Question about Kicker ZR360 Car Audio Amplifier
Kicker zr360 amp
Ive got a kicker zr360 amp that worked fine until i chaned some switch from hipass to bipass with my power on. im not sure if that is the problem but yesterday i touched my amp and i acted as the ground...any solutions?
  • 29 Answers
Double check that your ground wire is connected to the ground terminal, make sure the ground wire is not broken.
Posted on Nov 11, 2007
Im trying to figure out how i should wire my Kicker S12L5 sub to my Kicker Zr360 amp. should i wire it for 1ohm and bridge it or what if you could help it would be much appreciated thanks. ...
What is the wattage of the sub? What is the power output of the amp, bridged & not bridged? If the bridged power output will NOT exceed the rated power of the sub then you should bridge it. If it will exceed the rated power of the sub then don't. 8)
Nov 11, 2010 | Kicker Car Audio & Video
My zr360 when i turn on the radio turns the subs to full pulsing bass very loud and there is no control. have to shut off the radio to stop it
yuor amp has an internal power supply problem,contact eric @ Capital Audio & electronics Repair 850-339-1130 we repair all namebrands & all models
Mar 16, 2010 | Kicker ZR360 Car Audio Amplifier
I have a Kicker ZR360 CLASSIC AMP that puts out very little sound until I push on the crossover module. Is something wrong with the crossover module or a connection on the amp itself?
THERE IS AN ISSUE WITH THE FEMALE CONNECTOR THAT IS SOLDERED TO THE PC BOARD THAT ACCEPTS THE CROSSOVER CARD. IF THE CROSSOVER IS PUSHED WITHOUT CARE, IT EVENTUALLY STARTS TO HAVE POOR CONTACT. THE CONNECTOR MUST BE REPLACED. YOU SHOULD BE ABLE TO FIND MY ADD FOR REPAIR UNDER ZIPCODE 70360. I AM NEW TO THIS FORUM AND DON'T YET KNOW HOW TO LINK TO MY ADD ON THIS SITE. YOU SHOULD BE ABLE TO FIND IT BY SEARCHING MY LOCAL ZIPCODE THOUGH. LET ME KNOW IF I CAN BE OF FURTHER ASSISTANCE......V
Dec 10, 2009 | Kicker ZR360 Car Audio Amplifier
Kicker zr360 in protection
unplug rca,disconnect spker turn on amp if light goes away start connecting with one rca and one spk wire and you will find the problem should go away '''''''make spk polarity is wright
Apr 07, 2009 | Kicker ZR360 Car Audio Amplifier
Kicker 550.3 amp will not power up
do u have the remote wire hooked up to the (rem) spot usally inbetween the pos and neg?
Mar 15, 2009 | Kicker ZR360 Car Audio Amplifier
No Power light or sound from kicker amp and speakers
OPEN UP THE AMP AND CHECK THE FUSE HOLDER THAT IT IS CONNECTED TO THE BOARD
IT MAY HAVE GOT BUMPED AND THE CONNECTION MAY HAVE BROKE IT MAY BE A HAIR LINE BREAK WITH THE COVER OFF AND THE POWER ON MOVE THE HOLDER MAY NEED TO BE RESOLDER THE CONNECTON THATS ALL IT IS GOOD LUCK
Feb 20, 2009 | Kicker ZR360 Car Audio Amplifier
Kicker zr360 ground problems
It sounds like you have some broken solder connections on the power terminal. if you know how to solder and are good at taking things apart and putting them back together you can fix it pretty easy.
Car amps are not always very easy to take apart if you have never done it before.
Radioshack guys don't know much at all about real repair work, but they can help find a part you might need.
This can probably be fixed at a repair shop for $60 to $80 depending on the shops rates.
You know one thing for sure, the amp will work if you hold the terminal down. If it was an electrical problem that needed some real troubleshooting done, holding your finger on the power terminal would not make it start working again. This has to be a bad connection inside the amp.
Feel free to ask for more help again if you need it, and if this was helpful to you a good rating would be appreciated. Thanks
Jun 19, 2008 | Kicker ZR360 Car Audio Amplifier
Your amp
Do you have a remote wire set up? if not, you need to run one from your deck so that it can trigger the amp to come on.
May 14, 2008 | Kicker ZR360 Car Audio Amplifier
Kicker ZR360 Car Audio Amplifier Logo
134 people viewed this question
Top Kicker Car Audio & Video Experts
Morne Olivier
Marvin
Marvin
Dalynn Turner
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
