Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
F1 error code
This is unbelievable. This washer is 1.5 years old. I was told it was top of the line. I looked up to see what this error code is and I find out everyone is having the same problem. There has got to be something we can do. I have to Pause the washer and then start again. Sometime that works. Sometimes I have to switch it all the way to rinse and spin and go throught the motions there. I am calling tomorrow.......
    Genius:
  • 1,028 Answers
Replace control module under console
Posted on Nov 06, 2008
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    F1 error message comes on every time I start our washer after lid lock engages!
    THE PRINTED CIRCUIT BOARD IS BAD. DO NOT BLAME SEARS FOR THIS I SHOULD OF HAD A SURGE PROCTECTOR ON THE MACHINE. THIS may cost you like $250
    Oct 03, 2008 | Kenmore Oasis HE 27062 Top Load Washer
    F1 error code
    This is from a service bulletin. This may be of interest to you. I agree with you that fancy doesn't necessarily mean better. Anyway, I sympathize and hope this helps. Best wishes.
    CORRECTION:
    HE Top Load Washers
    Models:
    F1 Error Code
    WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
    MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
    Serial Numbers: CT01 – CU52
    There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
    that the diagnosis is correct and the proper repair is completed.
    A) Air leaks in the air pressure (switch/sensor) hose.
    a. Inspect the hose for cracks, pin-holes or loose connection.
    b. Replace the hose and harness assembly (W10058730) if it is compromised.
    B) Moisture in the air pressure (switch/sensor) hose.
    a. Inspect the hose for evidence of water.
    b. Replace the hose and harness assembly (W10058730) if water is detected.
    C) Lint or flashing in the air dome hose connection port.
    a. Inspect the air dome hose connection port for lint or flashing.
    b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
    the tub.
    D) The control needs to be replaced.
    a. Replace the control only after you have completed steps A – C above, and verified that there are no issues
    with the air pressure system.
    Aug 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    F-1 Error on Whirlpool Cabrio Top load
    Called 1-800-253-1301. Spoke to a woman named Valerie in customer service. She told me there was a quality issue associated with the F1 fault code and they would take care of the repair parts and labor at NO CHARGE!. My machine is 28 months old.
    Apr 06, 2009 | Whirlpool WTW6400SW Cabrio Washer
    My Whirlpool Washer Cabrio model# WTW6200SW has a F1 error (fault) code? Does anyone know what this is and how to clear/reset the code?
    Called 1-800-253-1301 was told by the Whirlpool agent that there was a quality issue associated with the F1 fault code. They would take care of parts and labor free of charge! My machine is 28 months old. Talked to a woman named Valerie.
    Mar 18, 2009 | Whirlpool WTW6400SW Cabrio Washer
    F1 error code on cabrio washer
    CALL 18002531301 AND TELL THEM YOU HAVE THE F 1 CODE PROBLEM. THEY HAVEN'T CALLED THIS A RECALL, BUT THEY ARE CALLING IT A CUSTOMER AWARENESS PROBLEM.
    WHIRLPOOL IS SENDING TECHNICIANS OUT NEXT DAY FREE OF CHARGE.
    T W
    Feb 02, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Call Whirlpool at 800-253-1301 in USA. There is a recall on this washer for the F1 code. Service call and parts are free. I just did it today.
    Jan 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    F1 error code
    Call and complain a lot. There is a class action lawsuit agaisnt whirlpool (whirlpool made the oasis) for this problem. It is a faulty control board. Some people have gotten sears to pay for the repair. Try that. good luck!
    Nov 19, 2008 | Washing Machines
    Washer problems
    Replace the computer yourself. takes 20 minutes very easy and part is about 150.00, I did mine.
    Jun 10, 2006 | Kenmore Oasis HE 27062 Top Load Washer
    Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
    Dan Webster
    Dan Webster
    Sal De
