Maytag Neptune not spinning - further help pls if you can
After looking at your solution for the Maytag Neptune noty spinning, i tried following:
(have a MAH4000)
- manually pressed the door-closed switch, and after having removed cover, manually triggered the 2 switches inside (1 just right-above of the wax motor, 1 right-above of the door-lock, so about4 inches right of wax motor). With this i had the full-spin, not only back-and-forth
- replaced the wax motor. now, no matter what i do, the wax motor never moves. So seems that the command to move the wax motor never comes.
Question: does that mean borad problem, or should i check fopr anything else first ?
Thx in advance
Charles
    Scholar:
  • 79 Answers
Hi Charles,
If your door latch wax motor actuator pin color matches the body color (brownish color) then you have the defective wax motor and it needs to be replaced. See www.neptunewaxmotor.com for step by step disassembly photos. Then, I would check the machine control board (located behind the timer in upper console) for a burnt resistor, R11 which is located near the left circuit board mounting slot. If the R11 is burnt you can try the STAGE 1 repair kit, which includes a new R11 resistor and Q6 triac and wax motor or you can purchase a new control board. Don't forget to unplug machine when servicing your Neptune.
You can try to solder the new R11 and Q6 into the machine control board as there is a video on the above mentioned site that shows you how to perform the R11 and Q6 replacement. Another option is to call local t.v. repair shops and see if they will replace the components for you for a nominal fee. I hope this helps
Posted on Nov 06, 2008
My maytag neptune washer has black residue on the seal. I have tried everything & nothing seems to take it off. I am now concerned that it is mold. Has anyone experienced this same problem?
Hi just read your posting.The black residue is most likely mould.I have seen it on a few front loaders.Have you tried the product called Mould off ?It helps on some machines.Worse case you might have to replace the door seal.Please reply for further help.Looking forward to your reply.
Jun 24, 2012 | Maytag Neptune MAH6500A Front Load Washer
Maytag neptune FAV6800AWW top load washer gets to 32 minutes left and goes no further. It starts to cycle for about 5 seconds and stops for about 35 seconds... over and over and over
Is the machine in Spin Cycle when this is happening? What part of the washer selected cycle does the Cycle Status LED say the machine cycle is in.
If it’s in the Spin Cycle I think you have a clutch issue. Do you take any error codes to the LED console display such as dC or uC?
If you stop the machine in that cycle and do a Spin Only cycle will it complete?
Do you want to DIY the fix? Let me know and I will try to help…..Rich
Feb 26, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune error code lr
i think this one is the one with the clutch. if it does it b4 it spins. put it on a spin. if it doesnt spin, u need a clutch. under the unit the belt is whapped on it
Feb 12, 2010 | Maytag Neptune MAH6500A Front Load Washer
My Maytag front load washer get a really loud noise when spinning at top speed but nothing seems to be wrong with it's performance what is the noise about?
remove the back panel ck under the tub for leakage / like brownwater deposits. it sounds like the rear seal has failed and water has interted into the brg . / there is no cheap repair for this . . pls leave feed back mm hope this helped .
Dec 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Neptune wont spin
Looks like I may have to post this as a solution to get the link to you. I never tried to put a link in a clarification request.
Click on this Forum. If that doesn’t work here is the link to paste in your browser.
http://www.fixya.com/support/p46844-maytag_neptune_mlg2000a_front_load
Jul 03, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Neptune frontloader washed accumulates water
replace water valve if its filling while not being used. if u hear the water in the tub but noty seeing it thats normal they water in them always. as far as mold u can buy some affresh its a cleaner for the frontloads
Mar 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500BWW Will not spin
maytag neptune washers do have a motor problem and they have a kit to replace the motor and motor controller.
when the motor fails, it wont wash or spin. most units have a 5 year parts warranty and should be replaced with a free part, but you will have to pay an authorized servicer to do this.
if it is over 5 years then i would call maytag and see if they will help you with an authorization for repair.
most of the time they will provide the part for free. just call the 800 # and ask for help. they wont send you the part but might give you some help with the parts.
Jan 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
468 people viewed this question
Top Washing Machines Experts
