Question about Mitsubishi WS-55511 55" Rear Projection Television
Need the same help with the continuous blinking light
Continuous green blinking light after electricity going on and off several times. TV was plugged into a Monster surge protector. I have tried all the same troubleshooting with no success. Do you have any solutions or suggestions that might help?
  • Mitsubishi Master
  • 8,617 Answers
Youre set doesnt have a lamp as its not a dlp. The problem is the DM isnt completeing the boot sequence due to the failed caps. You can get the V21/V19 DM repair kit at the following link which contains the replacement capacitors and a CD with step by step instructions with pictures on how to do the repair. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Nov 15, 2008
  • 45 Answers
Replace your lamp, that should do the trick
Posted on Nov 08, 2008
My kids were watching the tv when it shut off. When I got home I turned it on and green light flashed about 100 100 times now the red light flashes continuous. Tv still not coming on.
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jul 07, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
TV goes off after turning on
did you change your lamp? if so check thermal fuse.. i have same tv, it was great for about 18 months then went to ****.. light engine will go out soon, cost between 2,000 and 600 bucks.. i have major complaint with sony atm. i know several several ppl with sdame prblem, might get a class suit started against sony, they knew and did nothing. I am pretty upset with them since i have always been a sony fan until this.
May 20, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tv shuts off and green light blinks 5 times and repeats 5 blinks.
Please buy new Lamp for KDF-55WF655 from Sony Accessories Store with following part number..
" A1085447A " LAMP BLOCK ASSY XL-2200U
(type model number in search box and click)
Always buy Sony original lamp for safety of your TV.
Feb 06, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Continuous flashing green "timer" light on front, tv won't reset
Is your set a mitsubishi/ If so you need a DM repair kit they have various kits for the different mitsubishis at the following link under the repair kit category. The kits contain the replacement capacitors and instructions on CD.
Jan 15, 2009 | Televison & Video
Last night the electric went off now my tv will not come back on all its doing it flashing a green light. my tv is a mitubishi big screen medallion model ws 55615
how many times is the led flashing or is it a continuous blink that doesnt stop? Pleaserespond to this same post and I will try to assist you with the problem.
Sep 07, 2008 | Televison & Video
Mitsubishi WS-55511 55" Rear Projection Television Logo
93 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
