Question about Sony Playstation 3 (PS3) Console
Playstation 3 freezing
My playstation 3 keep freezing as soon as i turn it on help don't know what to do
  • 11 more comments
  • abacuzz Nov 07, 2008
    my ps3 doesn't show any of the icons on my hard drive or will sometimes just have the spinning discs on my game downloads. it freezes on the wave screen when i attempt to access my system settings. it also won't recognize any discs entered.
  • Anonymous Nov 07, 2008
    my ps3 froze on a loading point and i at to turn off by the main power at the back, since then it frezzes n it wont reject disk
  • day_football Nov 07, 2008
    my ps3 has froze at the loading point n since then it has froze all my games, sometimes it dont load disk or let me get the disk back out the ps3. is this data curruption?
  • rockersg131 Nov 07, 2008
    every time i turn on my ps3 either it stays at the wave background and nothing will come up. or the xmb will pop up but nothing underneath it will show up and i cant move. or everything will come up including the icons and i can move but as soon as i click on something it will freeze again and no games or movies will load. PLEASEE HELP!!!!
  • mswife02 Nov 24, 2008
    after about 25 to 30 minutes my playstation 3 freezes up and won't work anymore. it does this everytime i try to play it! i don't know why or what to do.
  • emir72593 Dec 12, 2008
    as soon as i turn on the ps3 and the menu comes up it freezes after i click x on the controler
  • Anonymous Dec 13, 2008
    My PS3 originally had disc reading issues.  Sony sent me a replacement no questions asked.  This PS3 last exactly 93 days then would not load past the initial wave screen.  How convenient that it is no longer covered under the warranty.  I will never buy another SONY product!
  • Anonymous Dec 15, 2008
    my ps3 keeps freezing everytime i start it up...it has like a greenish, purpleish color that appears all over the screen...basically everytime i cut it on i have to hope it works just long enough for me to get my music started because that's the only thing i can do now is listen to music...once i press play the screen freezes and the only thing i can do is listen while it plays in sequence...
    when i turn my console on, it wont leave the wave at the start up screen.
  • havard01 May 11, 2010
    PS3 is one of the most amazing gaming device but like other competitor
    gaming devices (Xbox and Wii) It also has some problems like Freezing
    up. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up
  • Wes Sydenstricker
    Wes Sydenstricker May 11, 2010
    The XMB is the Cross Media Bar. Thats the main menu.
    Your problem seems new to me. But when it says to reconnect your controller after taking it off of the USB cord, do you press the PS button in the center or no??
  • Wes Sydenstricker
    Does it fully boot up to the XMB?
  • Anonymous Mar 21, 2014
    it freezes and i am unable to do anything except turning it off.
All you need to do is replace the harddrive and/or reformat the current one which will require removing it and using a PC to reformat it if it will read. If not , simply replacing it will work I would recommend an upgrade at that point as well if you would like. I upgraded to 250GB when this happened to me. System works just fine now.
Posted on Jan 26, 2009
Alright i had the same problem all you have to do is call sony at 1-800-345-7669 and keep answering the questions and when they ask u if u want to hit 0 to talk to an operator do it. Once you talk them you'll need your receipt and they'll give you some numbers then they'll send u a box and u just put ur ps3 in it and send in to them
Posted on Nov 11, 2008
I have the exact same problem. I'll power on my ps3, and it'll say "sony home entertainment" and the wave loading screen just stays and never leaves. Nothing loads and no XMB. Funny thing is that I played a movie on a monday, turned everything off. Went to play on thursday and all of a sudden there's this problem :S any ideas?
Posted on Nov 08, 2008
What's the XMB gamer? No error code patriot.
I think i've narrowed down the problem. something about the siaxis controller and playing COD4 online. i was able to boot the system and access everything on my hard drive tonight after letting it sit unpowered for a day.i was able to load a downloaded game & play two different movies. I shut it down and restarted and no problems. my controller was fully charged so i disconnected it and when i began to play COD4 online the screen says "reconnect your controller". This is exactly what happened three days ago. plugging the controller back in does nothing, I tried resetting the controller while plugged in and no dice. and i can't connect with my other controller forcing me to turn the PS3 off by holding down the power button for 10 sec or so. restarting brings me back to the same problems. I remove the game and it doesn't change anything when starting up. shutting the rear power off and waiting for 30 minutes does nothing. Can it be something with COD4 online or is it some problem with the wireless siaxis controller?
Posted on Nov 07, 2008
  • abacuzz Nov 08, 2008
    it does load to the XMB although in different ways. sometimes it will freeze immediately and not allow you to move accross the menu. other times it will show spinning discs on my downloads in the game menu. it will freeze if i select something in the system menu.
    i've been able to turn it on after leaving it for day. played COD4 online for about 4 hours last night with the controller connected by the usb. when i went to quit the game the screen went black. restarting brought up the same issues described above.
    the controller issue seems irrelavant to the bigger problem, it just forces me to restart which is what causes these symptoms.
