Question about GE Advantium 120 Convection/Microwave Oven
Not heating turntable and lights work, seems fine other than the different noise and no heat
  • 905 Answers
You will need to take this in , unless you know what your doing
this is most likely the magnetron or high voltage capacitor but test will need to be done to ensure the rest of the circut checks out ok
Posted on Nov 06, 2008
Why does the turntable spin when the door is closed ?
this is normal thats the way they heat from in to out
now if you open the door the light is on
if it does not just change the bulb 10w 120 vac e14
Sep 16, 2015 | Microwave Ovens
Does not heat everything else works ge microwave oven JNM1851SMSS
It will be one of three things, magnetron, "heats food" high voltage diode,"sometimes cracks" or the high voltage capacitor, "usually shorts"
Mar 23, 2012 | General Electric JNM1851 1100 Watts...
Does not heat up properly. Seems it lost it's
Assuming the turntable works maybe your magnetron isn't working properly. Cheaper to buy new microwave then to fix it.
Apr 30, 2010 | Kenmore Microwave Ovens
MICROWAVE NOT HEATING
Most likely you have a magnetron problem. Easy to replace (DYI) but make sure the high voltage capacitor is fully discharged first against the case.
Dec 11, 2009 | Kenmore 62622 Microwave Oven
No heating, turntable does not turn, but clock & lights work.
Check to make sure the plastic on the shelve holders or tuntable guide did not wear and expose metal. If these holders or brackets are wore and exposed metal it shorted out your micro wave. They need to be replaced and a fuse needs to be replaced inside the control panel,
Sep 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800 does not heat. All other functions appear to be working normally, the light comes on and the turntable functions. When turned on, it makes a humming noise slightly louder than normal,...
Possible bad heating element, You should remove the cover of the unit and look at the heating element with the power off. Until you get your problem resolved I would recommend not to even turn it on due to the fact that you are unsure what is going on and you smelt some burnt smell. Just for safety until you fine the problem
Feb 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven does not heat anything. Clock, turntable, lights work. I turned the turntable off while the oven was cooking--heard a noise, now it doesn't heat anything.
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Jul 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Heard a loud glass breaking noise, now micro-wave will not heat anything. Turntable works, everything looks fine but no heating. Model#R-1505LK
Does it seems to run louder?
I would suspect a shorted high voltage rectifier diode.
We have the full service manual and have uploaded it to our site here.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 19, 2008 | Sharp Microwave Ovens
SPORADIC HEATING
check highvoltage crcuit ,and check fan, and turntable motor,
Oct 18, 2007 | KitchenAid KHMS155LSS 1000 Watts Microwave...
GE Advantium 120 Convection/Microwave Oven Logo
76 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
