Question about Gold Medal 2131 Antique Gay 90s Pinto Pop Popcorn Maker
Popcorn won't pop
We can not get the popcorn to pop. Any idea what the problem may be?
Hints for getting the best popped corn: Don't pop popcorn in butter as the butter will burn before it can get hot enough. Popcorn pops best in temperatures of 400-460 degrees F. If your oil starts to smoke which happens at 500 degrees F, you've got it too hot. Any oil will work. Use enough oil to cover the bottom of the pan. For your health, you should choose a light cooking oil or better yet, skip the oil all together and use an air popper. The movie houses use yellow dyed coconut oil which does a great job of popping the popcorn although there are healthier oils you can use than coconut oil. To see if you have the oil hot enough, drop a couple of kernels into the hot oil. If it's hot enough, they should pop in just a few seconds. If you don't have a popper, any thick bottomed, high walled pan will do. Popcorn can even be easily made in a Dutch oven over a camp fire. When your oil is the right temperature, pour in your popcorn, shaking the pan to cover all the seeds in oil. Do this with the lid on to prevent burns should the hot oil try to splash out of the pan. Using a lid helps the kernels to heat more evenly and keeps the popping corn from flying all over the place. (If you are using a popcorn popper, shaking it isn't necessary because of it's rounded bottom.) As it begins popping, it's important to continue to shake a flat-bottomed pan. This helps any un-popped kernels to settle to the bottom of the pan where they can pop. As soon as you hear the popcorn stop popping, pull the pan off the heat and pour the popcorn into another container. It will burn if you leave it in the hot pan.
What can you do if you've done everything right but your popcorn still doesn't pop very well? As mentioned above, popcorn must have about 13.5 to 14% moisture to pop properly. This is because as the popcorn kernel is heated, the moisture inside the seed is turned to steam creating a huge inner pressure. As this pressure continues past the shell's strength to keep it in, the skin ruptures and the inner starchy layer of the kernel greatly expands and turns itself inside out. If the moisture isn't there, this pressure build-up can't happen. If you find your popcorn has excessive old maids (un-popped kernels) in it, the problem might be that it lacks moisture. Place 3 cups of un-popped popcorn into a quart bottle. Add a tablespoon of water, put the lid on and shake it to get water on all the kernels. If the water puddles in the bottom of the bottle, shake it again every 10 minutes until enough of the water has been absorbed to prevent puddling. Now let it sit for two or three days while the moisture is evenly distributed into the kernels. If it still doesn't pop correctly, repeat this process but add no more than 2 teaspoons of water the second time. Yes, it's also possible to get it so moist it won't pop, so definitely, don't add water a third time. Lastly, you can even take your old maids that didn't pop, rejuvenate them with water using the above process and re-pop them. (With a measurement of three cups un-popped popcorn, 1 tablespoon of water will increase the moisture content 2.5%. A teaspoon of water will increase the moisture level almost 1%. Air dried popcorn will probably never get below a 10% moisture content on it's own, so adding even two tablespoons of water would be pushing it, raising the moisture content to 15% - that is if it started out at a moisture level of 10%.)
Posted on Oct 03, 2010
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: instructions on how to use the Cuisinart easy pop popcorn maker
http://www.cuisinart.com/share/man/624_man.pdf
Posted on Jan 11, 2009
How do I fix the toggle switch on my popcorn machine?
Trust me, rather than trying to reassemble the original switch, it'd be easier to just replace the switch.
Replacements are out there....example:
http://www.radioshack.com/product/index.jsp?productId=2062525
Now you'd just have to figure out if the original is a SPST or a DPDT, or some other configuration.
Sep 23, 2013 | Kitchen Appliances - Others
Can't pop popcorn
Pls check if your popcorn pack sealed tightly and kindly inspect your equipment if the radiation is enough to heat up the popcorn. You may also restart the mircowave so that you would verify if the machine does work
Jul 01, 2012 | Kitchen Appliances - Others
Paragon Popcorn Popper Thrifty Pop 4 OZ Parts
I run a part-time hot dog stand in Nashville, TN. I've bought parts from Fine Entertaining . I'm better sure they sell popcorn popper. Paragon Popcorn Popper Thrifty Pop - the manual is under the resource section.
May 25, 2012 | Paragon Theater Pop 4 Popcorn Maker
Have a kitchenaid microwave KHMS2040WSS brand new. Is there a way to set the popcorn sensor for a smaller bag? Right now it is set for 3.5oz and burns all the popcorn.
I have never seen a microwave that doesn't burn popcorn if you use the "popcorn" button. Why the manufacturers keep putting them on I'll never understand. There's nothing you can do change the presets on an oven since they are built into the controller. Instead of relying on the oven, you should follw the directions on the bag. These tell you to use high power, stay by the oven and stop the cooking when the time between pops drops to 1 or 2 seconds. Stored heat will continue to pop kernels for a bit, and you won't cremate your popcorn. You'll also avoid the possibility of the bag catching fire and damaging the oven, which I have seen several times. Finally, don't expect 100% of the kernels to pop. There wil always be a few duds, and extending the cooking time just results in burned popcorn.
Jun 05, 2011 | KitchenAid KHMS2040W Microwave Oven
I have a daewoo countertop microwave/convection oven and I can't pop popcorn. It pops only half of the popcorn and burns what it pops. What's the deal?
Check the power setting it may be too high and are you useing microwave popcorn?you generally can not use standard popcorn in a microwave.The power setting required is on the bag of microwave popcorn
Dec 29, 2009 | Daewoo KOR-63D5 Convection/Microwave Oven
Need model number for Gold Medal popper
http://www.concessionpalace.com/concession-tutorials/P-60_60_Special_Uncle_Walts-1866_2085_2086_2656-popcorn-machines.pdf
Sep 01, 2009 | Gold Medal Kitchen Appliances - Others
Popcorn jamming in kettle
The only real solution is to put less kernels in kettle - it pops so fast that it jams up and burns. Adding a little more oil usually helps as well.
Dec 12, 2008 | Nostalgia Electrics CCP-509 Popcorn Maker
Popcorn
Cuisinart makes fresh, crunchy, homemade popcorn fast, easy¿.and healthy! The Cuisinart Popcorn Maker pops up to 10 cups of popcorn in under 5 minutes, and lets popcorn lovers decide just how much, and what kind, of popcorn, oil and flavoring to use. Popcorn pops right into a clear plastic bowl that flips to serve, and both bowl and poping plate go into the dishwasher.
Feb 18, 2008 | Kitchen Appliances - Others
Gold Medal 2131 Antique Gay 90s Pinto Pop Popcorn Maker Logo
2,944 people viewed this question
Top Gold Medal Kitchen Appliances - Others Experts
Oloyede Monsuru
Ted Maxwell
Coss
Are you a Gold Medal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
