Question about Dishwashers
Control panel cover falling apart
The touch panel plastic cover over each switch located on the door edge are starting to fall apart and exposing the switches on my Kitchen Aid dishwasher (KUDS01FLSS5). The dishwasher is still functional, but I am concerned that one day some water will get into it and short it out. The dishwasher is about 4 years old and the control panel is still under warranty, but covers parts only not labor. Kitchen Aid wants me to have a Kitchen Aid certified repairman to come out and diagnose and repair the panel and they will pay for the part. However I don't want to pay $150 service charge when I can probably do it myself. Is it easy to change the control panel? Does anyone have instructions on how to do this? I am pretty handy at fixing stuff. Thanks.
Eric
  • Kitaika Nov 06, 2008
    Thanks for the quick feedback. I think you are right; it would be cheaper for me to fix it. It sounds pretty simple. Does the console assembly come integrated with the switch buttons and do I need to remove all of the screws from the inner door or just the 6 that are clostest to the console? Thanks for your help.
    President:
  • 2,651 Answers
I looke dup your model and you seem to have the hidden control panel model. the manufacture is funny htat way they will only cover part if you have installedby auth servicer, i looked up the part for you part number 8531269 retails for about $70. its the enitre console assy including overlay. so although they cover it youd be better off buying it direct and installing your self for sure. simple enough repair, the screws (torx15) from the inner door panel come off and release the panel, everthing on the inside simply unsnaps and gets transferred to the new part. just remember to disconnect power first all live wires!
Posted on Nov 06, 2008
  • Ron Coons
    Ron Coons Nov 06, 2008
    part comes only with active overlay(sticker)... User interface(buttons separate part), all screws need to come of, the lower 6 will remove the outer panel so as not to damage it
Doorhandle
for passenger side:
1. unclip screw cover 'center flap' of inside door opener plastic cover, flap is 3/8"x 3/8" (center of plastic cover)
2. remove phillips screw now showing
3. push fabric panel (edge of door opener plastic cover-at hinged end of chrome handle) to allow uncliping of edge of plastic cover (top rt & lwr rt (for passenger side) of plastic cover)
4. open chrome inside door handle to allow plastic cover to be removed-slide plastic cover toward rear, free end of door to remove cover
5. remove switch panel-gently pry with wide non maring pry bar (cover wide blade screwdriver using cloth) do rear of sw panel 1st (don't pry front edge)
6. slide switch panel toward rear to allow removal
7. remove large phillips screw under sw panel
8. remove the 2 plastic covers near top, hinge edge -use plastic spoon handles to encourage caps to pop off. May also require small screwdriver approx 1/8" in to complete pop off
9. remove the 2 phillips screws w/ captive washers
10. remove 3 phillips/hex screws along the bottom inside of door panel
11. on outside/rear edge of panel push the 2 center pins of each in about 1/8"-this allows the clip to be pulled out w/ pin pushed in
12. remove plastic cover (REAR OF SIDE MIRROR)-pull window edge up and back.
13. lift rear of door panel (not hinge edge) up allow hinge edge to pivot around lower pin in door (hinge edge)
14. remove the 2 rt edge "L" brackets (gently pry center plastic pin out) (note the color and replace as removed)
15. slowly peel the clear plastc away from the non hinged end to expose the plastic panel with 3 phillips head screws
16. remove the 3 screws and panel for access to door handle.
17. using access area now available unlatch the rod attached to exterior door handle (unclip plastic to rotate clip up to allow rod to slide out-toward hinged edge)
18. using access area now available remove rod from ext door handle from inside door area
19. remove the 3 -10mm head bolts
20. remove the ext door handle (bottom edge out first)
reverse order to replace door handle
Mar 24, 2014 | 2003 Toyota Avalon
How to remove the drivers door panel on a 1991 honda accord lx
Instructions
    • Insert the narrow edge of the flat head screwdriver behind the edge of the plastic screw covers located on the door pull as well as the rear of the door panel. Remove the Phillips screws located behind the covers with the Phillips screwdriver.
    • 2Insert your flat head screwdriver behind the plastic screw cover located behind the door release. Remove the Phillips screw from behind the cover with the Phillips screwdriver, then slide the door release handle forward and remove it.
    • 3Insert the panel tool behind the front of the door's upper edge to pry out the triangular piece of plastic located there.
