Question about Toshiba PDR-M81 Digital Camera
"No Card" message
My camera continues to have a NO CARD message even though I have tried two different cards and have formated both thinking this might be wrong. Any ideas?
4 Suggested Answers
try putting in with the camera on. mine has done this and that's how i got it to read the card.
Posted on Dec 05, 2007
  • 10594 Answers
SOURCE: 1GB SD memory card problem
Your camera is an old model and can't handle big memory card. Use only 128 or 256MB card in this model.
Posted on Aug 23, 2008
SOURCE: PNY 2GB memory card
I have the same camera and bought a 4GB PNY SD card and it wouldn't work, so I read the manual :) The manual says, "SD Memory Cards having the following storage capacity can be used on your camera (Toshiba PDR-3330):
8MB, 16MB, 32MB, 64MB, 128MB, and 256MB"
Hope this helps! -Kim
Posted on Dec 26, 2008
  • 180 Answers
SOURCE: What kind of memory card does this camera take?
i checked specs on that camera and the maximum memory card you can use is 512mb. if you get one that size you should have no errors anymore
Posted on Feb 19, 2009
0 characters
1 Points
I just bought a 4 GB SDHC card so I can take longer videos on my canon A610. I can't get it to work, even though i formatted it using my computer reader. I spoke with the card maker, and they say that they...
Your camera, introduced in 2006, cannot use SDHC cards, but only 'standard' SD cards up to 2 GB.
You should always format the cards (if needed) in the camera and not in the computer to ensure compability.
Aug 06, 2010 | Canon PowerShot A610 Digital Camera
I purchased a new memory card (sandisk sdhc ) it will not format?
Get a new camera :-)
Seriously, the Z740 is designed to work with SD cards, not SDHC cards. While SDHC cards will fit into the camera, they will not work. You need to buy SD cards 2GB and smaller.
Jul 26, 2010 | Kodak EasyShare Z740 Digital Camera
When i insert the xd card i get a message saying card error or card full even though the card is empty. any ideas on how to fix this or is time to replace it.
1) Try and clean the contacts on the card, soft dry cloth. I don't think you can get at the contacts in the camera, but you could give the card port a blast of compressed air if you got a can.
2) As the card is empty, try a re-format in the camera.
3) It could be you need a new card, a backup is always handy but if you can borrow one, try that first.
Jul 19, 2010 | Fuji Finepix S5800 Digital Camera
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Digital Cameras
Memory card requires formatting
Have you tried a different card, that may help. Plus, there are cameras that will not "like" certain cards. If the card is...let's 8 gig...some cameras can't read that or even write to it. Try a different card and a 1 or 2 gig card too. Good Luck.
Mar 28, 2010 | Kodak EasyShare DX7590 Digital Camera
Xd clean card
me too , thats my prob .
Sep 25, 2008 | Olympus Stylus 820 Digital Camera
Memory card error
Dear jk_cibergirl:
It is likely that some type of corruption has happened to your memory card. Try reformatting the card in your camera to correct any problems. If that works then you should be fine to take more pictures from this point. If not, you may need to get another memory card. Check your memory card manufacturer for warranty information.
Just a few tips to help you avoid this problem in the future:
1. Even though your computer can format a memory card, do
not ever do so from your PC. Your computer lays down a
different type of file table than your camera, which can lead
to data corruption.
2. Always format the memory card in the camera it will be
used in after each downloading session AND even when
using a brand new card right out of the box for the first time.
3. Do not share cards among cameras - even if they use the
same type of card - even if they are the same camera model!
Consider your memory card to be camera specific.
4. Do not place your camera close to strong magnetic fields
(e.g on top of a television)
5. Lastly, even though your camera has a single image erase
button, do not do what some do and fill your card up and then
go into the playback mode and erase a few images just to
take a few more new images. This almost certainly will lead
to data corruption on your card. Download your images and
reformat the card to take additional shots.
If you need to recover any lost images from that memory card, you can give it a try by simply downloading free software from the internet (such as Zero Assumption software available at, connecting your memory card to your computer via a card reader, and running the program on the card reader volume.
Hope this helps.
May 28, 2008 | Canon PowerShot A520 Digital Camera
Toshiba PDR-M81 Digital Camera Logo
18 people viewed this question
Top Toshiba Digital Cameras Experts
john milligan
isaac johny
isaac johny
Are you a Toshiba Digital Camera Expert? Answer questions, earn points and help others
