Question about Emerson EWF2703 27" TV
Remotes not working for tv
We just recently received brand new Directv receivers. It has a universal remote to control the receiver and the tv. Everything worked great until two days ago. Now the new universal remote won't control the tv and the old remote for the tv won't control it either. The tv can manually be turned on and off, but neither control can run it. We have tried new batteries, and tried to reprogram the codes in for the universal remote.
    Sergeant:
  • 337 Answers
You have already diagnosed the problem,the remote receiver on the tv is bad,is rare but it happens but before you call for help try unpluging the tv from the wall for 10 minutes and then plug it back in and try it,sometimes this takes care of the problem,if that does not do it you will need the help of a servicer ,your remotes are working but the receiver is not processing the information.If you are familiar with tv service it should be easy to locate the receiver,sometimes is soldered to the chassis and sometimes is part of the push button assembly and conected to the chassis by wires,if is part of the push button is easier to replace,if you are not too familiar with tv service be safe and ask for help.
Posted on Oct 11, 2006
  • Omar Urrutia
    Omar Urrutia Oct 11, 2006
    Rating the response is important to the person helping you
I have a new RC65 remote, Sony Bravia KDL-46XBR4, and Directv receiver HR 21-200. I have programmed the remote in the TV position and can control the television. I then switch over to the directv symbol...
reset the code again go to www. remotecodelist.com or remotes.com
tight the spring contacts very well with long pliers, and clean it
replace new batteries with the same type, alkaline, and FULL Charge.
download and fix it.
God bless you
Oct 12, 2012 | New Directv Rc-65 Universal Remote Contron...
Rf20 code for directv HR34/700 receiver
Check these codes:
503, 505, 515, 548, 579, 580, 581, 582,
583, 584, 586, 587, 625, 633, 634, 691,
698, 701, 708, 714, 715, 716
Jul 22, 2012 | Universal Remote Control RF20 LCD Remote...
I need to know the code to program a jvc av-32432 tv to a direct tv remote
Hello
The code for JVC with Direct TV Universal remote is:
10053
Programming DIRECTV Remote
[1] Locate the DIRECTV Receiver's brand and model number
(on the back or bottom panel) and write it in the
spaces below.
[2] Enter the 5-digit code for your DIRECTV Receiver
[3] Power on the DIRECTV Receiver
[4] Move the slide switch to DIRECTV icon
[5] Press and hold in the MUTE and SELECT keys until the
green light under the DIRECTV icon flashes twice and
then release both keys.
[6] Using the number keys enter the 5-digit code. If performed
correctly the green light under the DIRECTV icon
will flash twice.
[7] Aim the remote at your DIRECTV Receiver and press
that the power key once. The DIRECTV Receiver should
turn off. If it does not turn off, repeat steps 3 and 4, trying
each code for your brand until you find the correct
code.
OK.
Jul 06, 2011 | Televison & Video
Need code & instructions for Emerson TV. I have universal remote
Hello
Codes for Emerson TV with "Direct TV - RC64 for web Univeral remote control are:
10154, 10236, 10463, 10180,
10178, 10171, 11963, 11944,
11929, 11928, 11911, 11394,
10623, 10282, 10280, 10270,
10185, 10183, 10182, 10181,
10179, 10177, 10158, 10039,
10038, 10019
You haven't specified the model number of remote control you possess; that is why I send this remote controls codes.
[1] Locate the 5-digit code for your DIRECTV® Receiver
[2] Power on the DIRECTV Receiver
[3] Slide the MODE switch to the DIRECTV position
[4] Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
[5] Using the number keys, enter the 5-digit code. If
performed correctly, the green light under the
[6] Aim the remote at your DIRECTV Receiver and press
the PWR key once. The DIRECTV Receiver should
turnoff; if it does not, repeat steps 3 and 4, trying each
code for your brand until you find the correct code
OK.
Jul 02, 2011 | Emerson Televison & Video
The remote will work my tv but wont work anything on my sat receiver
swith the "mode" button (on the top) to the directv symbol(the first one) the tv will still work in that mode.
Aug 20, 2010 | Universal Remote Control DIRECTV Universal...
Direc TV remote won't work Receiver
call directv and they will walk ya thru reporgramming remote for reciever. or goto menu, setup, remote, then follow on screen instructions. i cant give u the exact instructions cause every reciever is a bit different and its different if one remote operates two directv recievers. ( like a bar would do to operate two tvs with one remote)
Jun 12, 2009 | Directv Universal Remote
Can i use a store bought universal remote and if so which one
Just about all of them will work these days. However, I've had great luck with the One For All remote's.
Another option is a learning remote. With a learning remote, you can learn any remote you own to the one. Again, the One For All 8910, is a universal and learning remote. This one is my fav:
http://www.oneforall-na.com/remote.php?type=URC%208910
May 02, 2009 | Directv HDTV Receiver
I have a Directv RC24 remote control. I am trying
1. Locate the DIRECTV Receiver's brand and model number
spaces below.
2. Locate the 5-digit code for your DIRECTV Receiver (see
page 10).
3. Power on the DIRECTV Receiver.
4. Move the slide switch to DIRECTV icon.
5. Press and hold in the MUTE and SELECT keys until the
6. Using the number keys enter the 5-digit code. If performed
will flash twice.
Magnavox codes:
11454, 10054, 10030, 10706, 10179, 11254
7. Aim the remote at your DIRECTV Receiver and press
code.
8. For future reference write down the working code for
your DIRECTV Receiver in the blocks below:
Once you have programmed the DIRECTV remote control for
your TV, you may want to activate the TV Input button.
1. Move the slide switch to the position under TV icon.
2. Press and hold the MUTE and SELECT keys until the green
light under the TV icon flashes twice and then release
both keys.
3. Using the number keys enter in 9-6-0 (The green light
under the TV icon will flash twice)
You now have the ability to control the Input select feature for
your TV.
Feb 20, 2009 | Directv RC24 Remote Control
Remote control code
Those 2 remotes are not compatible with the newer directv receivers
Feb 09, 2008 | Directv D10 DTV Receiver
Emerson EWF2703 27" TV Logo
120 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
