Question about RCA F36665 36" TV
Rca f36665 No picture but sound and menus work
TV will turn on fine, works through all menus fine, sound works fine, problem is that on any station you have no picture. You can hear the channel that you are on but no picture. I have removed rear cover and blew the dust off (not very dusty), checked all connections for tightness ect, TV was working fine and then just quit showing picture. I am not very familiar with TV problems and my experience level with them ends with with watching one. I however am capable of fixing a PC including basic electrical trouble shooting so fixing it including changing out components isn't beyond my knowledge. Any Suggestions on where I should start??
  • dan hoffman Oct 11, 2006
    I did the cover removal and check connections trick to no avail. I looked on the website for service manuals and they do not have one for this model. Any other suggestions? Thanks
  • dan hoffman Oct 12, 2006
    The service manual place does not and cannot get the manual for this model. Any suggestions?
    Sergeant:
  • 337 Answers
This might be a simple problem or a more involved one and for that you will need the service manual to check different voltages,is good you are somehow familiar with electronic servicing,first you need to remove the back cover and reconect just the cable signal and the power cord,make sure the chassis is seated properly in whats left of the front cabinet then turn the set on and scan for channels if you still see no picture tap lightly with handle (not Metal)of a screwdriver in the chassis to see if the set reacts to your tapping if it does you will be looking for a loose conection and should be easier but if the set does not react you will need to order the service manual from http://www.servicemanuals.net/ ,in there you go to service manuals and put the model number,they will give you a price. Once you get the service manual you need to check the voltages to the signal processor IC to see if they are there specially the B+ supply to this IC.Let Us know if you have any more questions.
Posted on Oct 11, 2006
  • Omar Urrutia
    Omar Urrutia Oct 11, 2006
    The rating response is important to the person helping you.
  • Omar Urrutia
    You need to go back to service manuals and go to contact us and fill up the form ,tell them the manual you need is not on their list.They will find it and get back to you.
SOURCE:
I have my rca model f36665 hooked up strait from the wall to the tv and I can't get it to find the channels. do I have to have a cable box?
First if cable I presume you have entered the menu and selected cable.
Another possible reason is the tuner/s in this set are bad---hook a DVD or something to one of the rear inputs and see if set works.
If set works that way and tuner turns out to be bad you can with a box with av cable out connections on back just go into a rear input and bypass the tuner--leave set on that input and change channels with the box.
Let me know if you have questions and what you find---usually on this set if no signal---"unusable signal" will appear on screen if no signal.
Mar 20, 2012 | RCA F36665 36" TV
Have rca f36665 have picture but static for sound
it has a short in it.u will need a tv repairman sorry
Sep 23, 2009 | RCA F36450 36" TV
I need the part number for the control panel on my 36" RCA model number F36665.
p3001 is the number I have on wires,going from the motherboard to the control panel.It is A 36"RCA F36665 1999
Mar 29, 2009 | RCA F36665 36" TV
RCA F36665 36" red picture
Do picture have little white lines in it? This could be caused by a bad CRT driver transistor. On the small CRT board on back of tube. The red could be shorted
Dec 07, 2007 | RCA F36665 36" TV
RCA Model f36665 Guide series 36" TV
Who said it cannot be fixed? You can try and hook an external speaker to wires and test for sound. Maybe audio outs have sound?
Oct 29, 2007 | RCA F36645 TV
36" RCA TV Wont power up
Best suggestion is IHVT,also known as flyback transformer.Thomson products well-known for xformer troubles. (GE,RCA & Proscan)
Oct 04, 2007 | RCA F36665 36" TV
Rca direct view tv 36" f36665
clicking,w/no sound or pix is usually IHVT, AKA flyback transformer.Please clarify size and model #. Include last three characters in Thomson products service #---Ex.=F36665-YX01.
Oct 02, 2007 | RCA 32F531T 32" TV
RCA 37'' has sound but no picture
1)confirm service # on back of tv 2)Is sound from tv or surround system? 3)suspect bad flyback xformer.
Sep 01, 2007 | RCA F36665 36" TV
RCA has no sound
well u have a problem in the audio circuits of the tv which includes the speaker itself. but most of the time the audio power output transistor or ic get easily damaged resulting a no sound tv. if u dont have any idea with regards to this, i suggest have it check with a qualified service technician. it will not cost u a lot for sure.
Jan 17, 2007 | RCA F36665 36" TV
RCA F36665 36" TV Logo
261 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
