Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
Dishwasher My dishwasher which is only two years old won't dissolve the soap. I have run it through two cycles. Please help!!
  • Anonymous Mar 20, 2014
    soap not dissolving
  • KitchenAid Master
  • 2,651 Answers
2 things will lead to soap not dissolving, first is cold water, so make sure you have hot enough water. second and more likely is the dispenser is not opening at the proper time , instead fully opens at end of cycle during the dry cycle never even getting wet, and washing dishes with no soap, id replace the dispenser or make sure your not stacking items in front of dispenser hindering the opening. also powder is best, tabs and gelpack put undo stress on the dispenser door not always allowing full operation...
Posted on Nov 06, 2008
Dishwasher soap is not dissolving.
Try emptying the dishwasher and putting a few tablespoons of vegatable oil in the bottom. Run the cycle without soap and no dishs. Often dish soap (palmolive) builds up and creates soap suds that won't go away during a normal cycle. The oil binds with the soap residue to get rid of it. It worked for my Kenmore. I know do it every few months. Good Luck!!!
Jun 22, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
Help! My dishwasher doesn't rinse soap off my dishes anymore
try a few applications of jet dry DISHWASHER cleaner to remove excessive build up of calcium/hard water deposits...sounds like the water temperature is too low upon the initial fill cycle to assist in dissolving the soap.the water temp. must 125 degrees to insure soap activation/ and dissolve it.check for obstructed spray arm as well
Mar 06, 2010 | Frigidaire 24 in. PLD2850 Built-in...
The soap packet doesn't dissolve, it remains intact at the bottom of the machine at the end of the cycle.
don,t use those packets stay with powder or liquid dishwasher soap. the packets need a lot of heat to dissolve,.
May 29, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher detergent "pacs" dont disolve anymore
Try reversing the bottom dish rack, it's likely blocking the dispenser door because it's put in the dishwasher incorrectly. Also check if there is anything in the back of the rack preventing it from going all the way in.
Apr 05, 2009 | KitchenAid KUDU03FT Built-in Dishwasher
My soap won't dissolve during the cycle.
You are not getting enough water or you are losing the water during wash cycle. Is you dishwasher new or older? How is it plumbed in? If it is plumbed through the floor you will have to put and air gap in to keep the water in it. All tall tub dishwasher have to be plumbed properly.
Jan 05, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Not all of the soap dissolving, some left in dispenser and bottom
Kitchenaid lists 130 dishwashers with this model. Need the rest of the number
Back in the day, when I worked on K Dishwashers, the drain valve was the problem typically.
It would get a piece of glass, from broken glass or other item, or a toothpick, whatever stuck in the drain valve. It would not completely close. During the wash cycle, water would be trickling down the drain and by the time the soap dispenser opens, the water would be gone or nearly gone.
Check this. When you hear the dispenser snap open, stop the dishwasher and open the door.
If you have little or no water, you are losing the water during the wash cycle.
Let me know.
Nov 22, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Soap does not seem to dissolve or clean
Probably a sticky dispenser door. Run for a few times with the dispenser open and put a tablet in the cultery basket
Nov 23, 2007 | Frigidaire 24 in. FDB635RF Built-in...
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
642 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
