ASUS A7N8X-E Deluxe Motherboard
Problem for ASUS A7N8X-E Deluxe Motherboard
No Power to PC
By Jreed on Oct 11, 2006
I went out of town and came back to realize that my PC isnt Powering up. I immediately replace the Power supply to discover that wasn't the problem, Next I replaced that motherboard with the exact same (ASUS A7nX8E Deluxe and that wasnt the problem, next I replaced the processor and its still not Powering On. Could the case be defective? Im lost I have 1gig ram, Athon XP processcor.
Comments:
Oct 11, 2006
- There is NO Power at All, Im not get a Fan, a Hardrive or anything sign of Power, the green light on the motherboard is lit, thats the only sign on Power
Oct 11, 2006
- Im think the case is faulty, Im going to take it in a let someone else look at it, I might try changing the case, I'll try the paper clip thing, I was told to try the screwdriver thing but that didnt work. Im dont want to short out my board so I will stop here..
Same Problem
Mar 01, 2009
-   same thing is happenin to me fs i cant get ma pc powering up but the light is on like lol doing my head rite in ppl -   mercer-08
Mar 10, 2008
-   when I turn my computer on it cut off a few minutes later or sometimes a little longer and the green led stays lit. then I have to turn the power switch on the power supply off before I can turn the computer on with the switch on the front .-   raven918
Best Solution
posted on Oct 11, 2006
Helpful)
sandrew
Rank: Wiz  ASUS Expert
Rating: 83%, 5980 votes
When your pc starts to boot up do you get two beeps one then another, although not two together, if not and only one beep occurs
this could mean a memory problem, two beeps together normally a cmos bios problem.(Only part you've not changed was your ram)
Do you get as far as the bios screen?, if so look for a line in advanced cmos settings, saying 'halt on all errors' dissable this and sometimes on boot up the problem will show itself in the initial dos screen.
Keep diggin.
Comments:
Oct 11, 2006
- Very odd! 2 power supplies 2, 2 processors, 2 motherboards, how unlucky can you get, not solving it.
I can assume your getting power to the board because of the light you mention, so either the switch on pc is faulty or the motherboard is shorting out on the chassis, and maybe worth trying to plug into a different socket as it may be faulty and killed of the psu.
You can check the psu by unplugging from the board and put a paper clip from the green wire to a black wire on the 20 pin connector then turn on psu.
Was this helpful?
Yes
No
Solution #2
posted on Nov 30, 2007
Not Rated)
chiplevel
Rank: Guru
Rating: 88%, 88 votes
i think only 5 v in the power supply is working the 12 v supplu thats the yellow wire in psuis not workin and the orange wire 5 v is also not working check ur psu shorting the green and rthe black if the psu is working then the power supply is ok either the supply has been shorting to chaisis
Was this helpful?
Yes
No
Popular Solutions for ASUS A7N8X-E Deluxe
Questions and Unsolved Problems for ASUS A7N8X-E Deluxe
Do you recommend ASUS A7N8X-E Deluxe Motherboard?
Answer
Answer
system board, dev 001, err 91, fru 3610
Answer
plug at interner exployer doesn't make contact front plug on inspiron 530 i purchased 06/2009 i... (More)
Answer
blackberry 8100 trackball wont move up it just move from left to right and down
Answer
I need a manual for the Apache X58 machine. Help please.
Answer
i have problems with webcam vx3000 microsoft and windows live messenger on windows 7
Describe your Motherboards problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
