Question about Dell UltraSharp 2005FPW 20.1" LCD Monitor
Screen resolution My screen seems to be a little fuzzy. How do I change it so that it is at the highest resolution? I use the monitor with an ibook G4.
  • 3,940 Answers
1680 x 1050 at 60 Hz is the ooptimal resolution and the only one that will not be fuzzy.
http://support.dell.com/support/edocs/monitors/2005FPW/En/about.htm#Specifioications
press command - shift - a to bring up the Applications folder. Then open System Preferences. Click on Displays, from there you should be able to adjust the resolution
Posted on Jun 08, 2008
How fix computer monitor stuck in low resolution
If your resolution is too low, you can change that by clicking on the Start button and then clicking on Control Panel. From the Control Panel window, click on Adjust screen resolution from beneath the Appearance and Personalization section. From the Resolution drop-down, select the highest resolution by moving the slider to the top. Your resolution should be just fine now.
To change your font size, go back to Control Panel, search for "window color" in the search box, and then click on Change window colors and metrics". You can adjust font sizes from here.
Jun 08, 2014 | Microsoft Windows 7 Ultimate for PC
My monitor is fuzzy in internet
Fuzzy on the internet and everything else or fuzzy just on the internet? check for monitor resolution and see if you have the screen resolution set right. If you have the resolution set too low, the screen can appear more fuzzy if the aspect ratio is not set right.
Jun 04, 2014 | Samsung SyncMaster 2333SW 23" LCD Monitor
Monitor screen is almost completely black - i can only see the desktop very slightly. is there a light bulb that can be replaced to fix this?
Change the display resolution in Windows To change the display resolution to the highest resolution, use the following actions.
  • In Windows 7 , click Start , click Control Panel , find the Appearance and Personalization area , and click Adjust Screen Resolution . Move the slider bar until the highest resolution for the monitor is set, and click OK .
  • In Windows Vista , click Start , click Control Panel , find the Appearance and Personalization area , and click Adjust Screen Resolution . Move the slider bar until the highest resolution for the monitor is set, and click OK .
  • In Windows XP , click Start , click Settings , and then click Control Panel . Double-click the Display icon, and select the Settings tab. Move the slider bar until the highest resolution is set, and click OK .
If the screen is still blurry, please contact an HP support technician for further assistance.
Also see To troubleshoot this problem, make sure the AC adapter is connected. For specific steps, see HP Notebook PCs - Troubleshooting Black Screen Displays with No Error Messages During Startup or Boot .
Nov 02, 2010 | HP G60-127NR Notebook
Laptop comes on great and seems to make all the right noise but the screen looks like the old vhf/uhf tv screens from the 60's....wont show a thing encept "fuzzy static"...it's a slimnote...
Hmmm, well either your Video Driver needs to be re-installed or you need to change the windows resolution settings.
XP: Right click the desktop and left click properties. Clickthe Settings tab and you will see a slider bar in the middle left. Move the barto the right or left one at a time and eventually you will hit the correctsettings for the monitor.
Vista/Win7: Right click the desktop and left click on Screen Resolution. Whereit says Resolution, you can change the settings to the Recommended settings foryour specific monitor.
Cheers!
Oct 28, 2010 | Twinhead Slimnote N12PI (N12PICC01) PC...
Screen will flicker a few times at random periods
Change the display resolution in Windows Change the display resolution to the highest resolution using the following actions:
If the screen is still blurry, the notebook display might need servicing.
Feb 13, 2010 | HP Pavilion dv4000 Notebook
Only getting extra large picture
Please right click on your monitor desktop
Click on "Properties"
Click on "Settings"
Look for "Screen Resolution" down at the bottom.
see if the resolution is "1024 by 768"
if not then make it "1024 by 768"
Also check "Color Quality" is set to "Highest (32 bit)"
If not then make it "Highest (32 bit)"
Click apply and screen resolution will be changed.
If it does not change then please check your graphic card drivers.
Cheers
Nov 04, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
Screen resolution on powerpoint cannot be locked at high res. Changes when connected to my projector. Monitor screen res. also changes everytime the projector is plugged in, In power point display (2nd...
I just checked the specs on your Benq PB 6110, which has a native resolution of 800X600 and will simulate 1280X1024. When you connect it to your computer, the computer goes to 800X600, right? That is the resolution of the BenQ. How high a resolution do you want? THe highest I have seen in projectors is 1024X760, which is not that much higher. Projectors seem to lag behind monitors and Plasma/LCD/LED TVs for resolution. They must have a very small market share therefore low developement.
May 07, 2009 | Microsoft Office PowerPoint Home and...
Screen resolution of 1080p sharp lcd
set the resolution to the native resolution of the monitor
less makes it look fuzzy
Dec 31, 2008 | Best Data Products Best Data BizView BV200...
Font and screan to big and fuzzy
Right click on your desktop. Click on properties.
Click on Settings. Adjust the resolution based on the documentation for your screen.
Jun 27, 2008 | Smart Modular PYXSCAPE SV1170 17" Flat...
Dell UltraSharp 2005FPW 20.1" LCD Monitor Logo
141 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