    • 4Pry around the edges of the door panel with the panel tool until the panel is loose.
    • 5Lift upwards on the door panel to slide it off the door. Unplug any electrical connectors that are plugged into the back.
Oct 01, 2012 | Cars & Trucks
Dyson DC 25 power switch replacement
It a fairly straightforward procedure. Remove the accessory hose to expose 4 torx screws from behind that hold the front switch cover in place. After removing the screws, gently pull the front switch cover and carefully pry two plastic tabs apart using a small screwdriver that "snap" cover in place. The switches will be exposed. The electrical connectors each have a tiny lock button at the base of the terminal that you need to push to remove. Otherwise they won't pull off easily. Assembly is reverse with one note: You'll have to hold the plastic cover and push buttons together so they don't fall out as you place the the cover back on. Once you get it on, the plastic tabs will hold until you install the torx screws. Be sure to retest the push buttons to make sure there was no binding in reassembly.
If I may add one more thing- I believe all DC25's carry a 5 year warranty and switch failure is covered. I replace these routinely. If you call Dyson, they will likely refer you to an authorized repair center for replacement at no charge.
Regards
Feb 16, 2012 | Vacuums
The window on my 2004 Ford F-150 fell into the door. How do I take the door apart to put the window back on track?
There are usually screws holding the door panel in place. Look around the edge of the inner door panel for any screws. There are also some screws under the arm rest on the door. Any items that penetrate the door panel must also be moved out of the way or removed (like window cranks).
Once you get all screws and obstructions out, the panel moves away from the door and lifts up and away. You may find that the window didn't come off track, but you may need to replace some parts as well.
Gary
Aug 09, 2011 | 2004 Ford F150
How do you change out door switch that controls inside lights on a viking frig DDBB363Rss
If the unit doesn't have an exposed door switch(on the control panel), than the switch is on top of the door hinge and if that's the case contact your distributor because the unit might fall under a hinge recall which will also fix the door switch.
Jan 06, 2011 | Viking DDBB363 Bottom Freezer Refrigerator
How to remove door panel on a 1985 cadillac eldorado
Very easy! One tool that will save you a lot of headache and anger can be bought at any auto parts store and looks like this:
You use this tool to pop loose the plastic fastners that are attached to the door panel edges.
But first, remove all screws...remove the door handle cup, pop loose the master door/window stich assmbly, etc. Very simple process....takes less than 10 minutes.
Door Panel
  1. Remove all door inside handles.
  2. Remove the door inside locking rod knob.
  3. On styles with door pull handles, remove the screws inserted through the handle into the door panel.
  4. On styles with remote control mirror assemblies, remove the remote mirror escutcheon and disengage the end of the mirror control cable from the escutcheon.
  5. On styles equipped with switch cover plate in the door armrest, remove the screws securing the cover plate, then disconnect the switches and cigar lighter, if so equipped, from the harness connectors.
  6. Remove the remote control cover plates and remove the exposed screws securing the cover plate to the door inner panel.
  7. On styles with integral armrest, remove the screws inserted through the pull cup into the armrest hanger support. On some styles it may be necessary to remove the screws behind the armrest deflector or courtesy lamp remote control cover plate. On styles with armrest applied after the door trim installation, remove the armrest to door inner panel attaching screws.
  8. On styles with with two piece trim panels, disengage the retainer clips at the front and rear of the upper trim panel. Remove the upper trim panel by lifting upward and sliding slightly rearward to disengage the the front door inner panel at the beltline.
  9. On styles with electric switches located in the door trim panel, disconnect the wire harness at the switch assembly.
  10. To remove the lower trim panel, remove the attaching screws along the upper edge of the lower trim panel. Then starting at a lower corner, insert a pry type tool between the door inner panel and the trim panel and disengage the retaining clips down both sides and across the bottom. On styles with courtesy lamps or reading lamps located in the trim panel, disconnect the wire harness at the lamp assembly.
  11. On styles with one piece trim panels, remove all the clips around the perimeter of the trim panel. Push the trim panel downward and outboard to disengage it from the door inner panel at the beltline. Disconnect any courtesy lamp wire harnesses, if so equipped and remove the trim panel from the door.
