Question about Olympus FE-140 Digital Camera
Card cover open
Can this problem be resolved easily
You can glue the end of a toothpick into the sensor, or do some quick surgery on the circuit board.
From: http://www.digitalcamera-hq.com/digital-cameras/olympus-fe130_question.html?qid=7535
" Overriding the electrical system:
Theelectrical parts of the switch are soldered to the camera body with 2soldering points, on LH and RH of the switch, if you look at the bottomside of the camera (lift up the little black plastic sheet that coversone soldering point). i left the switch in place and connected the 2soldering points with a small copper thread from an ordinarymulti-thread electrical cable, using a fine pointed 15W soldering iron(5 Euros). i dont know if this action damages the camera and dont knowthe function of the switch, but my FE-140 is working again !
i forgot to mention the first steps:
Removethe camera back by removing all 7 screws on the camera body. Pull offthe back carefully. It is 1 loose plastic piece. Then you are able seethe switch environment (i needed a loupe)."
Posted on Aug 22, 2008
  • 75 Answers
The problem is a broken micro switch. If you are familiar with soldering on micro circuits you can get the part from Olympus it is called a card cover switch. Otherwise, send it into an authorized Olympus shop.
Posted on Mar 28, 2007
SOURCE:
I can't open my back cover...how can i change my sim
Hi there!
Let me give you the steps on how to insert the sim card on your phone.
First,kindly switch off the power and disconnect the charger and any other device before removing the covers. Avoid touching electronic components while changing the
covers. Always store and use the device with the covers attached.The SIM card and its contacts can be easily damaged by scratches or bending, so becareful when handling, inserting, or removing the card.
For you to be able to remove the back cover is that you have the press the back part of the phone gently and slide down the back plate of your phone.And after that kindly remove the cover and the battery.Please open the SIM card holder and insert the SIM card into the holder with the bevelled
corner facing down and the contact surface area facing toward the contacts of
the device. Close the SIM card holder.
Line up the battery contacts, and insert the battery. Replace the back cover.
That's it!
Thanks!
Apr 20, 2011 | Nokia X3 Cell Phone
Tip
Blackberry Curve Camera Won't Open
This Tip can help if you are receiving the following message on your Blackbery Curve.
"Could not start the camera. Close other applications and try opening the camera again."
A lot of people are complaining of this happening on the Blackberry curve for no apparent reason. Firmware updates do not resolve the behavior and it can become a very difficult problem to resolve.
There are four main things that have been known to resolve this problem as listed below;
1) Close the applications as requested. To do this;
  • Hold down the Blackberry button (marked by dots on the phone)
  • A menu will pop up showing all the apps that you currently have open.
  • Enter each one of these apps and make sure you manually close it down via the close selection on the menu.
  • Try the camera
2) This very simple solution has been known to work in a lot of cases.
  • Put your finger over the flash (if fitted on your version) and cover it when you try to start the camera, the camera has been known to start without any problem if you do this.
3) The camera is very susceptible to knocks which can easily jam the lens. This can often be resolved by following these simple steps.
  • Remove the back cover.
  • Gently but firmly press down around the lens until you hear a soft click.
  • Replace cover and battery and power up to see if issue resolved.
4) Finally this one may seem strange but is reported to work in some instances
  • Go to OPTIONS -ADVANCED OPTIONS - HOST ROUTING TABLE.
  • Click to enter then use menu key to Register now.
  • You will get an email for verification.
  • Pull the battery while the device is ON and then replace it.
  • Let the device reboot 1-3 min
  • Retry the camera.
If this Tip has helped - please do use the Yes/No buttons below to indicate this.
on Dec 27, 2009 | Cell Phones
Dns ps3
dont worry it seems to be a small problem.................
and u can easily resolve your problem
Click Here to download the repair guide
dont waste money by going to repair shop........... with out knowing much you can repair your ps3 with the help of this guide .........
it covers this problem so can download this soon to resolve this problem
Aug 15, 2010 | Sony Playstation 3 (PS3) Console
Paper jammed at this time error message show on control panel 13.05.00-Jam in top cover area open front covers and Transfer unit. Fuser is hot transfer unit can be easily damaged. Check left side of...
This error comes when media doesn't come to fuser delivery sencor with in the specified time it may be due to improper paper picking or fault in registration ***...
clean the paper feed rooler & registration *** path ur problem will resolve defin...........
Jul 14, 2010 | HP LaserJet M4345 MultiFunction Printer
Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
Jan 19, 2010 | Panasonic Microwave Ovens
Samsung CLP-300 - Cover Open error message, but covers are closed
Front cover is on the right hand side, back is on the left hand side in the middle, and the top cover is like a little button on top. All the others are little openings.
Dec 02, 2008 | Samsung CLP 300 Laser Printer
Camera turns off by itself
I have a similar problem.. I recently found out it mostly happened when I was squeezing the right side of the camera or touching the card slot cover in some way... and I discovered that the camera turns off when you open the card slot cover, so it probably has to do with contacts that touch too easily and make the camera turn off when you shake the card slot cover somehow. Now that I know the source I'll see if there's a solution. Hope this helps!
Jun 09, 2008 | Fuji FinePix S7000 Digital Camera
Card-Cover open
According to Olympus Tech Support this is a Sensor issue and requires repair. They quoted $86 for repairs...to me that is just not worth it, I have the same issue but purchased a good used camera on ebay for only $40! Good luck, sory I couldn't help.
Jan 05, 2008 | Olympus Camedia D-435 Digital Camera
Error message: battery cover open. This message appears in the window and will not let me operate camera until problem is resolved. The cover is closed, but the message will not go away. I have re-set...
try closing the battery cover. if you do not know what that is, it is where the sd card and the battery are held. the cover for that is the battery cover. if it is closed, and still not working, make sure its closed all the way, if it is, take it to best buy or circut city or any other electronics store and ask them.
Dec 12, 2007 | Gateway DC-T50 Digital Camera
Olympus FE-140 Digital Camera Logo
355 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
