When i try to install my software it comes up with the error... " Error 25007.Error occured while initializing fusion. Setup could not load fusion with loudlibrary shim (). Error 0x80131702" disk is EOS DIGITAL solution disk ver 15.1.. my computer is running windows XP
  • debbielatta Nov 06, 2008
    ok... thanks for that... BUT... its the .NET framework 2.0 that wont install... even from the canon website.. or anywebsite for that matter :(.. it comes up with the error msg above.. anymore hints or tips?
  • 796 Answers
Is this for a digital camera??
you can download the newer version of the software from the canon site itself
Posted on Nov 06, 2008
""an internal error occurred in the initialization
Hi! Welcome to www.fixya.com.
You can go to this website and follow the instructions
http://support.microsoft.com/kb/929135
Thanks for contacting Fixya. Bye for now.
Jul 23, 2011 | Lenovo G460 Laptop Computer 06774CU Intel...
Screen says "Printer error."
Welcome to Fixya
If the error occurred when you were trying to use a feature of EASYSHARE Software:
  1. Run the Repair utility:
    1. Select Start > Settings > Control Panel > Add or Remove Programs.
    2. Click KODAK EASYSHARE Software.
    3. Click Change.
    4. Click Next.
    5. Select Repair, then follow the instructions.
  2. Try the feature again.
If the error occurred when you were installing or upgrading EASYSHARE Software:
  1. Uninstall your current version of EASYSHARE Software:
    3. Select Remove.
    4. Follow the instructions to remove the software.
  2. Go to the Clear Utility for KODAK EASYSHARE Software at www.kodak.com/go/clear, then follow the instructions to run the utility.
  3. After restarting your computer, go to KODAK EASYSHARE Software at www.kodak.com/go/easysharesw, and install the latest version of software, free of charge.
Thank you for using Fixya!
Mar 23, 2011 | Computers & Internet
I have a Plustek OpticFilm 7600i SE film scanner. Every time I try and load-up the setup disc, the set up install starts and then comes up with this error message: An error (-500 : 0x8004ace8) has...
It is quite possible that there is another piece of software that is clashing with your Plustek OpticFilm scanner. It is hard to tell which software is having a clash. If you remove that software from your system you will obtain the desired results. I suspect the SP3 of Windows XP may be responsible for this because Microsoft has indicated that Windows XP SP3 is not for everyone. If you install Windows XP SP2 uninstalling XP SP3 your problem can definitely be rectified.
Good Luck!
Mar 10, 2011 | Plustek OpticFilm 7200 Film Scanner
Received a error message "This software can only
This may sound stupid but make sure it is plugged in. Check the operating system and hardware requirements, if they don't meet the requirements, software will not recognize the device. Try different usb ports because sometimes computers have selective hearing and make sure your computer is initially recognizing the device when it is plugged in. If all else fails, don't try to install the software and head over to computer/my computer in the start menu. Right click and select properties. Click device manager in the hardware section or the bar to the left and look in the cd drive section. If you see your drive, right click and try any option about installing.
Mar 03, 2011 | LG Super Multi Blue Slim Portable Blu-Ray...
Loaded Start disc. When installing my language disc 1, I get an 9123 error code and a message " there was an error in the application". I cannot uninstall, because I get messages "...
Version 3/4: Error 9123 during Language CD installation
This error message relates to Version 3 and Version4. If you receive a 9123 error message during language installation, try one of the following resolutions:
  • Clean the disc with alcohol/windex/water and a soft cloth and try installing again.
  • Disable your internet security program, especially Norton or Symantec Security and try installing again.
If you are still experiencing this error, please contact Rosetta Stone Support
Dec 23, 2010 | Rosetta Stone Chinese Mandarin Level I &...
Error An error occurred while loading the COM file
uninstalled the program, downloaded the latest trial version from Sony (25 da trial) and recovered the files without errors. I will try to repair my own version later.
Thanks for your reply.
Dec 19, 2009 | Sony Vegas Pro 8 for PC (SVDVD8006)
Futura CE-200 Software fails to initialize on XP sp2
Maybe you should try to contact singer south africa and ask them whats wrong, my laptop did the excact same thing switch over to home pc and no problem ever again.
Mar 02, 2009 | Singer CE-200 Quantum Futura Computerized...
Using hp scanjet 3970 Just loaded hp scanning software and the large install of the 3970 drivers. When I enter the program the scanner opens and scans te image on the tray. (I am trying to scan a...
Have you checked the cord from the scanner lid to the scanner base. if that doesn't work I would try uninstalling the scanner and then reinstalling it. It sounds like a problem with the twain driver for the scanner.
Dec 20, 2008 | Computers & Internet
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