  12. Installation is the reverse of removal. On styles with adjustable trim supports at the beltline, the door trim panel can be adjusted in or out so as not to restrict door window operation
May 08, 2010 | 1985 Cadillac Eldorado
Can you explain how to replace the light bulb in my amana oven?the model number AARG7303WW
This worked like a charm ... actually it's easier than you might think. Just a few screws and a few tugs. Give it a shot.. I found a 10W (G4 style ... you'll see the difference when you get to the store) replacement bulb at Home Depot for $6:
1) Turn off power to the unit
2) Open the lower oven door
3) Remove the side trim screws and pull the trims down and out.
4) Remove 2 screws on the sides of the control panel.
5) Open the Microwave door. Remove the 3 screws on the Air Vent Plastic Cover on top of the microwave. You can then remove the Air Vent Cover by pushing the control panel up and pull out slightly at the bottom.
6) Remove the 4 screws on the Air Vent Plastic Cover on top of the lower oven and remove the Air Vent Cover. (You may have to remove the left under side bracket of the Microwave door temporarily just for the Air Vent Cover to clear the screw of the bracket. Re-secure the side bracket of the Microwave door panel as the front panel may fall)
7) Remove the 2 screws which held the Microwave unit in place behind the Air Vent Cover on step 6.
8) Wiggle the Microwave unit out about half way to expose the light bulb unit on top center
9) Wiring to the Control Panel will prevent you from pulling the Microwave unit out any further. And you don't want to do that as the unit may fall. Space is cramped, but working carefully with your fingers or pliers you should be able to release the springs which held down the light bulb unit and change the bulb.
Feb 14, 2010 | KitchenAid KEMC378KSS Electric Double Oven
How to replace window switch on 2002 taurus
A Chilton's manual will show you how to take the door panel off, but here's the overview:
1. Remove screw inside the door handle.
2. Remove the speaker cover (2 screws).
3. Use a trim tool or small flat prybar to pull out the plastic pushpins all the way around the door (about 12). They can be reused once, but after that they tend to fall apart. A box of them is pretty cheap at Fastenal or some car parts / car stereo stores.
4. Lift the door panel up and out, then disconnect the wiring harness.
There's your switch. But if all your power windows aren't working, then the switches are probably fine, and you might want to replace your battery instead.
I had a problem with my 97 Taurus where my passengers could not control their windows, but I could control them from the driver's door controls; and it turns out it was a bad battery. Apparently the Taurus computer tests the battery voltage while the car is being started, and if the voltage is too low the computer begins disabling accessories, like the power windows. (But it doesn't alert you, say, by turing on the Check Engine light.) It also was affecting the remote control (key fob) operation, which is also fixed now.
So apparently if your battery ever falls below 10.0V, the computer freaks out and goes into "limp-home" mode, and begins shutting accessories off.
Check your battery with a voltmeter; if it's below 11.0V in the morning with the engine off, or below 10.0V while cranking the engine, I'd try getting a new battery.
Sep 11, 2009 | 2002 Ford Taurus
Replace power window motor right side
I looked at one earlier and I believe that first obviously that you remove the inner door panel.There are screws all around the outer edge of door panel.Also there are two quarter inch screws that are above the handle in middle of door.Then you peel back carefully the water barrier that is stuck to door.You will see three holes in the centr of door.The screws are golden in color in those holes.I believe they are 9mm or its standard counterpart.You should be able to remove the motor by pulling straight back.Be careful because I believe once you pull it out the window will fall.I'm not sure.Unhook wire connector and reinstallation is reverse of removal.Good lick!!!!I haven't done one yet but I'm going to do one in a bit on a 2002 saBLE.My email is ctate2@stx.rr.com if you have any questions.I don't know much but I can help people with alot of things every once in a while.I hope you get it going.
Jun 10, 2009 | 2003 Chevrolet Venture Passanger
How do i change light bulb for my oven
Here is a simpler method from the same website mentioned in solution #1:
9) Wiring to the Control Panel will prevent you from pulling the Microwave unit out any further. And you don't want to do that as the unit may fall. Space is cramped, but working carefully with pliers you should be able to release the springs which held down the light bulb unit and change the bulb.
By the way, the bulb is Osram 64405S. It's available online for about $2.00 plus shipping.
See more info. at: http://www.howtomendit.com/answers.php?id=51232
Mar 13, 2008 | KitchenAid KEMC378KSS Electric Double Oven
Dishwashers Logo
228 people viewed this question
Top Dishwashers Experts
