Question about Sony Xplod CD Player w/MP3 Playback CDX-GT50W
Troubleshooting in car cd player
I just hooked up this cd player in my car because the old one stopped working. i have subwoofers in the trunk and for some reason the subwoofers only work with the radio. when i put in a cd the lights on my amp shut off and the subs wont work. i have never seen something like this happen.
    New Friend:
  • 57 Answers
That is very strange but it could be that when you put the cd in the radio it maybe sending out a quick shot of amplified power I would try disconecting the subs put in a cd let it play a little then plug the subs in while the cd is playing and see if they work if this works you may to get a new radio or put in a switch to turn the subs off or some type of momentary circuit breaker I'm just trying to help I never saw anything like that before good luck........
Posted on Jan 11, 2009
When you put fader to rear theres no sound its a sony 6stack cd player sony6000
Check to make sure your wires are hooked up right. A good way to check your wires is to pull the cd player out. unhook - and + to right rear speaker. Touch the - and + to corresponding ends of a AA battery. Have someone in the trunk to see if the speaker moves. If it doesn't, replace your wire going back or maybe a bad speaker. if it does move and you hook it back to the cd player right, and there is still no sound...it is the cd player. Best of luck to you!
Feb 05, 2011 | Car Audio & Video
Jvc kd-g340 rear speakers not working. I recently bought the car with this unit installed. I noticed that there is a l/r cable, power, ground in the trunk which means there was probably a subwoofer...
check the wires in the back of the stereo if not then make sure the back speakers are not hooked up to a internal amp and if it is make sure that it is not blown
Mar 31, 2010 | JVC KD-G340 Car CD/ MP3 Player
I BOUGHT A USED SUB YESTERDAY AND IT HAS POWER BUT NO AUDIO?
Let's establish that your feeding it a good signal first. How is it hooked up and to what?
A quick kand dirty test of it would be to jack in a CD player to its RCA input. It will tell you if it's alive and functioning.
THEN we'll troubleshoot the signal source end.
Feb 26, 2010 | KLH ASW10-125C Subwoofer
My 93 Boneville CD Player does not work, the radio works fine but it will not play CD's, also how would i install a set of speakers (subwoofers)
the cd player is bad and you can hook up subs through a rca hook up that you can hook to your speaker wires in the trunk the adapter is like 20 bucks at radio shack or local sound installer or buy an after market cd player cause yours will never work again and run rca's off the back of the radio to your trunk
Jul 09, 2009 | 1993 Pontiac Bonneville
My subwoofers will make no sound now
Go through the multiple menus of your head unit, and make sure the subwoofer setting is set to "yes".
Do you have the owner's manual for the unit? What make/model is the head unit?
Mar 06, 2009 | Rockford Fosgate (P212D4) Car Subwoofer
I wanna hook an ..
Yes. Just run your RCA leads to the amp (after properly wiring it). You can use either the front of rear pre-out connections. If your amp has a built in crossover, Use the low-pass filter setting at around 60Hz.
A copy of the owner's manual can be found here if you need it:
http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/#_
Hope this helps!
Aug 31, 2008 | Kenwood KDC-2011S CD Player
I am hooked up a pioneer cd player in a 96 dodge ram and when i turn the cd player on and turn up the volume the speakers just kinda crackle
speakers are busted or can not handle that much power/bass to them... being as old as the truck is im sure the speakers are more than likely busted...
Aug 11, 2008 | Car Audio & Video
Clarion dxz665mp cd player
I think you connect the wrong remote wire to the subwoofer amp.
This cd player it has 2 blue remote wires,one is for PWR ANTENNA (BLUE ONLY),when you insert the cd,this wire cut out the pwr,so,is when your subwoofers stop working.
The other blue wire is the REMOTE (BLUE W/WHITE) Wire,this is the one you need to connect to the Amplifier.
Let me know if work
Thank you
Jul 27, 2008 | Clarion DXZ665MP CD Player
No sub when listening to a cd
you're using the wrong remote output wire. You have it hooked to the power ANTenna wire (blue) which turns off when not using the tuner. You need to use the REM OUT wire (blue w/ white stripe).
Oct 14, 2007 | Sony CDX-M630 CD Player
Subwoofers
low power needs adequate ground
Aug 17, 2007 | Jensen BP212 Car Subwoofer
Sony Xplod CD Player w/MP3 Playback CDX-GT50W Logo
285 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
