Question about LG RU-60SZ30 60" Rear Projection HDTV-Ready Television
Blue tint on sides of picture
I have had TV approximately four years. No lights when power on. Blue tint of sides of picture.
  • angelas708 Feb 26, 2009
    I too have blue tint on the each side of the screen at the bottom - my TV is 4 1/2 yrs old
Try to fix your engine
Posted on Nov 11, 2008
  • 153 Answers
Check for any cold solders and do dry soldering on the PCB and try changing the flyback, it looks like the flyback is dying. Try this.
Posted on Nov 06, 2008
Have a hl61a750a1fxzc(model) tv, tv is about 5 years old. Tv has a greenish picture tint... Looking at http://ww2.justanswer.com/uploads/TVTech1/2010-07-02_101408_SMPTE_Color_bar.jpg top 7 colors on my tv...
please do this test: God bless you
  • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
Aug 01, 2013 | Samsung Hl61a750 61" LED Powered DLP HDTV
There is an approximately 3" line of blue light
IS it like the picture is being cut off? You may need to check the connections to your buffer boards and main logic boards.
Thanks,
Michael
Apr 05, 2011 | Sanyo DP42746 42 in. Plasma Television
Blue tint left side of tv
sounds like you need a new light engine. Sony can probably get you one at no cost if make enough noise, they are aware of problems with their light engines. good luck
Apr 25, 2009 | Sony KDF-50E2000 50" HDTV
Picture and sound problem at 21" sony waga color tv
This is not a simple question to answer without looking at it, my recommendation is to call a service center in your area. That's my professional opinion.
Feb 04, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blue haze spot-yellow tint
I have the same problem with blue haze that just spread out on model 55VS69A ,
tv is almost 2 years old. i called hitachi and they advised to call a local repair center to check the tv...they confirmed Optical Block (light engine ) replacement light engine cost $1400 and labour $400, so i called back hitachi and they said they will provide light engine and will have to pay labour!....this is not right paying out of pocket for a tv less than 2 years old....I am not sure if the issue will resurface again...more likely ....Hitachi is supposed to issue a recall or atleast like sony did to cover all cost for there defective TV's....I will NEVER buy hitach again.
Hitach SUCKS.
Dec 28, 2008 | Hitachi 60V500 60" Rear Projection...
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Blue tint and lines on screen.
Those lines sound like "retrace lines" and several things can cause them. The most common are shorts inside the picture tube and shorted semiconductors in the video driver circuits. They can also be seen if the blue screen voltage is too high or if someone has tampered with the screen voltage control.
Jan 20, 2007 | Philips 28PW9536 28" TV
LG RU-60SZ30 60" Rear Projection HDTV-Ready Television Logo
116 people viewed this question
Computer Repairing
Computer Repairing
