep 13, 2005 | Epson PhotoPC 600 Digital Camera
The best situation to use each of the shooting modes
The shooting modes are described as follows: AUTO (Factory default setting) Auto mode is used for regular photography. The camera automatically makes the settings for natural color balance. Other functions, such as the flash mode and metering, can be adjusted manually. Portrait Portrait mode is suitable for taking a portrait-style picture of a person. The camera automatically sets the optimal shooting conditions. Night scene Night scene mode is suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting conditions. If you use the flash, you can take pictures of both your subject and the night background. SCENE Scene mode enables you to select one of the following scene shooting modes available in the menu. Landscape + Scene shooting Landscape + Scene shooting is suitable for taking pictures of landscapes and other outdoor scenes. This mode produces clear, sharp pictures with excellent detail, making it ideal for shooting natural scenery. Landscape + Portrait shooting Landscape + Portrait shooting is suitable for taking photos of both your subject and the background. The picture is taken with the background as well as the subject in the foreground in focus. The camera automatically sets the optimal shooting settings QuickTime Movie Quicktime Movie mode lets you record movies. The focus and zoom are locked. If the distance to the subject changes, the focus may be compromised. Landscape Landscape mode is suitable for taking pictures of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting conditions. Self-portrait Self-portrait mode enables you to take a picture of yourself while holding the camera. Point the lens towards yourself, and the focus will be locked on you. The camera automatically sets the optimal shooting conditions. The zoom is fixed in the wide position and cannot be changed. My Mode Enables you to make settings manually and register them in the mode dial's mode so you can call up your own shooting mode whenever you want. Program shooting (P) Program shooting allows you to shoot using an aperture and shutter speed that the camera sets. You can set the flash, white balance, or other functions manually. Aperture priority shooting (A) Aperture priority shooting allows you to set the aperture manually. The camera sets the shutter speed automatically. By decreasing the aperture value (F-number), the camera will focus within a smaller range, producing a picture with a blurred background. Increasing the value will let the camera focus over a wider range in the forward and backward directions, resulting in a picture in which
Sep 04, 2005 | Olympus Camedia C-60 Zoom Digital Camera
Best situation to use each of the shooting modes
Program Auto (Factory default setting) Program Auto mode is used for regular photography. The camera automatically makes the settings for natural color balance. Other functions, such as the flash mode and metering, can be adjusted manually. Portrait Portrait mode is suitable for taking a portrait-style picture of a person. The camera automatically sets the optimal shooting conditions. Landscape + Portrait Landscape + Portrait mode is suitable for taking photos which include both your subject and the landscape. The camera automatically sets the optimal shooting conditions. Landscape Landscape mode is suitable for taking pictures of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting conditions. Night scene Night scene mode is suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting conditions. If you use the flash, you can take pictures of both your subject and the night background. Indoor Indoor mode enables you to take pictures while indoors by allowing the flash to reach farther away. Beach & Snow Beach & Snow mode enables you to take pictures of scenery containing white sand or snow. Cuisine Cuisine mode enables you to take pictures of food by increasing the saturation, sharpness and contrast settings to take sharp, vivid pictures of the subject. Self-portrait Self-portrait mode enables you to take a picture of yourself while holding the camera. Point the lens towards yourself, and the focus will be locked on you. The camera automatically sets the optimal shooting conditions. The zoom is fixed in the wide position and cannot be changed. QuickTime Movie QuickTime Movie mode lets you record movies with sound. The focus and zoom are locked. If the distance to the subject changes, the focus may be compromised.
Sep 01, 2005 | Olympus Stylus 410 / ? 410 Digital Camera
Olympus Stylus 710 Digital Camera Logo
134 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
