Question about HP LaserJet 3330 All-In-One Printer
Loud ratchet noise
We start printing docs from PC, and all of a sudden a loud ratchet noise starts and won't stop until I pull the plug from the printer. It will not print during the ratchet noise. There is no paper jam. At times, when I put the plug back in and power up, it goes thru startup cycle, and will start that loud ratchet noise again. This happens sporadically. We can print for an hour or so, and then, all of a sudden, the noise take over and no printing takes place.
  • 3 more comments
  • 2008fixme Nov 06, 2008
    The printer is an HP Laserjet 3330...works on a toner cartridge. It doesn't matter if the cartridge is older or a brand new one. I have been using only genuine HP cartridges.
  • tede s Dec 20, 2008
    I just started having the same problem. Can some one tell me what the fix it? Do I try to clean the ink on the inside where the cartridge is? Thanks for your help
  • hardcopy Jan 09, 2009
    I have the same problem.
  • ktillack Jan 16, 2009
    loud ratchet noise can anyone help HP 3330 laser jet all in one
  • jon2332 Feb 09, 2009
    This has been happening for some months. Usually if I cycle the power a couple of times it will settle down and prints OK until the next time I use the scanner when the noises start again. It has been getting progressively more difficult to get rid of the noise in this way and now seems impossible.
I've had this problem on the HP 3330. I think it is the scanner portion (that runs under the glass to perform scanning and copying) getting all the way to the right-hand side of the printer to where it can go no further and the gearing is slipping (causing the ratcheting sound). My guess is that the scanner 'jumps a tooth' every so often and eventually when it is initializing, experiences this problem- but only my guess. Mine *might* have been associated with an 'Error 79' as well (the Error 79 occurred at the same time and .
What I did was open the top as if I were copying from the glass. There is a single screw on the left hand side-in the middle, holding a smaller section of glass in (for the Document feeder scanning). I removed this screw, and carefully removed the glass cover and small (1.5 x 9 inches) piece of glass.
If you look into the rear bottom left-hand side of the scanner (below where you removed the glass) you'll see a belt. I pulled the belt (can't recall if I pulled it left or right- but when you pull it, you'll see the scanner move left or right) just a bit, causing the scanner to move a little (1/4 inch) from the right-hand printer wall (hence the scanner moved left) to stop it from 'bottoming-out' against the right printer wall. Now when the printer initializes, it no longer bottoms-out against the right side (and doesn't make the ratcheting sound). And, it doesn't appear to have affected the copying/scanning from the Auto Document feeder or scanner bed either.
Posted on Apr 28, 2010
  • 6,674 Answers
Have you been using ink cartridges other than store bought? Reason I'm asking is that i used a refill kit, and tried those half price refill places, only to find ink was leaking out when not in use & clogged up the ends where the cartridge moves across. take a flashlight & look at the ends of the track that the cartridges slide across on, you may see a build up of ink, that won't allow the cartridge to travel as far as it needs to go to run properly.
Posted on Nov 06, 2008
  • Mike Butler
    Mike Butler Nov 07, 2008
    Thanks for clarification, & guess I missed model # somehow.
How do I stop a print job? I can not fine anywhere to cancel or stop. I had my job set to do 24 labels and only needed 1. Once it started I couldn't stop it until I pulled the plug.
go to settings and go to printers find printer and click on printer picture. Printer queue show show print job click on this and select stop print . MAy need to right click on print job to find stop or delete option. May have a printer symbol on right hand bottom of screen shortcuts that will go into the printer queue also !
Aug 13, 2015 | Dymo ® LabelWriter® 450 Series PC...
HP Deskjet 5740 Printer
Did you check if there is anything obstructing movement inside the printer?
Mar 24, 2008 | HP DeskJet 3740 InkJet Printer
Hp 1018 printer making really load grinding noise and not printing
ok first try restarting your printer, then try uninstalling the driver for your printer off your computer, restart your computer and printer and then reinstall your drive for the printer, see if you get a replacement for your printer or a refund
Dec 01, 2014 | HP LaserJet 1018 Printer
My Canon LBP6000 printer has suddenly stopped working and, when switched on, gives a loud rattling noise. What is wrong?
If you have extra used cartridge, try replacing the cartridge. If there's no noise, change your cartridge with a new one.
Oct 09, 2014 | Canon Office Equipment & Supplies
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Apr 16, 2017 | Splendide 2000S Front Load Washer / Dryer
Lexmark x1270, installed on new Dell, will scan/print once but print queue won't clear after printing, and further jobs just back up in queue. Once, after trying reboot, printed next doc but that was...
Try to follow the steps below to fix the problem:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Aug 06, 2011 | Lexmark X1270 All-In-One InkJet Printer
My Dell 2135cn printer all the sudden started making crazy loud grinding noises. Then I got a paper jam. I fixed the paper jam and tried to print again, but got the loud grinding noises and paper jam...
Refer to the service manual in disassembling the device.. Clean it thoroughly then try it again.. If, you have no experience in doing so, hire a qualified tech to do so.
Jun 17, 2011 | Dell 2135cn All-In-One Laser Printer
WHEN THE PRINTER GETS STARTED IT MAKES A LOUD NOISE BUT PRINTS. NOW IT STOPPED PRINTING
Hey dude,
First check with the interface cable from system to printer.If when the printout is given it starts making noise,then the communication is ok.Now check with the Print driver ,try to uninstall and reinstall it.i assure it'll help so.
With hope,
Mar 06, 2011 | HP LaserJet 1000 Printer
The problem on my HP Photosmart C4240 is a loud clicking noise (like a ratchet slipping) when the printheads stop moving. The noise occurs when the head starts moving and when it stops.
hi ,
try and clean the print heads manually
and reinstall the printeads
disconnect the power cable from the back of the printer and keep pressing the power button for 20-30 seconds
follow the instructions from the below mentioned url
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00867260&cc=us&lc=en&dlc=en&product=3300219
if the issue is still not resolved its a problem with the printer and if the printer is in warranty call hp ion the toll free number-1800-474-6836
hopefully this should resolve the issue
thanks
regards
HAMID
Feb 19, 2010 | HP Photosmart C4240 All-In-One InkJet...
When you start printing it starts making loud banging noises
It's called an ENCODER STRIP you will have to revmove the covers to reinstall.
Jan 02, 2009 | Dell 924 All-in-One InkJet Printer
HP LaserJet 3330 All-In-One Printer Logo
352 people viewed this question
Ben Johnson
