Question about Tag Heuer 2000 CN1110.BA0337 Wristwatch
Problem w tag
Hi, i have a tag heuer f1 chrono black dial and cant seem to make it work right can u help?
  • Arturs Kalnins
    Arturs Kalnins May 11, 2010
    What exactly isn't working right?
SOURCE: Tag Heuer Formula 1 Mens watch
This is not a cheap watch....You should send it to a qualified watchmaker or the manufacturer. This watch has to have a pressure test to insure it's water tight. This may require replacement of some or all of the gaskets in the case.I would never recommend that this is something that you should try to do yourself.You would be amazed at the money I make do to improper replacement of JUST the battery.
Donald McPherson, Certified Watchmaker AWCI
www.finewatchmaking.com
WWW.AWCI.Com
Posted on Oct 25, 2007
indays
  • 111 Answers
SOURCE: early tag heuer professional 200m wrist watch
nice noon ! see for the correct position and press it to back on.thank you ! god bless !...
Posted on Sep 02, 2008
  • 161 Answers
SOURCE: My Tag Heuer sports watch
Hi Due to the high value of this brand of timepiece, it would be advisable to contact a reputable jeweler who sells the brand, and have them repair it.
Posted on Dec 10, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: looking for the user manual for Tag Heuer Aquaracer watch
They were just hiding it:
http://ww2.tagheuer.com/_documents/manuals/EI2252_en.pdf
-Tha Mp3 Doctor
Posted on Dec 31, 2008
escapement
  • 2334 Answers
SOURCE: I can't seem to set the time on my used tag heuer watch
Probably your watch has a screwdown crown and prior to attempt any settings you have to unscrew it. Some peoples fingers are stronger then others, so, try that with a pair of plyers. Cover your crown with a soft cloth and then grip with plyers(this will avoid any damage). Thread is right handed and unscrewing is done by turning the crown anticlockwise.
After setting the time don't forget to screw the crown back- it is for water resistance.
If you are unable to unscrew the crown, that means your watch is rusty and you will need watchmakers help.
PS If the watch is rusty, you can brake the crown off while trying to unscrew it. Don't panic yet, as in this case you will need a watchmaker anyway.
Don't forget to rate, please.
Posted on Jan 10, 2009
How to reset the chrono function of a Tag Heuer Aquaracer Calibre S CAF7113.FT8010 after a battery change
Pull the crown out to the first position, and then you may find that successive pushes of the upper pushbutton will move one of the chrono hands by one division, and the lower pushbutton will move a different chrono hand. Similarly if you pull the crown out to the second position, the pushbuttons will control the other chrono hands. In this way you can set each of the chrono hands to their zero positions. Hope this works..
Jan 17, 2014 | Tag Heuer Aquaracer Calibre S...
I cant get my minute and hour hands to zero out on my Tag chrono
If you haven't got the user manual, you can go to http://www.tagheuer.com/the-collection/link/men/quartz-chronograph/index.lbl?w=CJ1110.BA0576, where you will see a small menu on the right.
Click on "user manual" to download the instructions, which include the hand re-setting procedure.
Mar 20, 2011 | Tag Heuer cj1110.ba0576 Wristwatch
Need manual on operation of Tag Heuer ''Chrono'' watch . Leather band w/rose gold bezel.
I would contact Tag for this one. Most watch vendors will provide them at no cost. Be prepared to give them the #'s on the back of the watch to ID your watch.
Good luck.
Jul 23, 2010 | Tag Heuer Automatic Chronograph Series...
Describe your tag heuer CN1111 replacement bezel Problem: The bezel came off & was lost
YOU have to buy new one. Will be costly. Check out e-Bay. Cheapest prices are there.
Feb 23, 2010 | Tag Heuer 2000 Exclusive Qtz Chrono...
My Tag Heuer chronograph will not reset to zero.
Try the following, which I discovered by accident on my Tag Professional. Pull the crown out to the first position, and then you may find that successive pushes of the upper pushbutton will move one of the chrono hands by one division, and the lower pushbutton will move a different chrono hand. Similarly if you pull the crown out to the second position, the pushbuttons will control the other chrono hands. In this way you can set each of the chrono hands to their zero positions. Hope this works for you. Geoff
Feb 11, 2010 | Tag Heuer Aquagraph CN211A wristwatch
My alarm does not sound on my Tag Heuer Kirium F1?
