Question about Sansui VRDVD4000 DVD Player/VCR
Change clock need to change clock from daylight saving time
How do I change the time on my sansui vrdvd4000 dvd player / vcr combo
Posted on Nov 25, 2008
  • 4 Answers
To change the clock select vcr mode(the vcr light comes on), then press "vcr menu". Press left or right arrow buttons to select system set up and press enter. Press left or right arrow buttons to select clock set and press enter.
Posted on Mar 08, 2011
How to set time
Plug in the unit.
First, the month and date appear, then the
year, and then the current Eastern Standard/
Daylight Time appears in the display.
Press
TIME ZONE
Area number "2" appears in the display.
If you live in the Eastern Time zone, you do
not need to adjust the area setting.
Area number
Time zone
Atlantic Standard/
Daylight Time
(default)
Eastern Standard/
Daylight Time
Central Standard/
Daylight Time
Mountain Standard/
Daylight Time
5
Pacific Standard/Daylight
Time
6
Yukon Standard/Daylight
Time
7
Hawaiian Standard/
Daylight Time
Press
TIME ZONE
repeatedly until the
desired number appears.
The display returns to the clock about 4
seconds after the operation is complete.
Note
During the shipment and your first use, a clock
error may occur. In this case, refer to "Setting the
clock and date" to set the correct time.
When daylight saving time
(summer time) begins
This unit employs Automatic Daylight Saving
Time/Summer Time adjustment. The DST
indicator appears in the display at the beginning
of the daylight saving time (summer time), and
disappears at the end of it.
Daylight saving time begins at: 2:00 AM on the
second Sunday of March.
Standard time begins at: 2:00 AM on the first
Sunday of November.
To cancel the automatic DST/summer
time adjustment and to set DST display
manually
The automatic DST/summer time adjustment can
be cancelled.
Press and hold
DST
for at least 3 seconds while
the clock is displayed.
A beep sounds, and "Aut
OFF" appears in the
display to show that the automatic DST/summer
time adjustment is cancelled. The display returns
to the clock.
Notes
Daylight Saving Time depends on the law in
each country/region, and your area may not use
it. In such a case, cancel the automatic DST/
summer time adjustment before using the set
and set the time manually as necessary.
To activate the automatic DST/summer time
adjustment again, press and hold
DST
for at
least 3 seconds. A beep sounds, and "Aut
On" appears in the display to show that the
automatic DST/summer time adjustment is
activated. The display returns to the clock.
To change the display to the daylight saving
time (summer time) manually, see "To change
the display to the daylight saving time (summer
time) indication."
Setting the clock and
date
To change the setting manually, follow the
procedure from step
Press
CLOCK
for at least 2 seconds.
You will hear a beep and the year will start to
flash in the display.
Press
or
until the correct year
Press
CLOCK
Repeat steps
and
to set the month,
day and time.
After setting the time, two short beeps sound
and the clock starts from 0 seconds.
Pressing and holding
or
changes the year,
month or day rapidly.
When setting the current time, time changes
rapidly by 1 minute-increments up to 10
minutes, and then by 10 minute-increments.
While setting the clock, you must perform each
step within 65 seconds, or the clock setting
mode will be cancelled.
To display the year and date
Press
SNOOZE/DATE/SLEEP OFF
once for the
date, and within about 3 seconds press it again for
the year.
The display shows the date or year for about 3
seconds and then changes back to the current
time.
If you connect the AC plug to an AC outlet while
this unit is powered from the backup power
source, the current date and time appears in the
following order (the same as when the unit is
powered on after a power interruption).
"month and date" (about 1 second)
"year"
(about 1 second)
"current time"
saving time (summer time) indication
Change the daylight saving time (summer time)
adjustment setting according to the following
procedures if you have cancelled the automatic
DST/summer time adjustment.
Press
DST
The DST indicator appears in the display and the
time indication changes to the daylight saving
time (summer time).
To deactivate the daylight saving time (summer
time) adjustment, press
DST
again.
