Question about Dell Dimension 5100 (D51L1) PC Desktop
Dell 5100 Power Supply.
My computer died and the Blue light is on the Mother Board, and there is an amber light that flickers rapidly by the front part where the switch is located.
Is there a way I can check the power supply to see if it is the culprit? if it is OK, I will check the motherboard. The system is 3 years old.Pentium3.
Thanks for your help.
John
  • camarillojoh Nov 06, 2008
    Thanks for the response Pablo. I ordered a Power Supply with the Dell part number to make sure it will fit. I will try it as soon as I get it.
    Camarillojohn
  • dannycyn5 Nov 06, 2008
    I have a similar problem with mine. My 5100 is about 4 yrs old and it has trouble starting up, There is a little orange light that flickers at the main switch and also where the dsl hooks in. I am not computer stupid but can't figure out this one. On the motherboard i have a green light. Can you help me on this one.
    Genius:
  • 1,124 Answers
Check if the fan of power supply is working (back),
the same way open your computer and chech if the fan of the cpu is working.
If not the power supply must be replaced.
Please advice that not all dell power supplies are compatible with the universal ones.
Check first yours before buy one. (in case of replace)
Posted on Nov 06, 2008
Power led light is a steady orange but pc will not power up
If the power light is blinking amber, the computer is receiving electrical
power, a device might be malfunctioning or incorrectly installed.
- Remove and then reinstall the memory modules (see "Memory" on
page 112).
- Remove and then reinstall any cards (see "Cards" on page 116).
- Remove and then reinstall the graphics card, if applicable (see "Cards"
on page 116).
• If the power light is steady amber, there may be a power problem or an
internal device malfunction.
- Ensure that all power cables are securely connected to the system
board (see "System Board Components" on page 107).
- Ensure that the main power cable and front panel cable are securely
connected to the system board (see "System Board Components"
Copy and paste this link to your internet browser for your computer's manual.
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_inspiron_desktop/inspiron-531s_owner%27s%20manual_en-us.pdf
You can also go to support.dell.com
Jan 08, 2013 | Dell Dimension 4600 PC Desktop
Dell Inspiron 1721 will not power on,light on power supply flashes rapidly.
First, try and take out the battery and start the computer with just the power adapter. If the power adapter is still blinking, replace the power adapter. If the computer turns on with just the power adapter, replace the battery.
If the battery status light rapidly flashes amber, the battery may be defective. Purchase a replacement battery from Dell.
If the power supply status light flashes, the power supply may be defective. Purchase a replacement power supply.
Feb 15, 2011 | Dell Inspiron 1721 Notebook
My dell GX 270 computer has amber mother board light,No display,processor fan runs,power supply fan rotates.
hi ansilesh
If the power light is steady amber - The computer is receiving
electrical power, but an internal power problem might exist.
Ensure that the microprocessor power cable is securely connected to the
system board.
it might also be a failed mainboard already since you are experiencing a blackout.
hope this helps
janc30
Feb 11, 2011 | Dell (002TR) Motherboard
Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
Jun 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Blinking amber light with green 4 light
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.
Try, unplugging the power cable from the pc, and reinsert it, if this does not help try a differnt power outlet, if this dont help, open the computer, take the power Molex conector out of the mother board and try turning it on, if this dont help, take out the Memory modules and reseat them, if this dont work you may want to ring up dell support.
Hope this helps!
Jun 15, 2009 | Dell Dimension 9100 PC Desktop
Dimension 5100 wont power up
check powersupply, boot into recovery console and run chkdsk /r if able, and yes you can mirror the drive and recover data. may also be able to do repair install.
Dec 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Flickering amber power light
Normally a bad power supply, but since you have changed that and the motherboard, the front IO panel is next.
Jun 25, 2008 | Dell OptiPlex GX280 PC Desktop
Computer won't start
Can you see a green light on located on the mother board ? I had the same problem with mine right after the warrranty was off, The mother board failed, But you should make sure thats it first by making sure everything Inside of the computer is tight and secure.Unplug and make sure there is no power on and unplugged,Before you touch anything inside your computer discharge any static electricity by touching the metal on the inside of the tower. The Memory modules Make sure that they are pushed in securely in there slots and video card is Pushed in and tight, and any other extras you may have plugged into it, After you do all that put everything back and try to reboot see if that get you up and going. If not let me know I can Help You fix it or repair it myself if you would like, just leave message here or email me. bear350cid@yahoo.com Happy Holidays
Dec 15, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimensions 5100 Power Button
The power light is tied to the Mother Board and therefore it could be an issue with just about anything on the PC. Here is the trouble shooting documentation and the link should bring you directly to what the various conditions of the power LED mean.
There is also a detailed listing for the HD light as well as some diagnostic lights (if your paticular variation is equiped)
http://support.dell.com/support/edocs/systems/dim5100/en/sm/tshoot1.htm#wp1114432
Nov 22, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
79 people viewed this question
Alun Cox
