Question about HP LaserJet 1300 Printer
Toner Cartridge Jammed
I installed a new toner cartridge but forgot to remove the tab. It is now stuck in the printer. The manual is no help. I don't want to force it out. Is there some undocumented way of freeing it?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 188 Answers
Hi Cope,
Unfortunately, you are going to have to force it out.
I am quite surprised you didn't have to force it to go in, but none the less, don't be afraid to apply a little pressure to remove it.
If you apply equal pressure to both ends of the cartridge while trying to remove it, you shouldn't end up damaging anything. You may knock the pull tab off the new cartriged, but the printer itself is pretty ruggid, and you shouldnt cause any damage.
Posted on Nov 06, 2008
I just changed the toner and the printer does not print.
If u have the CD of tht printer , u just delet tht printer from the Devices and printers settings. And re installed it
Aug 14, 2012 | Brother HL-2040 Laser Printer
I have red light the second (toner) and the last lamp (exlamation). The first one i don't care, it was red since i charged it, but since the exclamation is red doesn't do anything and the green...
The toner cartridge is not installed, or the printer detects a toner cartridge error. The error is caused by a defective cartridge, an unsupported cartridge an invalid refill, or a cartridge meant to be used in another geographic region.
If the toner cartridge is not installed, install it. If the toner cartridge is installed, remove it and install a new toner cartridge.
For Cartridge errors, Press and release the right button twice briefly to display secondary error codes.
For further assistance, please contact Lexmark Technical Support.
Jun 29, 2011 | Lexmark E120n Laser Printer
ESP5200printer,new,paper jam message
Hi slicknick58,
Paper jam message occurs when there are stuck papers inside the printer. There are several ways on how to correct this problem, either you remove the visible stuck paper manually or replace the toner or ink cartridge. Below are the steps you'll want to follow when this problem still occurs.
1. Turn off the printer. Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it. Remove any paper trays. Inspect them for wrinkled or damaged paper.
3. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
4. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
5. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
6. If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything.
7. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
8. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path and try repeating the above steps again.
Hope it helps.
Thank you for using FixYa.
Apr 20, 2011 | Kodak ESP 5 Printer
Toner light is on and it wont print
The toner light being on solid means that the toner cartridge is empty.
You will need to replace it with a new one.
When replacing the cartridge, please remember to seperate the toner and the drum, DO NOT THROW OUT THE DRUM.
If you have already changed the toner cartridge with a new one, then you will want to reset the toner cartridge.
To manually reset the printer, first, remove the toner from the printer and separate it from the drum unit.
With the toner cartridge in hand and the brother writing facing you, look to the left side of the cartridge. You should see an arc shaped opening with a white tab in it.
The tab is set at the right position and must be pushed back to the left side of the opening.
To push the tab back, you must turn the grey gear attached to the front roller upwards as you push the tab.
Once the tab has been placed to the left position, the printer will accept it as a new toner cartridge.
Thanks,
Pat
Apr 07, 2010 | Brother HL-2170W Laser Printer
Toner light will not go off and have replaced toner with new cartridge
Hello Rapidlube,
This problem is a common issue and easily fixed.
When putting in a new toner cartridge, the printer usually automatically resets the toner count.
In a situation like this, the printer did not automatically do the reset and so we must manually reset the printer.
Mar 25, 2010 | Brother HL-2070N Laser Printer
Unable to remove black cartridge, it is really stuck. Help
I just changed my black toner this past week, and finally figured out why the cartridges get stuck like this.
First, you must eject the toner cartridge on the front-panel menu:
Menu->Replace Toner->Eject Toner->Black(K)
It will say "Rotating to Black Toner(K)" and then say "Black Toner(K) Ready to Eject"
Now, open the front panel and you'll see the black toner cartridge in front. You can also open the top panel if you want more light on your work area.
Lift the lock handle on the old toner cartridge to the "unlock" position, and here's the part that the Dell instructions don't have:
There are two channels for the toner cartridges -- one on each side. Run your finger down the channel on the right, and you'll feel a small, spring-loaded catch. This catch often gets sticky and won't release the cartridge without some help. Don't force it, but gently move it towards the back of the printer and it should release.
Now the old cartrdige should slide right out, and you can finish per the instructions that came with the new cartridge.
Jan 27, 2010 | Dell 3100cn Laser Printer
Can't get new toner cartridge all the way back into the Xerox 4CP copier/printer. Does the power need to be on to do it?
No the power is not needed. You probably forgot to pull the packaging tab out of the toner before you installed it. Refer to your toners instructions. This tab keeps the toner in the package in shipment. Do not force it in. You will destroy your printer if you do.
Jul 25, 2009 | Office Equipment & Supplies
How do you remove toner cartridge from a Dell 3010cn color laser printer correctly.appears to be stuck trying to remove
This is how to Install or replace the Toner Cartridge.
Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier does not rotate).
1. After confirming the Insert Yellow Toner(Y) message, open the front door.
2. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
NOTE: You need to remove the protective cover only the first time that you install the toner.
NOTE: Dispose of the protective cover after you remove it.
NOTE: The protective cover is attached to each toner cartridge mount.
3. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
4. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
5. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
6. Close the front door.
NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly.
7. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
8. Repeat steps 1 through 7 when inserting the remaining cartridges.
Cheers!!
Apr 21, 2009 | Dell 3010cn Laser Printer
I have samsung scx-4300 printer this time show toner error
good day sir, these are the possible causes of toner errors of samsung scx. You can check all this causes.
  • You have used an unauthorized cartridge.
  • the toner cartridge is not installed.
  • Paper has jammed in the fuser area or in the fuser manual feeder.
  • The toner cartridge has run out.
  • the toner is almost empty.
  • To prevent serious pollution of breakdown of printer, the printer stops printing.
  • the toner cartridge is not a samsung genuine cartridge.
hope this will help you. god bless.
Mar 24, 2009 | Samsung SCX-4300 Monochrome Laser...
Label stuck on a roller?
Looks like label stuck on the toner cartridge. Easiest solution would be to replace toner cartridge or if you can slowly spin the OPC drum on toner cartridge till you find label NOTE: damage to the OPC drum with affect print quality as well as oil from fingers will affect PQ( print quality)
Jan 13, 2009 | HP LaserJet 5000n Printer
HP LaserJet 1300 Printer Logo
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
