Question about Kenmore Elite 20972
Did i loosen the belt or break the belt ?
I think i caused this problem myself, i put a too large comforter in to wash and it fit without a problem, but in the cycle the noise started, the spinning/rinsing cycle continued but with clicking noise...and a slight hot smell...please help sooooooon... what could be the cause of this ? is the belt loosened by this?
    President:
  • 878 Answers
Toso, If your model number starts with 110, you don't have a belt to worry about. This is a direct drive washer. The clicking noise could be any number of things such as; something passing through the pump, something under the agitator or something caught in between the basket and tub. The hot smell could be the motor getting hot from the load. It's really hard to tell without being there, but it doesn't sound to serious...Catriver...post back.
Posted on Oct 11, 2006
Removal of Fan on 1999 Chevy Tahoe
If your talking about the fan on the water pump,, 2 ways,,, pair of needle nose vise grips and clamp the pulley from behind so it cant turn then use the proper size wrench to loosen the large nut CCW,, i think its a 32mm. Or if you have access to a hand held air hammer with a flat chisel head put it on the egde of the nut to loosen,, this works great,,all it takes is a second to break it loose,,,, leave the belt on while loosening to hold the pulley using this method,, you can also leave the belt on using the vise grips to ,,but you might have to replace the belt if you damage it,, wrap a little black tape or somthing simular around the vise jaws
Sep 27, 2014 | 1999 Chevrolet Tahoe
How do you release the tension bolt to fit the belt on the washing mashine
To fit the belt it is not necessary to release the tension bolt. To remove the belt use a long screwdriver. Put it between the belt (sideways) and the large wheel, lever the screwdriver to outside while moving the wheel in clockwise/anticlockwise depending upon where you put the screwdriver at left/right side. Reverse the procedure for putting the belt on the wheel. While putting the belt first fit it on the motor pulley.
sonsunny
Jun 30, 2011 | Washing Machines
How to put a belt put back on
Your washer does not have a belt. It has a drive couplerthemobilian_1593.jpg
This dude mounts between the tranny and the motor
Number 13 s pictured here
So what went wrong?
Overloaded washer/comforter/rugs
low water/large load
worn coupler
all of the above causes this:
This is NOT a hard fix if yall know the trick.
Video how to:
I have a manual and more HERE
I have a blog featuring these washers HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 26, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
I put my comforter in the washer on slow and large wash, but it stopped after about 5 minutes and water had flowed out. what do i do now?
Never wash a comforter in your home machine. Laundry mat is where you was that one. A comforter will break the drive coupling. This video shows how to replace that drive coupling. Note: For a more precise answer you need to post your model number.
Nov 27, 2010 | Kenmore Washing Machines
How do you remove water pump on 1995 Buick Century?'
I think most (if not all) 95 Centurys had a 3.1. Specifying engine size allows for a more specific answer to your question.
To remove the bolts from the pulley, first put the belt back on. With the belt on, you may be able to unscrew the pulley bolts. If the pulley still spins, you can try rotating the tensioner in the 'tighten' direction to get a better hold.
What I do to remove pulley bolts:
With the belt on, I get an open-end wrench 2 mm larger then the bolts.
I place the end of the wrench around one bolt. It will fit very loosely. I then use a ratchet and 6 point socket on a different bolt to turn the pulley counterclockwise until the handle of the open-end wrench contacts another bolt. Holding the wrench firmly, I use the ratchet to loosen the bolt it's already on just slightly, not more than a quarter turn. I then move the wrench to the next bolt until all bolts are slightly loosened. A second pass with just the ratchet and no open-end wrench then loosens the bolts one full turn. I remove the belt at this time and then fulley remove the pulley bolts.
If and of the water pump mounting bolts are stuck, do not apply excessive force and break them off. Instead, reinstall the pulley and belt. Then fill the cooling system completely and allow the engine to idle for about 15 minutes or until it is fully warm. You can now remove the belt and pulley, drain the coolant, and safely remove the stuck bolts without breaking them.
Sep 27, 2009 | 1995 Buick Century
I need to replace the belt
You shouldn't have to remove the pump to replace the belt. The motor mount can be loosened and the motor moved so the belt will fit over all pulleys without removing the components.
Loosen motor, move it in, install belt, move motor out to correct belt tension, tighten motor mounts.
May 28, 2009 | Amana 3.2 cu. ft. Top-Load Washer
How do you install a new belt? its hard to fit around !!
Youmust loosen the motor bracket bolts and this will allow the motor to swing. Put belt on the motor pulley and feed the belt onto the large drum pulley and at the same time turn the drum pulley so that the belt pulls onto the pulley groove. Put some tension on the motor to tension the belt - not too much tension though. Holding the motor & belt tension, tighten the motor bracket bolts - job done. Should take no more than twenty minutes to complete.
Apr 14, 2009 | Washing Machines
How to put the belt on,
there is no way of tensioning the belt so it is a very tight fit
put belt round motor pulley first then start belt on large pulley and turn large pulley by hand and it should go on
Jun 24, 2008 | Washing Machines
TROUBLE FITTING NEW BELT
i put the belt on large wheel then with a large Phillips screwdriver
though a socket slightly larger than the motor wheel put the belt around the socket on the screwdriver and put the driver in the small
hole in end of the motor wheel,lever the belt and slide the socket with the belt on down to the wheel ,push the belt over the socket onto the
motor wheel this my take 5-6 atemps but ive done it about 5 times
Feb 05, 2008 | Washing Machines
Washing machine
you shouldnt have to loosen it, if you put the belt on the motor first then onto the pulley, using both hands (one to keep belt on pulley the other to work the belt around) it should go on pretty quickly, maybe tight though.
hope this helps
kj
Nov 07, 2007 | Miele Touchtronic W1113 Washing Machine
Washing Machines Logo
95 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
