Wavy lines across a samsung dlp hdtv. repairman said it needed a new set of digital and analogue cards and would cost us about $1000
  • bambizzle Nov 06, 2008
    thanks, I'll give it a try.
  • 153 Answers
How old is the tv? if its being used for more than one year, what you should do is, ask a technician open the item and see on the main board and see if theres any crack on the soldered lead at the terminal of any components in the PCB. if there is, its called a cold sold. You re- solder ( dry sold) the terminal of the components. Do it to any visual crack or cold solder terminals and test.
Hope it helps.
Posted on Nov 06, 2008
Wavy line on a DLP SAMSUNG 65 INCH PROJECTION TV
Bulb does not do anything but project white light. Wavy lines are a digital board problem. You should have a tech look at it.
May 20, 2015 | Samsung Televison & Video
Lines across bottom of screen
are they blinking lines or just straight across from one side to the other blinking lines is the dlp chip going ( they cost a bit to replace)
no blinking then the mirror could of moved in the back of the tv, happens if the tv is not on level ground. or the dlp board needs adjustment ( happens over time as the plastic moves when hot to cold all the time)
Mar 16, 2013 | Toshiba 52HM95 52" HDTV Projection...
The picture on my Mitsubishi WD62725 is starting to show some wavy lines and snow. We had a repairman come and he said that it needs a new chassis which would run around $550 and he said that it was not...
If the set is 6 years old I would not put $550 into it, but a new 60-65 DLP should only run you from 1200-1800. If you check around you will find alot of Mits DLPs on the internet for even less.
Jan 08, 2011 | Mitsubishi WD-62725 62" Rear Projection...
I have a Samsung HL-N4647W 42 inch HDTV DLP TV and the screen is blurry and out of focus with a black curved block across the bottom. what can I do to fix it?
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 03, 2010 | Samsung HL-R4264W 42" DLP HDTV
Samsung 50 HLN5065WX has wavy lines on analog input
this is an inherit problem of this set - - search 'wavy line' and you'll see many samsung sets have this - there is no cure ! use the set with component or hdmi good luck
Jul 16, 2010 | Samsung SP50L6HX 50" DLP HDTV
Samsung DLP 50
check the input board for AVI make sure it is not dusty and that all the connections on the board are good you may have a bad solder point or that board is bad ,also possible video ctrl board
May 31, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Televison & Video Logo
115 people viewed this question
Top Televison & Video Experts
