Question about HP Computers & Internet
Doing siytem restore,and have no operating system.Vista home premium model no s 3460 sofware build 82APv3PrA1.Im under warranty what can i do?.In the start of system restore computer stopped,message reeds no O S.
  • Igorot May 11, 2010
    Bro can you tell me how many Hard Drives you have? If you have 2, kindly set your hard disk priority to the hard drive that has the OS was installed. You can determine this by checking if it's C: or by opening your Systems unit and checking what cable is attached to IDE 1 or SATA 1. If you see that the cable is attached to a hard drive then that is automatically your HDD that contains your OS. Go back to your CMOS and set it to that HDD. Save your settings by pressing F10 then let it boot. Ifyou are able to enter your windows then you are OK. Reboot your computer but before the windows comes out, continuesly click F8 then go to safe mode. If you are in safe mode, then you can choose to system restore to the date of your choosing. I have a suspicion that your computer was infected with a virus called autorun.inf. I hope i was of help.... good luck bro ... Good Day !!!
  • 749 Answers
Starting the recovery from power up If Windows Vista cannot open and if the Recovery partition on the hard disk drive is functioning properly, you can perform a System Recovery by performing the following procedure:
  1. Turn off the computer.
  2. Disconnect all connected devices (such as the Personal Media Drive, USB drives, printer, and fax), remove media from drives, and remove any recently added internal hardware. Do not disconnect the monitor, keyboard, mouse, and power cord.
  3. Turn on the computer.
  4. Do one of the following actions depending on how Windows Vista was installed:
    • If Windows Vista came pre-installed on your computer, press the F11 key repeatedly when the first screen opens (the logo screen), until Recovery Manager program opens on the screen.
    • If your computer was upgraded from Windows XP to Windows Vista, press the F10 key repeatedly when the first screen opens (the logo screen) until Recovery Manager program opens on the screen.
    If Recovery Manager does not open, a set of recovery discs is needed to perform a System Recovery. Follow the instructions listed in Starting the recovery from recovery discs .
  5. Click Next .
  6. On the screen that prompts for Microsoft System Restore select No , and then click Next .
  7. The Recovery Manager gives you the option of backing up your data files. Backing up your files is recommended. To back up your files select Yes , and then click Next . Follow the onscreen instructions. If you do not want to backup your files, select No , and then click Next .
  8. After the System Recovery is complete, the computer restarts and continues into Windows setup. Complete the setup screens and wait until the computer finishes the setup. Then, turn off the computer, reconnect all peripheral devices, and turn on the computer.
  9. Before using the computer, update and protect it by reinstalling any virus and security software that was installed before the System Recovery.
  10. Reinstall any software applications that were added after puchasing the computer, and replace any files that were backed up.
Posted on Nov 06, 2008
  • Jeff Strader
    Jeff Strader Nov 06, 2008
    Use the following steps to recover the computer from a set of recovery discs (either CDs or DVDs):
    1. If the computer is on, insert the recovery disc labeled #1.
    2. Turn off the computer.
    3. Disconnect all connected devices (such as the Personal Media Drive, USB drives, printer, and fax), remove media from drives, and remove any recently added internal hardware. Do not disconnect the monitor, keyboard, mouse, and power cord.
    4. Turn on the computer. The computer opens the Recovery Manager program.
    5. By default the Recovery Manager will be set to run a System Recovery from the inserted recovery disc. Click Next .
    7. The Recovery Manager gives you the option of backing up your data files. Backing up your files is recommended. To back up files, select Yes , and then click Next . Follow the onscreen instructions.
    9. Before using the computer, update and protect your computer. Reinstall any virus and security software that was installed before the System Recovery.
    10. Reinstall any software applications that were after puchasing the computer, and any files that were backed up.
    I'm doing a system restore in Vista home premium and every time i choose a restore point and start the restore it'll go for bout 2-5 minutes then suddenly it'll go to a blue screen VERY fast and says...
    Instead of rebooting to safe mode select the option for "Last known working configuration"
    Once windows boots to this, presumably working setting, attempt to restore to your desired point again.
    If that fails yet again you may opt to restore to a point further back in time if this is a possibility.
    If these do not solve the issue please feel free to clarify the problem, why these solutions did not resolve your issue and we will be happy to assist you further.
    May 04, 2011 | Microsoft Windows Vista Home Premium...
    Window vista home premium stop working after installing updates??
    You can restore your system to an earlier point to avoid the updated vista.
    To do so: 1.Type "restore" in the search field of your START MENU, 2.Click on SYSTEM RESTORE 3.Chose a suitable restore point , before your vista got updated. 4.successfully complete the system restore and restart.
    When you restore your pc to an earlier point, updates are cancelled and in this way you can avoid the updates.
    Click this for more information
    Dec 11, 2010 | Microsoft Windows Vista Home Premium...
    My Graphics card wont support Pixel Shader 2.0 or even 1.1
    Try update your system to "Vista home premium x64bit sp1" and update your DirectX to DirectX10, and see any changes.
    Jul 24, 2010 | Microsoft Windows XP Home Edition
    My microsoft word would not open
    try to perform system restore, it will restore your computer settings back to an earlier date. Here is the link where you can find the steps in performing system restore in windows vista: http://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/
    Jun 11, 2010 | Microsoft Windows Vista Home Premium with...
    I lost my laptop log-in running Vista Home Premium
    http://technofriends.in/2008/11/17/how-to-track-a-stolen-laptop/
    Plese check if something could help, if you have another desktop or a laptop that you can track the laptop that you have lost by installing the sofware and run it and check if you can retrieve it.
    Whats is mac and winsdows sofware
    Apple's applications are calls Mac (Operating system) and Microsoft's applications are called Windows (Operating system)
    May 29, 2010 | Microsoft Windows Vista Home Premium...
    Vista aero crash
    Ok, in that case , Try doing system restore using the following link and restore your system to the date on which it was working fine.
    May 29, 2009 | Microsoft Windows Vista Ultimate Edition
    Reboot
    Hi again.
    You are not going to be able to recover the system without the CD as there is no recovery partition for that model Dell machine.
    You can purchase a recovery disk at minimal cost to yourself from here>>>>>>
    http://www.user-guides.co.uk/cddownload/Dell/DellInspiron/Dell-Inspiron-1521-Vista-Driver-Recovery-CD-Restore-Disk-155038.html
    I know this is not the answer you were looking for but this is the only option you have at this moment in time.
    Good luck and thanks for using FixYa!!
    Mar 24, 2009 | Microsoft Windows Vista Ultimate Edition
    Vista Home Premium crashed. Reloaded, www, graphics driver no-go
    I would try to use the System Restore feature, if you have not already. Choose a date prior to when it crashed on you and it should work.
    Mar 17, 2009 | Microsoft Windows Vista Home Premium with...
    Computers & Internet Logo
    156 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
