Emachine laptop overheating, fan comng on every 5 secs because it is. And also DC light on, but power light not coming on,BIOS battery seems to have fallen below 1 volt, it should be 3 volts....any ideas.
  • 796 Answers
May be the paste the removes the heat from the processor has lost it property of transferring the heat from processor on to the sink..
you shud be replacing the paste for reducing the temp.
Posted on Nov 06, 2008
My Eee 4g surf netbook won't charge at all. Upon turning it on, it runs for a second, then shuts off due to a lack of battery power. The charge cable's light is also not turning, so that may
I think your DC Power Jack is bad. The DC Power Jack is where the power cord plugs into the laptop. If it is bad, then a good power cord cannot charge the battery, nor can the laptop turn on once the battery is drained.
You say it smelled burnt, that might mean it took a power surge. I always tell people that before your plug the power cord into the electrical outlet on the wall to remove the other end of the cord from the laptop. That way if you get a power surge you will only damage the power cord and not the dc power jack or motherboard.
Anyway, take an ink pen and push it into the dc power jack and see if there is some movement. The little pin or the casing of the jack should not wiggle.
The DC Jack is soldered onto the motherboard. To replace it you will have to take the laptop apart, desolder the old dc jack and solder a new jack onto the board. Sometimes the DC Jack sits in a slot rather than being soldered. The palmrest and bottom case helps to keep it in place. This type of DC Jack usually has a cable harness that plugs into the motherboard.
Apr 02, 2012 | ASUS Eee 4G Notebook
I have a desktop PC that when I turn it on it will power up and then after 6 seconds turn back off.
The first solution is right on the money, It's the video card, or many of us today forget to plug the damm thing in and the computer doesn't read and we think that there is a serious problem. If none of this helps then try troubleshooting through this PC repair guide. Hope this helps.
Dec 29, 2011 | E-Machines eMachines Desktop PC
HP Pavillon dv62030ez No more start up. Fan and lights get power for a second, then nothing. Think thr BGA doesn't fit any more, due to overheating.
This may be a problem with the bios. Try to reset the bios. follow the below procedure
1. remove the main battery
2. remove any USB cables etc., if connected
3. hold the power button for 15 secs.
4. reconnect the power adapter (Do not install the battery yet)
Later if the system starts well then shut down the Laptop and install back the battery and connect the charger and start the Laptop again
If the above will not solve the problem then follow the next step
1. Remove the power adapter and the battery
2. Open the back side cover where the Memory is installed.
3. remove the BIOS battery
4. leave the laptop for a while may be 10 mins.
5. Now connect the BIOS battery back
6. System will automatically start do not press the power button
7. set the date and time
8. Shut down the Laptop
9. Start normally back on.
Jun 30, 2011 | HP Pavilion dv6000z Notebook
Cant operate bios after reformatting the unit
If you cannot operate the BIOS, the best way is to reset the CMOS battery which require a very good technician to tear down the unit. Here are the steps:
Turn off laptop
remove cables and battery
Press and hold power button for 5 secs.
Remove screws in the edges of the laptop
Remove Hard drive, Optical Drive and Power supply fan
Press the CMOS battery (circle shaped silver coating) upwards so that it would disengage and put it back in...
Put back the Hard drive, Optical Drive and Power supply fan
Put back screws in the edges of the laptop
Put in cables and battery
Turn on laptop and the BIOS will be reset successfully...
Jan 09, 2011 | ASUS A8HE-4P017C (90NNVA4115384CAL301) PC...
It's an Acer Aspire One 110 running Windows XP. When battery is inserted or power supply plugged in, the green light on the power button comes on and as long as there is power going to the machine the...
Thank you for your query
It would seem you have a possible DCf jack problem, causing the mentioned issues
If the DC jack is faulty it can cause the problems mentioned above.
I would recommend that you book the laptop into a reputable PC shop for them to replace it
I hope this has been useful
Mar 16, 2010 | Computers & Internet
Dell Inspiron works on battery only. No AC, no charger.
get a volt meter and be sure the power is coming to the plug, you may have a broken cord. if the problem is not there see if you have a setting in the bios for dc only. some older dells have a bios setting for the power settings in bios.
Jul 27, 2009 | Dell Computers & Internet
Delll Inspiron 2200 Laptop does not power on
You have all the simpthoms of an overheating laptop.
For starters, get a vacuum and **** all the dirt from the fan or fans on the back/ bottom of your laptop.
Then turn on your laptop. It should stay longer than 5 seconds.
If this solves your problem, then you are lucky.
If not, you'll need to have your laptop serviced, and clean the heat sink, and have reapplied the heat transfer compund on the processor.
Not a big deal, and not that expensive either.
If this answer helps, please don't forget to rate.
Jun 22, 2009 | Dell Inspiron 2200 Notebook
Desk top will not come on
at first check the all power cable. change the power supply, check the ram, check agp or pci-express. check hdd, remove the bios battery, wait for 5 minutes, then add battery, then start the computer.
Jan 25, 2009 | E-Machines eMachines Desktop PC
Laptop wont boot.
do you get any video on the screen at all? in either case, it might be a motherboard problem, but try taking out your battery and unplugging power. wait a few minutes, then put them back in and try to boot. if you're still getting lights but no video or functionality, it's probably a motherboard problem and you're looking at having to get a new computer, or a very very very expensive repair.
Jan 14, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Open Questions:
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
