Question about Samsung Weather Resistant Security Camera SSC-12C
SAMSUNG SSC21WEB I HAVE A SAMSUNG SSC21WEB SYSTEM WITH SSC1280 RECORDER. I TRY TO RECORD 1 CAMERA & IT WONT. IT ONLY RECORDS ON QUAD MODE. ALL CABLES ARE RIGHT. USE TO RECORD 1 CAMERA AT A TIME NOW WONT. ANY SUGGESTIONS?
If it is the same year as mine you can change the settings through the ssc21web system instead of the recorder-have you tried that yet? The ssc21web system has the ability to be set to view the input from the cameras. There are many options- motion detect, quad, single, it will switch from single to quad intermittently, etc. Maybe your settings were changed on the ssc21web and not your recording devise-check that first, then go back to the ssc1280.
Posted on Jul 23, 2010
  • 423 Answers
It's a quad. It records all 4 cameras at the same time. You can display 1 cam at a time. If you play it back, you have to hit the buttong that displays the corresponding camera you want to review.
Posted on Feb 15, 2009
Cameras record in quad view and I cant hear an sound was wondering what I can do to hear the recording. again it has recorded all four cameras in quad view
When it records in quad mode, you will not be able to hear the audio.You will need to choose manual or scheduled recording to get the video feed in full screen for audio to be recorded as well.
Jul 30, 2015 | Uniden UDR444 Video Survailance System;...
TWO SECERTY CAMERAS. One works, when there is motion. The other records all the time. No motion at all.
Its prop a mode it has on it, i would check the camera it self and see if there is a switch for motion and stay recording all the ttime.
Nov 25, 2014 | Quad Home Security
Ssc21web password reset please! I tried HTTP and it asked for username and password. I tried root/root, root/admin admin/admin, etc. but nothing worked.
Samsung told me the newer versions of Windows and Internet Explorer, will not work with this system. Microsoft told Samsung it was their problem. Find a old computer with ME and Explorer 5 and it will work again. I have the ssc17web.
Oct 09, 2009 | Samsung SSC DVR Digital Video Recorder...
Mine records and then stops after about 2 minutes
I had to modify the resolution and framerate settings to a lower level to make mine work reliably using 4 cameras. Otherwise mine would do the same thing as you have described. Once I lowered these it has worked but still locks up recording on occasion. I check it as least once a week to make sure it's still recording. When it locks up, the video remains, but the time freezes and the recording stops even though the recording light remains on.
Aug 14, 2009 | Samsung 4 Channel Dvr
Samsung SHR-1040 Digital Video Recorder
it sound like the system is locked up or your hard drive is going bad. write down all the info on the unit and reset and reprogram the unit. this may solve your problem if not you my need to send it in for repair.
•Factory Reset Hidden Key :
Mode Key + CH 2
•The Password and all setting
value will return to the initial
default value.
•Default Password is ‘4321’ .
mj
May 18, 2009 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Wont let me record! Flashes "Protection!"
My Samsung camcorder one day displays protection. Used or new tape no difference. Used the menu options to remove protection and it gives me a play mode alert. Regardless I can not record in protection mode. Help!
Feb 08, 2009 | Samsung SC-D103 Mini DV Digital Camcorder
Direct tv hdbox & Plasma TV & DVD SSound system & DVD recorder
Need to make sure you have the red,white,and yellow rca connection cables ran from the samsung dvd player to the red,white,yellow input on the back of the dvd recorder. Once you do that make sure you put your dvd recorder on line 1 input. If you look closely on the back of your recorder it should say line 1 input. If your recorder isn't on that input you can put the recorder on line 1 input by using dvd recorder remote and pushing the input button. Make sure you don't push the tv input button the dvd recorder remote there should be a seperate input button or a way to toggle the inputs on the recorder. Once you verify all that turn on your tv and go to the input on your tv that you watch the dvd recorder on and you should see what your recording on the tv.
Nov 20, 2008 | RCA RTD155 System
Dvr4-alert full screen playback
That's because this is a quad. It compresses all 4 video feeds into 1 file. When you play it back, it decompresses the video and shows you each camera. Playback through this unit is the only way to see 1 camera at a time.
To be able to copy 1 camera shot to a DVD, this is what you need to do: You need to have a TV with Video in and Video out jacks.  Connect the Quad to the TV Video in jack and connect the TV Video out jack to your DVD Video in jack. Playback a single camera shot on the quad to the TV and hit record on your DVD. - The DVD will record whatever is shown on the TV.
Oct 26, 2008 | Home Security
Problem when Trying to record
If you are trying to record to a tape and the display shows "Protection", you must slide the protection tab at the top of the tape to the "Rec" position.
Jul 23, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Connecting the recorder to the security system
If you are hooking your cameras into the SMO-151qn then you can use the pigtail cable to connect to the Shr-1040. Make sure the video out from the SMO-151qn goes into the video in of the Shr-1040. If there is a choice use CH1. On the Shr-1040 hold down the mode button and press CH2 for about 10 seconds. The Shr-1040 should reboot. Once it comes up press the record button. After recording for a feww minutes stop the recording. On the SMO-151qn press the button on the front Live/Vcr. You should see the screen from your Shr-1040. IF you hit play you should see what you recorded. Good Luck!
Jun 11, 2007 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Samsung Weather Resistant Security Camera SSC-12C Logo
440 people viewed this question
Top Samsung Home Security Experts
Heilcode
Level 1 Expert
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