May 24, 2015 | Sony SY-ICF-C414 Clock Radio
HELLO MY CLOCK DID NOT DO AUTO DAYLIGHT TIME HOW DO I FIX THE TIME TO ADJUST TO ONE HOUR A HEAD THANK YOU INGER WELCH
All you need to do to advance your clock an hour for daylight savings time, is hold down your clock button without letting it go. Then press your hour button once and you should be all set.
Most clocks that are older than when they changed the date of daylight savings time will either not change it for you on the right day anymore. Or they don't have that feature in it.
If yours does have an automatic daylight savings feature...you may find it helpful to take it off "automatic" and just change it manually from now on. That's what I do with my VCR. It has an automatic daylight savings time feature, but it's useless now that they have changed the date when we set our clocks for DST.
Some manufacturers will give you instructions on how to change the feature settings so your product will again work correctly for you. But not all will or can. You can look it up at your manufacturers website to know for sure.
Good Luck...and I hope this helps you.
Mar 13, 2011 | Vacuums
My clock went back one hour on Sunday 10/25, need to get it to move ahead one hour.
The clock program for Daylight savings Time is programmed for the old "third Sunday in October" changeover. The new changeover is the first Sunday in November. The program probably cannot be updated. If there is no button or setting to disable automatic change to Daylight Savings Time you can set the time manually and then change it manually to Daylight Savings on November 1 for the time to be correct.
Oct 26, 2009 | Emerson Smartset Clock Radio
Wrong Time
This appears to be a issue with the Magellan code. The Magellan code is setting Daylight Savings Time according to 2007 rules and not the 2008 rules. Magellan support indicates to change the time zone from Eastern to Central, save it and then put the time zone back to Eastern Time. I do not understand this solution. You can simply uncheck the Daylight Savings Time option and this will put the clock to the correct time. You will need to check the Daylight Savings Time option to put the clock ahead one hour when the clock is off by one hour. Magellan support informs me this is a manual process. Magellan needs to create a fix in their firmware to change the clock according to 2008 Daylight Savings Time when the box is checked.
Oct 23, 2008 | GPS
Emerson Research SmartSet Clock Radio
There is a solution for this already. You can reprogram the clock to use the new DST settings.
See http://www.fixya.com/support/t137304-daylight_saving_time_issues
Mar 10, 2008 | Emerson SmartSet CKS1850 Clock Radio
Daylight saving time problem
Sorry it took so long to reply to your questions about the change for the new daylight saving standard. The following link will take you to the customer support page for Emerson Radio. This page contains the directions for making the all the proper changes to you Clock/Radios. You will need a pdf reader and writer to read the information and make a copy for your records. [http://www.emersonradio.com/owners/SmartSet%20Series/DST%20Information.pdf] Copy this link and paste it into the address bar of your web browser. I hope this information helps you solve you problem with new daylight saving changes to your Clock/Radio. Thank you for using FixYa and have a nice day!
Mar 09, 2008 | Emerson Smartset Clock Radio
There was a sheet of paper that came with my clock explaining how to adjust the daylight savings time settings, but I lost it.  Anyone have theirs?  All i know is it requires that you press an awkward combination of buttons simultaneously, but that's it.
Nov 06, 2007 | Zenith Z230S Clock Radio
Daylight saving time auto change over
call 18006954820 they will walk you through
Nov 02, 2007 | Timex T276B Clock Radio
Turning daylight saving time OFF
If DST is *already* set to "on" when you reset the time zone to Z-07 (Hawaii), my very recent experience is that the time *still gets adjusted back* by one hour.  Now that daylight savings time is over (at least according to the clock's pre-programmed and outdated schedule) I'm hoping that setting the time zone to Z-07 (Hawaii) will completely cancel the automatic time changes from now on.  Otherwise, I need to purchase another clock, and it won't be a Timex.
Apr 02, 2007 | Timex T311T Clock Radio
Sansui VRDVD4000 DVD Player/VCR Logo
273 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