    Do you think retoring the default settings or even wiping the hard drive might help?
  • abacuzz Dec 18, 2008
    restoring the default settings ultimately fixed the problems.
Does it give you an error code??? 80010514 ??? good luck!!
  • jason gross Sep 20, 2013
    nope
  • Anthony Hogan Mar 09, 2015
    Does anyone kno wat to do I'll go to my account and then everything will freeze all I can see is my wallpaper and tha clock dis usually doesn't happen. Happend after turning tha system on and off multiple times
2 Suggested Answers
  • 31 Answers
SOURCE: playstation 3 freezing
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like Freezing up. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up
Posted on Mar 03, 2009
My ps3 keeps freezing during games
Problem: Your Playstation 3 console is freezing during gameplay. There are usually two problems that would cause your Playstation 3 to freeze during
gameplay. I will start with the most common problem:
1. The Blu Ray Laser is wearing out. This is a common issue among the newer video game consoles. The laser is constantly lighting up to read the discs while you are playing your Playstation 3 whether you are playing games, Blu Ray movies, or DVD movies. Eventually the laser will burn out. As it starts to wear out, first the games or movies will freeze. After a while, it will not read Blu Ray at all. Finally it will quit reading anything. You can find lasers at the following website starting at $49.95. The same website also performs repairs of the Playstation 3 console:
http://store.richspsxparts.com/pl3paac.html
2. Overheating. This is less common. If your PS3 freezes and you shut it off and back on and it comes on ok, it's probably not overheating. If heat is the problem, it will freeze right away if you turn it back on right away without giving it time to cool off. If it turns on OK with no problem and doesn't immediately freeze up, the laser is your issue. If you turn it back on and it freezes right away, your PS3 may be overheating.
If your PS3 is overheating, the best thing to do is to make sure you do not keep it in an enclosed area. Playstation 3 systems and XBox 360 systems run very hot. You must keep it in the open so it gets as much cool air as possible! You can also upgrade the fan inside of your Playstation 3 with the Whisper Fan which increases cooling. You can also find it at the following website:
http://store.richspsxparts.com/newpl3ps3taw.html
Apr 19, 2011 | Sony Playstation 3 (PS3) Console
Keeps going back to defult settings
Since your Playstation 3 is not loading properly then most likely you have corrupted data on your hard drive. The link below will help you address this. If you still have trouble then you have a more serious hardware problem.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Jul 11, 2010 | Sony Playstation 3 (PS3) Console
I have a playstation 1 game that i play on my 3,
Yes, GameStop and EB games both sell an adaptor you can buy, I believe it's around $20 that allows you to save and copy your data from the PS3. I have Gran Turismo 3 and I had just about everything in it on my PS2; I thought I had to start all over when I got my PS3 but I got one of these adapters and it worked wonders. Same applies for PS1 games.
Good luck and if I've helped you please give me a good rating.
Respectfully,
Don
May 10, 2010 | Sony Playstation 3 (PS3) Console
Yellow blinking light then turns off
My $500 80gig (old model, four ports and backwards compatibility) PlayStation 3 turns on, but doesn't show any audio and video. One day I was on the menu screen and all of a sudden the screen froze but the audio was still OK. After that I turned it off and then turn it back on, but i wasn't getting any video and now audio. I tried AV, component and HDMI cable, but still doesn't work. However, after an hour of keeping the system turned off, the game works back to normal condition, but soon it repeats the same problem of the screen freezing. WTF! I already know the holding-the-power button technique, but i still get nothing. HELP!
Sep 11, 2009 | Sony Playstation 3 (PS3) Console
As soon as i turn it on it freezes!
My PS3 has developed the exact same fault today HELP
Jul 09, 2009 | Sony Playstation 3 (PS3) Console
Ps3 keeps freezing after turn on
google:
rescuetechla
look for my blog.
look for my notes on the 5 most common ps3 problems.
pay attention to # 3
If you're confused wait until Sunday.
I'll have another simple version up soon.
Jun 18, 2009 | Sony Playstation 3 (PS3) Console
My plastation freezes as soon as i turn it on
That's not too hard to fix.
Check out my guide here:
Pay attention to #3.
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Feb 25, 2009 | Sony Playstation 3 (PS3) Console
TRY TO RESET IT IF IT DOESNT WORK!! TELL ME IN DETAIL!!?!
Dec 15, 2008 | Sony Playstation 3 (PS3) Console
Start up screen keeps freezing
My playstation was doing the same thing. I called a service person in South Carolina. He said that the system has crashed and it needs to be repaired by Sony. What he told was if I call the Manufacturer tell them that I was doing a network update and they will fix for free.
Sep 24, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
1,477 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
