Question about BenQ FP767 17" LCD Monitor
BenQ FP767 17" Power but no display?
I dont have the frequent power surges from previous post so it is no help to me. other monitor works the one im currently using compaq crt 12" omg lol. any way when i turn the system on the benQ green light blinks on and off but no display even if i turn it off then back on, its not the gcard and it appears that there is power getting to the benq is it broke or a technical fault?? thanks for anyhelp that you can give.
  • sdhuper Dec 24, 2007
    Same problem here. No display even though power light is on. Sometimes see a faint image but no backlight
  • ScorpionNL Mar 26, 2008
    i have BenQ FP767 17" LCD Monitor wel Power but no display wat is the problem? i think so "backlight" defect is? My question is how to get where to get backlight?.
    My e-mail:scorpion67nl@yahoo.com
  • 472 Answers
Different faults here.
First fault is no power, it is bad capacitors on the power board.
Second & third faults are the inverters. (power but no image visible, but feint if you shine a light into the screen)
Check the 4 transistors on the main power board for shorts.
If you are unsure what that means, then take it to your local TV technician, he should be able to solve it fairly cheaply.
Hope that helps.
Posted on Apr 09, 2008
Displaying only 2 secs
Monitor STFC (Self Test Feature Check)
* Turn off the monitor
* Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
* Unplug the monitor video cable from the back of the computer
* Turn on the monitor
* The floating dialog box should appear on screen against a black background. If the issue appears during the STFC, the monitor is defective. Get it replaced.
Oct 31, 2013 | BenQ Computers & Internet
Benq q5t4 monitor. power on "BENQ" display is
i want data for benq q5t4 moniter eprom 24c04 ic my moniter is not working properly
Dec 17, 2010 | BenQ FP51G 15" LCD Monitor
I have a BenQ FP71G+ monitor and the auto adjust message pops up frequently and the screen adjusts itself.
radioactivet, A qualified technician will need to investigate the units "switch-mode-power-supply" for typical "faults" and locate the faulty (bad) component(s) that ma be causing monitor to act this way. "Noise" on the +5 volt DC rail going to the vga/lcd interface (processor) may be why display is acting "strange" with uncalled for pop-up's appearing!! That's the very first place I would investigate when dealing with ANY COLD-CATHODE-FLUORESCENT-LAMP, BACK-LIT LCD DISPLAY. 12fixlouie
May 31, 2010 | BenQ FP71G 17" LCD Monitor
No display
BenQ made a lot of monitors for Dell. You may want to look at Dell pictures.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 11, 2010 | BenQ FP757-v2 - 17" LCD Monitor
Benq E2200HD No Cable Connected!
mnk1001, Possible Failure of internal "switch-mode-power-supply"/ "CCFL inverter supply" of E2200HD. Will need to investigate to see if SMPS is in emergency shutdown mode. Please post back if you find out root cause of failure. 12fixlouie
Apr 08, 2010 | BenQ E2200HD Monitor
BenQ fp737 monitor
Disconnect the signal cable from CPU and power on.You should get a BenQ Blue screen.
If no Display,Problem is definitely monitor related ie monitor has a hardware defect most probably the power/invertor board has a few blown components.
If you are technically able,you can dismantle monitor and check components on the Invertor board which you may find on my other posts.
Please reply if you need more help.Please rate this solution.
Thanks.
Samir
Aug 25, 2008 | BenQ FP737S-D 17" LCD Monitor
Can't find video signal
If screen says "Signal cable not connected " all the time till power led switches to Amber chances are monitor is ok and problem is with graphic card or cpu.Connect to Known working CPU and confirm that monitor is the problem.
If same problem persists on another working cpu after changing signal cable,the interface board in the monitor could be defective.
Samir
PLease rate solution and provide feedback.
Jun 09, 2008 | BenQ FP731 17" LCD Monitor
BenQ FP71G+ screen blank
If front power led is on and No display ,Problem is with Inverter circuit.The post u descibe should help you determine with certainity that Inverter is the issue.
Samir
Apr 08, 2008 | BenQ FP71G 17" LCD Monitor
Benq t701 flat screen no display
see this post
http://www.fixya.com/support/t155971-benq_t701_lcd_monitor
Apr 15, 2007 | BenQ T701 TFT 17" LCD Monitor
BenQ FP767 17" LCD Monitor Logo
1,772 people viewed this question
Top BenQ Computers & Internet Experts
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
