Problem with Toshiba Satellite A25-S307 (PSA20U-07FX4V) PC Notebook
Won't refresh IP address?
I live on a university campus and my computer won't connect to the internet. I can use wireless where I get a signal, but when I try to use the wired local area connection, I receive an error message saying "limited or no connectivity." The morons in the tech support office told me that I need a new network card, which may be the case, but I have never had trouble connecting to the internet before. When I right click on the connection in "Network Connections" and select "repair" it tells me it is not able to refresh the IP address. Why does wireless work but not wired? Can anyone make any suggestions other than replacing the network card?
Posted by avatar on Oct 11, 2006
    • By avatarMajBob Dec 24, 2007
    • I have a laptop with wireless capability. The wireless capability will not connect to the internet but when I hook up using ethernet I can connect to the internet. How do I do a release and refresh of a laptop IP address so it will pick up the routers IP address?
      Bob
Solutions (3)
Best Solution
Clicking repair normally sets incorrect ip addreses to your router requirements.
Firstly, dissable your wireless connection, as your pc will still be trying to connect to the router, then try connecting again, your router should automatically assign an IP address to your pc.
If that fails get into your routers settings (eg type in something similair to 192.168.x.x) x's being the numbers required for your router(see your manual); and have a look at the ip addresses that the router assigns to your pc's, probably on the 192.154.x.x region and write them down if neccassary.
Then open up your wired cards properties(control panel- network connections- local area connection icon) and click on 'internet protocol tcp/ip', then properties and then click use the following IP address and type in the same numbers as your router range except for the last figure as this must not be same.
You must also make sure the Subnet Mask numbers are the same as this is the route your connection follows to the router.
Sorry it's a bit long winded but theres no shorter way round it.
i suggest you get a large can of baked beans and fill it up with cheese nugget
then run around the house shouting ''jabbawocky'' before blowing thrice on your monitor.
Buy a Mac
  • By Author imageGuest Jun 10, 2008
Add Your Solution
