Question about Whirlpool Dryers
Dryer, model #LE6900XKNO, purchased 1983. Drum is not turning. Motor/heat comes on. I assume this is a belt? I have not taken apart.
Jimster
  • 240 Answers
SOURCE: Kenmore series 90 dryer
I hae to say it, but it sounds like the motor has already gone out. That loud humming noise is usually the start windings going out. There is no other way easily to tell if the motor is out, but taking the belt off and saying it doesnt look broke what work in this situation. I would imagine that you have a DOTT (Dryer Of Tommorrow, Today) dryer, because you said it had the front panel. The motor part number is 279787 if this the case. Good Luck, and let me know if you find out any new information or need further help.
Posted on Feb 13, 2008
ginko
  • 19396 Answers
SOURCE: Maytag dryer model # PVE
usually , after you remove the back panel you can see the belt yourself, running from the motor to the basket gear.
Posted on Jul 22, 2008
  • 417 Answers
SOURCE: Zanussi Tumble dryer belt replacement
Yes, that sounds about right.
Posted on Oct 11, 2008
  • 163 Answers
SOURCE: GE Profile Harmony Dryer DPGT750EC Drum won't turn & no heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
TheMobilian
  • 8220 Answers
SOURCE: kenmore dryer- remove fan to change motor on
The wheel has left handed threads. Use an impact wrench and an adjustable wrench to get it off or get a vice grips or pipe wrncha nd lock down the shaft then get a stick of wood or a hammer handle and shove it in between two fins at the 3 oclock position. Slam downwards on the wheel and it should pop loose.
Posted on Mar 22, 2009
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Heat ok but no rotation, if belt broken where it located for kenmore 80 siries
If the dryer is still heating, but the drum does no turn, this is commonly attributed to either a broken drive belt or seized drive motor. Please post back with your complete MODEL NUMBER (located on a nameplate around the door opening), so I can determine how your dryer is configured. All dryers are not assembled the same and will come apart for maintenance depending upon the features provided.
Apr 22, 2011 | Dryers
Drum squeaks, squeals, have taken it apart. belt still has print and is not worn.unbelievably loud. how to get rid of noise?
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
Once you have taken the dryer apart and you will now remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in.
This should solve your noise problem.
For this FREE answer, Please rate me
Oct 02, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
My kenmore gas dryer drum doesn't turn
Can you hear the motor running? If so, the drum drive belt has come apart (from the heat) and is lying loose. You will need to release the drum in order to get a new belt over it, then coupled and tensioned at the motor pulley.
Aug 25, 2009 | Dryers
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor  and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor  and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here  + new25.gifExpanded repair helps for a common "Even Heat" dryer
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Drum won't turn
is the motor driving the belt when on? If the belt is OK and properly routed thru the pulley system, then the motor needs to turn on to move the drum..Your best bet is to provide a brand and model on your next entry so I can assist you on your specific dryer..
Good Luck
Rick
Jan 07, 2009 | Dryers
Dryer drum won't spin
remove rear panel remove screws in blower housing ck for objects in blower ..if you still have dryer apart remove belt from motor pulley and try turning by hand
Nov 15, 2008 | Estate TEDS840JQ Electric Dryer
Kenmore Dryer: Drum will rotate, but only manually
Best way to confirm if it's a belt/pulley problem is to remove one of the access panels on the back of the dryer. For many models, it's on the bottom, right hand side. Open it and look inside. You also use that access panel to put a new belt on since it can be difficult to do from the front, having to reach past the drum. But if everything is intact, then you should be able to "rethread" the belt around the idler pulley and onto the motor pulley.
Here's a common diagram:
If the belt is OK, but came off the pulley, then most likely, your idler pulley has too much play in it or the spring has lost tension and isn't holding it securely. I'd put the belt back on. If it comes off again, then look into replacing the idler pulley and/or spring.
Oct 20, 2008 | Kenmore 62602 Electric Dryer
GE Electric Dryer Older model
it could be the motor capacitor. to check, turn on and carefully give the drum a push in the direction of rotation. if the drum picks up speed and goea ok, then the motor capacitor is faulty. cheap part
Jun 26, 2008 | Dryers
Roper dryer not working
If the drum will not rotate, look for a broken belt or even possibly a faulty motor. If it is a belt, it should be relatively cheap to repair and possibly easy for you to aquire the specs on the breakdown of the dryer to access the belt for installation. If the belt isn't broken, then the motor is possibly shot and I am unsure of how much ROPER parts are. Be model number and serial number SPECIFIC when ordering parts, and don't go with the "SUGGESTED MATCH" just to save money if you can avoid it, they aren't always compatible.
Mar 14, 2008 | Roper RES7646KQ Electric Dryer
Dryers Logo
100 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
