Question about Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher
The rince light stays on and it wont run, you cant get to any other cycle
Only used it twice, and the rince light stays on and if you push cancel, it will go off for a min, but then the rince light comes back on and you cant get to any other cycle on the dishwasher.
  • 1 more comment
  • tkstout1 Nov 06, 2008
    how do i get the key pad
    how do we get behind the key pad to check it, that is what it acts like, like it is stuck
    thank you very much
    Sergeant:
  • 409 Answers
sounds like you may have a stuck key on the keypad. disconnect the power and check the keys on the keypad as well as the pin connector behind the keypad that plugs into the board behind it for any dislogged or bent pins. replug all connections and plug the unit back into the wall. this should fix the problem. if the problem persists, replace the keypad. i know what you are thinking, new unit right?
Posted on Nov 06, 2008
Neff washing machine stops half way through the cycle and the high water level light comes on
possible hose blockage or filter blockage. when half way through the cycle the machine evacuates the water to replace for rince cycle or to start spin cycle if the way is blocked the water cant go out so the machine can not finish the cycle, and usually the door will stay locked so not to flood, when the water is still in the machine. remove and check the drainage hose for kinks and blockage. also remove and check the filter under the machine. (be careful as this will let out all the water so have some towels or bucket ready to catch the water. once the filter is clean replace and restart your machine.
I hope this was useful.
Feb 15, 2013 | Neff W4380X1 Front Load Washer
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
Quick rince light is flashing..but nothing work
To clear the indicators
Press CANCEL before starting the dishwasher to clear all options
and cycles.
Sep 16, 2009 | Kenmore 24 in. 16332 / 16334 / 16339...
How to reset alarm on heritage softail, bike wont
Set the alarm by holding the key fob button until you see running lights flash twice. Turn off the alarm by pushing the key fob button twice and the lights will flash once.
Aug 29, 2009 | 2000 Harley Davidson FLSTC Heritage...
The flashing light blinks 7 times on the clean indicator area , but the dishwasher will not function and when you press cancel it starts running but nothing washes through any cycle at all. please help
ok well usually it is not sensing a temperature change in the water or not getting hot enough. so you can reset the dishwasher and try running the hot water in the sink before starting the dishwasher. if it fails again there is a heating element and control board kit that would need to be installed. you can reset the dishwasher by pushing "high temp wash" and "heated dry" back and forth until all the lights light up then you can hit the cancel and drain button twice.. put detergent in and run it.
Mar 04, 2009 | KitchenAid Dishwashers
MAYTAG PREFORMA 2 SPEED 10 CYCLES 2004 TOP LOADER
Check your lid switch, some machines stay running when you add clothes when it agitates, but will shut off if you lift the lid in rinse and spin, lid switch may be broken.
Jul 15, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Powerpoint dishwasher TW26
cannot change the program low salt and low rince lights on but no lights on the cycle indicator lights.
May 02, 2008 | Dishwashers
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Wont start and says "SUD"
yes I can the suds is from too much soap it will go thru a flush cycle and should go away after 4 min of opert. let me know if it does not clear you may also get a LD code on the machine to clear press cancel twice
Feb 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher Logo
148 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
