Question about RCA D52W19 52" Rear Projection Television
Capacitors I am sorry for not wording it correctly! I read all the info on the trouble shooting the blinking codes the deflection boards and locations of boards and capacitors and such. What I was trying for is-- Where would I purchase replacement parts. I ve found were it was said (servicemanuals.vstore.ca) for the flyback. And I have found the flyback and CP150 & CP114. But nothing on CP111? Is there somewhere else to get the new capacitors? Sorry for the confusion. Hope you feel better. Thank you.
  • RCA Master
  • 5,138 Answers
There is 3 capacitors in same circuit 1 will be a 2200uf 16v / (2) of them are 220uf 35v and some sets may have (1) 220uf 35v (1)330uf 35v. replace 3 that are green with gold writing on them. also when reconnecting board make sure you have second ribbon connected good or set wil not come on.
Posted on Dec 19, 2008
Sony kp44px3u rear projector blinks 11 times red led then Off 3 second then 11 times off 3 second what dose this mean
your problem is most likely on the deflection power supply b Board a diode possibly d303 or mcz3001b Smps control IC . it will require some trouble shooting . and you will need a digital multi meter and schematics to trouble shoot the power supply further
Feb 02, 2015 | Sony Televison & Video
RCA Scenium HDLP50W151YX1
5 Times it is a problem with the lamp.
Either the lamp is gone, or the small pwer board powering the lamp is defective.
Sep 26, 2008 | RCA HD50LPW175 50" HDTV
Magnavox 37MF331D 37 inch won't power on with no led light
check the power supply board for swollen filter capacitors
Oct 15, 2012 | Televison & Video
Our Sony tv lost picture then shuts off and a red light keeps blinking
Ther are no resets the blinking light is the code for the tech to diagnose the issue. Most likely you have lost a circuit board, the most common is the power supply. There are a lot of bad capacitors in these sets and when they die they take the tv with them. Check your manual for the trouble shooting and see if you can tell by the blinking pattern of the lights what the issue might be. The other only hope is to unplug the set for at least an hour and then plug back in and turn on. This sometimes clears a bad code or reading. If not then the set needs service.
Apr 04, 2011 | Sony Televison & Video
Ge,52''widescreen,model #d52gw12.The power light button comes on and is blinking but want power up.Please help.Thanks
3 capacitors on deflection board cp150 2200uf 16v use 25v cp114 cp120 220uf 35v resolder FBT flyback Transfomer pinns also!
Dec 14, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Light flashes 6 times
First of all, the 6 blinks indicate a loss of 5V on the A board. The most common cause is a defective deflection yoke. This is not a repair that should be attempted by a novice because of the procedure required to locate the defect. Please get a detailed estimate from a local servicer. An improper attempt to locate the defect can easily cause additional damage.
Sorry to be the bearer of bad news, but this is one case where a professional should be used.
Dan
May 08, 2009 | Sony KP-65WS500 65" Rear Projection...
Bad capacitors? ladywinn
If you take the back off the deflection board is the one on the left. You must remove the board and near the front you will see a capacitor with a puffy top. Replace this one and the three closest capacitors around it. Not easily done unless you have some experience.
Apr 09, 2009 | RCA R52WH73 Projection Television
Hitachi 43UWX10B: Power light blinks continuously on and off, no picture
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Aug 08, 2017 | Hitachi 43UWX10B 43" Rear Projection...
Stil confused
Check 3 capacitors on deflection board where the flyback is but they are located on front of board cp150 2200uf 16v cp111 330uf 35v cp114 220uf 35v Look at top of capacitor cp150 if it looks like it is bubbled on top it is bad so replace all 3.
Oct 04, 2008 | RCA D52W19 52" Rear Projection Television
Toshiba 32A14 horizontal line
This symptom is characterized by a thin horizontal line in the middle of the screen. This symptom is caused by the absence of the deflection sawtooth current in the horizontal deflection coil.
The trouble is easily isolated by a continuity test and by checking the most likely defective components such as A)open vertical linearity compensation transformer, B) open capacitor and C) open horizontal deflection coil.
Be sure to decrease the brightness first before trouble-shooting if the line is very bright,as it burn the phosphor screen..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 19, 2008 | Toshiba 32A33 32" TV
RCA D52W19 52" Rear Projection Television Logo
76 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
