Question about Denon AVR-2803 Receiver
DSP problem This unit only works in the Direct Mode or in the Stereo Mode if the Tone Defeat switch is activated. Additionally there is no output signal going to the subwoofer. Sound comes out of the front speakers only in these 2 modes only. Everything else is dead. This is the most complicated receiver and remote I have ever used and being an older person I have either really honked it up by pushing the wrong buttons,(it used to work),or the DSP electronics may have burnt up. I have tried about everything and the manual is no help and way over my head. If it is possible the DSP electronics are burnt up would it be cost effective to fix it or should I just buy a new unit? I hate to spend $100 to have someone look at it and only tell me that it will be a couple hundred more to fix it. Help, Thanks.......
    President:
  • 3,130 Answers
Are you sure you have the unit in surround mode? It should say on the display MS if it is. If it is in the surround mode and you still do not get any sound to the subwoofer, make sure the speakers wires are all connected up properly. If all that looks good, you could have an amp problem. It shouldnt cost 100 bucks for an estimate. Contact the manufacturer, a number is located in the owners manual. Ask them if they have a factory service depot close by or what they charge to estimate or repair. Hope this helps. PS dont forget to rate this.
Posted on Oct 11, 2006
How do i turn off the dsp and run stereo mode?
Pressing the PROCESS button opens up the various screens that determine the signal path setup and that control processing parameters for the DSP modules: I/O, PEQ, XOVER, DEQ, DELAY, and LIMIT.
I/O
The I/O module sets up the signal routing inside the DSP from input to output. Press and rotate the SELECT encoder knob to choose between dual mono, stereo, bi-amped, or bridged routing options.
STEREO
STEREO mode routes the signal from both the A and B inputs through a single series of DSP modules. The parallel DSP modules process the A and B signals with identical, linked settings (only module "A" parameter settings appear on subsequent DSP module screens).
The manual is available at: http://www.behringer.com/assets/NU6000DSP_NU3000DSP_NU1000DSP_M_EN.pdf
Jun 02, 2014 | Behringer Inuke Nu6000dsp 6000-watt Power...
Would I be able to connect Yamaha eq 70 equalizer to Yamaha av receiver RX-V1800 Thanks.
Be advised that the engagement of any device in a Tape Monitor loop on a late-model Audio/Video Receiver will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
The connections themselves are fairly simple but it pays to understand what happens in the loop.
In general, any Line-Level external processor (EQ, dynamic range expander, etc) will go into a Tape Monitor loop on a receiver. A Tape Monitor, when engaged, sends the stereo analog signal Out to the Processor, massages it and returns it to the receiver via the Tape Monitor IN connectors to be passed on to the receiver's internal processes (volume, tone, whatever).
Old school analog stereo-only receivers consistently work this way. Newer digital and audio/video receivers introduce a couple of problems: 1) digital sound processing to simulate a variety of soundfields; 2) multiple output channels, either discrete or digitally-generated.
The latter requires that whatever signal is being processed experiences a maximum of one analog-digital-analog conversion.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose some form of STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Monitor as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? The rest would NOT be processed. That logical problem also plays into the decision to defeat digital sources if the Tape Monitor is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
Apr 16, 2011 | Yamaha RX-V1800
How can i hook a eq to this reciever to play through all my components not just the tape or cd player?? I was told jumpers but i am not sure on this
I assume you have it connected traditionally in the Tape loop and understand how that works. ANY 2-channel analog source will work with the EQ engaged.
I'm guessing you have digital sources you want to process. Ain't gonna happen. See page 19 of the manual. Note at the bottom.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose a STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Monitor as the first analog step in the process and defeats any pure digital sources.
Mar 12, 2011 | Panasonic SA-HE9 Receiver
Hello: I just purchased a DBX 128 and have no idea how to connect it up. I would like to listen to my records as well as tape using the expansion mode. However, it seems like it only hooks up to my tape...
Part 1
Let's establish a couple of things first.
1) You already have the turntable part working.
2) Your receiver has a defeatable Tape Loop.
Mar 10, 2011 | Audio Players & Recorders
How to install
The following is some boilerplate I made up that should explain some usage limitations.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? They would NOT be processed. That logical problem also plays into the decision to defeat digital sources if the Tape Monitor is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
Okay, back to the hook-up:
Receiver Tape Out (Rec) - to the External Processor (EQ, whatever) Preamp-, Rec, Line-In;
Receiver Tape In (Play) - from the External Processor (EQ, whatever) Preamp-, Play , Line-Out.
So, to sum up, you can only use the EQ or any outboard processor for analog stereo sources. If you actually want to use an analog recording deck you could place it within the typical Equalizer
Feb 03, 2011 | Teac EQA-120 Home Equalizer
HOW DO I CONNECT A RECIEVER CD PLAYER AND A EQULIZER
Jan 24, 2011 | Spectrum Technical Hifi EQ-B5100...
How to set up eq70
This is generic advice that should help you.
Be advised that the engagement of any device in a Tape Monitor loop will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose a STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Mon as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? That logical problem also plays into the decision to defeat digital sources if the Tape Mon is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
Okay, back to the hook-up: Receiver Tape- or VCR Out to the External Processor (EQ, whatever) Preamp-, Amp-, Tape- or Rec-In; Receiver Tape- or VCR In from the External Processor (EQ, whatever) Preamp-, Amp-, Tape- or Rec-Out.
If you actually want to use an analog recording deck you could place it within the typical Equalizer's own Tape Monitor loop(s). Many have two to facilitate equalized dubbing between decks.
Aug 04, 2010 | Yamaha EQ-70 Home Equalizer
How to connect all wires to a teac eqa 20
Generic advice that should help:
Aug 03, 2010 | Teac Audio Players & Recorders
How to connect to reciever
Jul 21, 2010 | Technics SH-GE50 Home Equalizer
No, i was looking for free advice
Okay, back to the hook-up: Receiver Tape- or VCR Out to the External Processor (EQ, whatever) Preamp-, Amp-, Tape- or Rec-In jacks; Receiver Tape- or VCR In from the External Processor (EQ, whatever) Preamp-, Amp-, Tape- or Rec-Out jacks.
Mar 26, 2010 | JVC Audio Players & Recorders
Denon AVR-2803 Receiver Logo
182 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