Have you a copy of the manual?
If you have, then you will see that it can be turned off (last page), is this likely to be the case?
If you need a copy, go to their web site "tagheuer.com", select "watches", then "tag heuer formula 1", then "man", followed by "Tag Heuer F1 chronometer" and finally you will see on the right a menu, select "user manual".
This seems to be a generic manual that cover both the chronometer and alarm version of the watch.
If these are not the correct instructions for your watch, opposite the "user manual" menu is a search box, put your watch model in this and there should be a user manual with it.
If not look at a similar watch for a generic manual.
Jan 27, 2010 | Tag Heuer Kirium Formula 1 Chronograph...
I need a user manual for the Tag kirum Formula 1 watch
Go to the Tagheuer web site (www.tagheuer.com/)
Select "watches"
Select "Tag Heuer Formula 1"
Select "men"
Select "Tag heuer F1 chronometer"
On the right hand side of the screen you will a menu and the user manual is the last iten on the list.
Jan 03, 2010 | Tag Heuer Kirium (CL1212.BA0705)...
Hi there i have bought a second hand tag heuer carrera tachymeter,i dont have a user manual,but cant seem to get the chronograph functions to work ?
Great watch! Operation should be pretty straight forward. The top button starts the chrono and stops it. The bottom button resets it. To calibrate the sweep arm into the right position pull the crown out to the first or second set position and press the start button until the sweep arm is in the start position you desire. This is typically 12:00 or 0.
If your chrono is not working then have the battery checked. If the battery has been recently replaced then make sure the watch doesn't need to be cleared.
I recommend you take this to a watch maker/technician who will be familiar with the service requirements of this model including resealing and pressure testing the watch to be sure it is sealed to its marked water resistance specifications.
Thanks!
Sep 20, 2009 | Tag Heuer Carrera Series Chronograph Watch
How to set up time on TAG HEUER SLR CHRONOGRAPH ? what are the functions of the 2 boutons and 2 crowns ?
The crown at 3 o'clock is used to set the time and change modes. The crown at 9 o'clock is used to rotate the flange at the edge of the dial.
The A button at approximately 2 o'clock starts and stops the chronograph function. The B button at approximately 4 o'clock resets the chronograph.
Lap Timer: When the watch is displaying normal time, press the right side crown to switch to chrono mode (the hour hand will indicate CHRONO). This watch measures lap times, press A to start timing the first lap. Press A again to stop the first lap and automatically start timing the second lap (the hour hand will move to indicate you're on the second lap), and so on. You can measure up to 20 laps this way. When you're fininshed timing laps, press the right side crown to see the best lap time. To reset the lap timer, hold down B for 2 seconds. To switch out of chrono and see the normal time, just press the right side crown in.
Chronongraph: To time an interval that is not a lap, just follow the above instructions, but instead of pressing A to stop the first lap, press B and the watch will show the elapsed time to the nearest 1/100th of a second. Hold B to reset.
Crown at 9 o'clock: This crown rotates the inner flange at the edge of the dial and is used to measure total race time (i.e. the total of all the laps). Simply rotate the crown until the the little start trinagle on the flange is aligned with the minute hand. This way, the total elapsed time can be read at any time, similarly to how a rotating bezel works.
To set the time: Ensure the watch is not in CHRONO mode, if so, press the right side crown in. At this time pull the right side crown out until you feel a click.The position the second hand moves to indicates what is currently being set. If the second hand is at 9 o'clock, you are setting am hours, press A repeatedly to set am hours. Then press B and the second hand will move to 6 o'clock, pressing A repeatedly will set the minutes. So on for year (11 o'clock), month (12 o'clock), and day (1 o'clock).
Feb 25, 2009 | Tag Heuer SLR Mercedes Benz Limited...
Tag Heuer 2000 CN1110.BA0337 Wristwatch Logo
43 people viewed this question
Top Tag Heuer Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
