Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Over tempature reset keeps beeping
On my Kitchenaid superba I have a problem with the over tempature reset button keeps beeping and I hit it and then it is silenced for a little while but then every couple of hours it starts beeping again. It is driving me crazy. Where do I go from here?
  • 1 more comment
  • soccerhead95 Dec 05, 2008
    I have the same problem. Where is the over temp switch???
  • Anonymous Dec 11, 2008
    On my unit, the freezer side appears to be working fine but a check of the actual temperature in the refrigerator shows its 50 degrees. I'm guessing its a problem with the air transfer unit which blows air from the freezer to the refrigerator. Can anyone confirm this is likely the issue?
  • jannicebat Dec 30, 2008
    the freezer stopped working and beeping sign dosent shut down. it keeps saying over temperature resset. i turn it off and it goes back on.
  • KitchenAid Master
  • 2,651 Answers
Its registering a warm temp, you reset it but when it checks again in 2 hours or so its still seeing a warm temp whichi s why the alrm is going off, id look at the contents of the refrig for signs of defrosting, icecream not hard enough, ice maker not producing and melting, moilk spoiling premature, butter too soft.
Posted on Nov 06, 2008
Just got error code "fe02"
The F2-E0 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F2-E0 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced . GENE
Sep 18, 2011 | KitchenAid Ovens
My beep quit! Beep used to work when the oven came up to temp, the timer timed out, or a button was touched. Can it be reset or will I need to replace it? Where's the control board located and how do I...
We have a Kitchenaid Superba gas stove and the beeps would not sound. We thought the control panel was shot, but we have a WONDERFUL repair man. Here was his oven door, push the cancel button, push stop-time button and hold that button for about 5 seconds. When the beep sounds let go and the panel is re-set. WOW!!!!
Oct 23, 2010 | KitchenAid KGRT607 Gas Kitchen Range
Sorry, I have the same oven and the same complaint. The manual doesn't indicate anything. BTW- the service manual is inside the oven frame, between oven "lining" and the outside sheet metal.
Jan 03, 2010 | KitchenAid 27 in. Built-in...
Probe indicator beeping. Can't turn off.
there is a continuous beep on my oven and it says enter the probe temperature. I never used and would like to
Oct 09, 2009 | KitchenAid KGST307 Gas Kitchen Range
Over temperature reset button keeps ringing and blinking
I called the KitchenAid customer support number. Found out that control goes off when the temperature of the fridge is above 48 degrees (i.e., over a few days, the food would be spoiling). This is not the case for ours, since everything seems to be working fine. They said there is probably something malfunctioning with that button/control, and there is no manual turn-off mechanism. We have to call someone to come and fix it.
Jan 29, 2009 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Microwave/Oven, Microway Door message
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
Dec 20, 2008 | Ovens
Kitchenaid superba oven
Hit the options button and check that the "Sabbath mode" setting is off. I note that October 20th was a Tuesday but the internal clock year could be incorrect.
Oct 20, 2008 | KitchenAid Ovens
Kitchenaid superba refrigerator not keeping cold
press reset botton for five times and it will reset kiki
Oct 12, 2007 | Refrigerators
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
993 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
