Mold around the rubber seal in the front loader. how to get rid of
  • allopiz Apr 13, 2009
    I also have persistent mold around the door seal. After a load, I leave the door open to dry.
    President:
  • Washing Mach... Master
  • 2,651 Answers
Aliitle amount of vbleach on a damp warm rag shoudl remove the "mold", cut back on the amount of fabric softener and make sur eyour using an HE detergent ( A MUST FOR FRONT LOADERS)). keep the door ajar between loads will also lessen the build up
Posted on Nov 06, 2008
Smell of mildew in washer
They make products to eliminate this mildew, check at the store.
Aug 30, 2017 | Washing Machines
Tip
Getting Rid of Front Loader Mildew and Odor
This advice is for preventing or getting rid off that awful mildew smell associated with front loader style washing machines.
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
USE HE DETERGENT ONLY. Using regular detergent, or improper amounts of detergent can contribute to the build up of soap scum in which dirt can collect. Regular detergent is formulated to be used in a conventional wash tub with capacity of about 35 gallons. A high efficiency front loader only uses 5 to 7 gallons of water. So, if you use regular detergent in a front loader, you are, in affect, using about 5 times the concentration of detergent needed. This can cause oversudsing, premature wear on the pump motor and parts, premature wear on rubber seals, odor from sticky soap residue and skin irritations caused by soap residue left in clothing. Using improper detergent will also void the manufacturer's warranty. Make sure you READ all detergent labels some HE detergent is double (2X) and triple (3X) concentrated.
I hope this information is found to be helpful.
on Dec 09, 2009 | Washing Machines
Tip
Front Loader Mildew & Odor
on Apr 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Mold in bosch nexxt 100 series- how to get rid of it?
yes bleach and a very hot wash. but remember mold grows in damp /wet so always leave door and soap draw open when machine is not in use this will dry out parts and cut down on mold growth ,
Sep 09, 2016 | Bosch Washing Machines
There is mold around the rubber and in the inside of the rubber on my Front Load. How can I get rid of this? Is there a product to clean front load washers?
Hi.
The mold is an enzime from the washing detergent or softener. It attacks certain rubbers and causes them to turn black. Eventually it will cause a musty smell which will go on the clothes.
The only way to remove is by replacing the door seal.
If you try bleach etc then it will cause the mold to get worse.
Hope this helps
Aardvark Repairs
Nov 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Terrible odor from rubber seal around door. Don't know how to remove seal
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Oct 14, 2009 | GE WSXH208A Front Load Washer
Water sitting and mold growing in the rubber gasket ring around the opening for the door
affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Oct 09, 2009 | LG WM-2277HW Front Load Washer
My LG front loader washing machine has a black scum all over the rubber seal and it gets on my clothes and WILL NOT come out once it is on the clothes. I have tried bleach to get the stain off my clothes...
this is mold due to the amount of moisture built up during your wash cycle clean the scum using bleach but do not shut your door after you wash so the seal has an opportunity to dry
Aug 31, 2009 | LG WM-2277HW Front Load Washer
I have mold on the rubber door seal
This is a comon problem In areas where miosture is high and the tempiture is warm. Try using bleach to clen it off with or you can use super clean to remove it from the rubber. Not touchingthe seal with your hands and clothes will help some to.
Rubber Seal Holds Mold!
This is a problem that seems to show up on almost every front-loading washer due to the design of the rubber boot that attaches to the front of the machine. It is extremely important to wipe down the rubber after usage but even this doesn't always help. There are a couple of products out there that claim to get rid of the mold and smell, something called Purewasher that you could look up on www.smellywasher.com and also something that whirlpool sells for this purpose.
Mar 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
543 people viewed this question
Top Washing Machines Experts
