Question about Sunbeam Ultrasonic 81696 Humidifier
Sunbeam ultrasonic humidifier model 696-12
I have this humidifier and the rubber gasket on the bottom of the filling lid got broke,where can I find a new one?
Thanks for your help
  • 2 more comments
  • Anonymous Nov 24, 2008
    unable to locate a rubber gasket that will seal enough for h2o to mist. where can I buy or order none?
  • hebrown Jan 18, 2009
    Need gasket for filler lid on water tank.
  • peskenorske Feb 24, 2009
    need rubber o-ring gasket on the fill tank model # 696
  • Anonymous Mar 18, 2014
    my welbilt keeps going off can i get a new one and where this machines is about 33 years old
I want to order this rubber gasket
Posted on Feb 24, 2009
What is the power consumption or rating of the sunbeam ultrasonic humidifier?
I have not been able to find the energy consumption of this product but you should be able to follow the steps listed on this site to calculate the number of kilowatt hours that it is using.
How to Calculate Kilowatt Hours
Feb 16, 2014 | Sunbeam SUL496-UM Ultrasonic Humidifier
Sunbeam ultrasonic humidifier model 694
i have a sunbeam humidifier model 694 i want to know how do i use it
Feb 04, 2014 | Humidifiers
How do i fill the whale sunbeam humidifier?
The part at the bottom of the water tank that lets the water into the base unscrews and that is how you fill the tank. It had me stumped too.
Mar 24, 2012 | Sunbeam Ultrasonic Humidifier
Sunbeam Ultrasonic Humidifier SUL495 quit working in first week. What may have happened.
Same problem. It worked for about a week, then gradually stopped producing mist. No solution.
Nov 29, 2010 | Sunbeam Ultrasonic Humidifier
I need the rubber o-ring on the water fill cover for my Senbeam humidifier model 696 please help get this part. my phone # 320 269 9368
Please call the Venta Customer service team.
1-888-333-8218
If you have proof of purchase the part ( cap) is covered under warranty. If you do not it will cost $13
Feb 27, 2009 | Sunbeam Ultrasonic 81696 Humidifier
Sunbeam Ultrasonic Humidifier, model: 697-6
Located My Manual:
Hope this helps!
1. Remove tank from base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled, or tap water. Water temp should NEVER be too hot or too cold. Return tank to base and let sit for a few minutes. Be sure the filling cap of the tank is tightened firmly.
2. Plug power cord into a 110-120V AC wall outlet only. Turn power switch to "on" position. Power light will illuminate. Turn mist nozzle until desired level is being released. Aim nozzle away from furniture and walls.
3. Always turn humidifier off when water runs* out. Unit will continue to operate when tank is empty.
*Humidifier will run up to 12 hrs on low; 6 hrs on high.
DO NOT LET WATER SIT IN TANK FOR LONG. THIS CAN ENCOURAGE BACTERIAL GROWTH.
Place unit on level surface away from direct sunlight.
DO NOT ADD MEDICATION OF ANY TYPE INTO THE NOZZLE, BASE, OR WATER TANK.
ALWAYS LEAVE ROOM DOOR PARTLY OPEN. DO NOT MOVE, TILT, OR EMPTY WHILE OPERATING.
Mild bleach and water solution for cleaning, never detergent.
Clean every 3rd day during use. Clean after long storage
Humidity varies from room to room. Aim for 30 - 50% relative humidity. If windows/ walls fog or frost, reduce mist intensity. If room too humid, ventilate by opening door or window; adjust mist intensity.
Sep 22, 2008 | Sunbeam Ultrasonic Humidifier
Sunbeam ultrasonic cool mist humidifer model 700
The Problem is minerals in the water. Impeller and ultrasonic designs send these minerals into the air. If the water in your area contains a lot of minerals, you will notice them as dust. The EPA does not issue health warnings about minerals in the air, but does recommend using low-mineral water (such as distilled water) in your humidifier. Many ultrasonic models feature a demineralization cartridge that filters minerals out of the water to prevent the dust.
Good Luck.
Feb 17, 2008 | Sunbeam Ultrasonic Humidifier
Sunbeam Ultrasonic 81696 Humidifier Logo
959 people viewed this question
Top Sunbeam Humidifiers Experts
Oloyede Monsuru
Paul Sikkema
Paul Sikkema
Are you a Sunbeam Humidifier Expert? Answer questions, earn points and help others
