Question about Toshiba 42H82 42" Rear Projection HDTV-Ready Television
Squiggly Lines at Power On
Started getting squiggly vertical lines near the top of the screen at power-on. Lines disappeared in 10 to 20 minutes. Now these lines extend to the whole screen and don't go away for about an hour after power-on. Even then some line motion is seen at the top of the screen. Machine is just over 5 years.
Thx
Dave
  • 2 more comments
  • danjen Nov 06, 2008
    I have the same problem but I have a Toshiba Theater Wide HD TV 52 inch.
  • jdcomp333 Nov 06, 2008
    Thanks. Does this suggest replacing the power supply too? Look forward to hearing from you after you research a bit.
    Thx
    Dave
  • dmrevels Dec 07, 2008
    I have the same problems with the squiggly lines as well as a yellow spot on my screen, can someone help me with this?
  • davidm728 Dec 20, 2008
    on start up the picture is all fuzzy and out of focus for about 10 min. my set is around 6years old.
  • 4,234 Answers
Generally speaking, this type of symptom is caused by AC hum leaking throught the power supply. This can be due to a bad filter cap. Since this clears up after a while, I'd start by looking for poor solder connections in the power supply area. If you can, check the caps in that area as well. I'll research this a bit and try to get you more details.
Dan
Posted on Nov 06, 2008
Squiggly lines
Check and replace all the filter capacitors at its main power regulator section circuit.
May 22, 2013 | Televison & Video
Video Card Ribbon Problem? Squiggly Lines on Monitor
It can be that the video card in bad or any electrical part need to be fix and i recommend to send it to a repair shop.
May 12, 2012 | HP Pavilion Computers & Internet
The tv has red images, I cannot get the red convergence line vertically to straighten, it is squiggly, the horizontal is straight, and the blue and green lines are both okay
the 43h71 has a pair of convergence ics that commonly go bad and cause this problem. replace original stk392-110 with stk392-120. the upgrades have a collector rated at 4 amps vs the 110's 3 amps and should be more reliable.
also know that they hyperboard in this set can cause squiggly lines throughout but will not affect the convergence.
Jul 06, 2010 | Toshiba 43H71 43" Rear Projection...
It started out with alot of different colored squiggly lines it would clear up after about ten minutes but it just shut off yesterday the red button on the front still flashes though
Especially Projection TVs will shut down to protect the projection tubes because loss of proper scan can burn an image into the phosphors in the tube itself. The squiggly lines most likely are a symptom of a failure in the Horizontal output section (the part that scans the picture from left to right), there is also a possibility of the Vertical output section (the part that scans the picture from top to bottom causing the problem. This will require replacing a circuit board or repairing the one in the set at a component level. This is best left to a qualified Technician to do the work.
May 29, 2010 | Sony KP-61HS30 TV
Small Rectangles or squiggly lines on screen
bad RAM on graphics card. replaces graphics card
May 14, 2010 | BenQ G2110W 21" Monitor
My Wii console has little squiggly lines on my screen...
Take it to a place where they fix the games!!
Oct 11, 2009 | Nintendo Wii Console
Faint squiggly lines top to bottom
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Sep 20, 2007 | Samsung HCN4226W 42" Rear Projection...
Open Questions:
See all Toshiba 42H82 42" Rear Projection HDTV-Ready Questions
Toshiba 42H82 42" Rear Projection HDTV-Ready Television Logo
266 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
