My toshiba Satellite A135-S2386 laptop is not turning on for last few days......i recently upgraded ram ...from 256 to 2G ....i used one 2G PC2-5300 module in the bottom slot..it was running just great after that.
i found out later that recommended memory for this laptop is PC2-4200 and its better to use a kit (1G each slot)
could it be the problem ????
i have tried all the tricks from here.....like removing battery ....holdind on/off switch for several seconds....etc etc...
thanks in advance
The right memory for your laptop is
256MB Memory (PC2-4200) KTT533D2/256, PA3389U-2M25 KTOS534
512MB Memory (PC2-4200) KTT533D2/512, PA3412U-1M51, PA3412U-2M51 KTOS535
1GB Memory (PC2-4200) KTT533D2/1G, PA3411U-2M1G KTOS536
Using the wrong memory can caused motherboard failure.
Try reinserting the old one memory module.
Be sure that the memory is placed in the right way
thank you for your response :-) i tried old ...original 512MB memory but it still refuse to start ...
i tried ....and then i called toshiba support center....
have to take it to repair shop....thanks :-)
