Yamaha RX-V470 LEDs/Lights all out
All of the lights, indicators, etc. have gone out on our receiver. It is now impossible to know which settings or programs I am on (borrowed the description from an identical problem on another forum). Otherwise, the receiver operates fine. Is there a common item that would cause all of the lights to stop working at the same time?
  • bernball Nov 07, 2008
    Thank you for your reply solutiondoct.  I checked the receiver and manual for the dimmer, but no luck.
    Do you have an idea what part the A/V guy would order to fix this?
  • drissoun Dec 28, 2008
    I have got exactelly the same problem, all LED were off whereas all function works fine.
    Thank you for your help and answers.
    Merry Chrismas and happy new year.
  • 93 Answers
Sometimes,you might press a "film mode" or "Dim"or "dimmer which will turn OFF the front panel display.Check that first from your manual.
It happened a lot!
If that is not the case,then you need A/V repair guy to order the part to fix it for you.
Posted on Nov 06, 2008
Remote control not working right out of box. Lights on remote work so I know it is putting out a signal. Is there some sort of initial set up or should this be working right out of the box?
If it is brand new look at the owners manual and if that doesn't help call Yamaha for help with repairing and /or replacing your remote or receiver.
Dec 11, 2013 | Yamaha RX-V673
Yamaha rx v470
Can you hear sound via the headphone socket? If you cannot then the main amp has failed. If you can hear the sound, then the headphone socket could be faulty.
May 28, 2013 | Audio Players & Recorders
Gigaware remote for ps3 cant connect
I can not locate a Remote For PS3 By Gigaware now if its a controller Follow these steps
Connect to PS3
1. Turn on your console and plug the receiver into the first port on the console. The RX indicator on the receiver flashes.
2. Slide POWER ON/OFF to ON to turn on the controller. The controller’s POWER indicator lights and the 4 port indicators flash.
3. The controller connects with the receiver automatically after about 3 seconds. If successful, the RX indicator on the receiver lights.
4. Press the PS button to assign a controller number. The corresponding port indicator lights.
Manual Search
If you are unable to automatically connect, try manual adjustment.
1. Repeat steps 1 and 2 under “Connect to PS3.”
2. Press CONNECT on the receiver. The RX indicator flashes.
3. Press and hold SELECT and L3 (left analog stick) on the controller simultaneously for at least 3 seconds. When the RX indicator stays lit, release SELECT and L3.
n Notes:
• Repeat “Connect to PS3“ or “Manual Search“ if the connection fails again.
• If you purchase a new receiver for the controller, but have previously been using it with the supplied receiver, you will have to follow connection steps again.
Reassigning a controller number
1. Press and hold the PS button for one second. The functional screen displays. Select “Controller Settings”, then “Reassign the controller.” Press X to confirm.
2. Use the D-pad to select the number that matches the controller’s port.
3. Press X again to confirm. The corresponding port indicator lights up.
Connect to PC
1. Plug the recevier into a PC’s USB port. The receiver’s RX indicator flashes.
2. Slide POWER ON/OFF to ON to turn on the controller. If connection is successful, the RX indicator on the receiver lights and the 4 port indicators on the controller turn off.
Test the controller
1. Open the control panel on your PC, and double-click “Game Controllers.” Then click “Properties“ and the testing screen appears.
2. Press the buttons of the controller. After testing, press OK to exit. You are now ready to play games.
If the controller stops working at any time, or will not connect to PS3 or PC, follow “Manual Search“ steps on pages 5-6.
Dec 14, 2009 | Video Game Consoles & Games
My Yamaha RX-V470 Kicks off after a couple of SEC.
Two possible problems , bad memory back up cap or weak voltage regulator.
Jul 10, 2009 | Yamaha RX-V995 Receiver
Display panel does not light; sound is ok
It may not need repair. if you have it hooked up to a TV, by video, s-video, or component. Press the menu button on the remote and you can see the main menu of the unit on the TV. Navigate the menu up/down/left/right/enter until you get to "display". You should be able to turn the display of the receiver on/off. If you don't have the manual. That's the PDF from Yamaha. I haven't used this particular unit, but that's the way it's done on all the other series. ie. RX-V or RX-Z. Hope this helps
Jun 02, 2009 | Yamaha RX-797 Receiver
The display light doesn't come on to indicate what the unit is doing (frequency, mode, etc.)
I assume that it plays, you just can't see the display. It may just need a new display bulb, that back lights the display.
Feb 22, 2009 | Yamaha RX-V730 Receiver
Yamaha RX-V470 Receiver Shuts Off
This unit is in the protection mode. See the link below. If you have further questions, please post them here.
Jan 01, 2008 | Audio Players & Recorders
Blank display
I replaced it with a 6V lamp. Radio Shack part# 272-1140. It cost $1.49.
Sep 26, 2007 | Yamaha RX-V870 Receiver
267 people viewed this question
