Question about ViewSonic VE710b 17" Flat Panel LCD Monitor
Monitor turns on and off
The monitor turns on for not even a second then turns off for about 5seconds and repeats it worked 1 year ago it is an hp1702 lcd screen
  • 1 more comment
  • princeloma Nov 13, 2008
    I have vg2021m, working from last 3 year. From couple of days, i have having the problem.
    When i used to monitor switch to turn on display it turn off within 2 sec.
    Is this issue with power or refresh rate?
  • Anonymous Jan 24, 2009
    I have - had the problem, too. Monitor switches off and on in second frequencies about.
    It happened when I did training in typing and I must have hit
    accindently a key combination. Let say ALT+fn (just an example)
    Then it started that on and off thing.
    By trying to find those keys, i tried long long time till I hit the right
    combination. Then monitor behaved normally again.
    Sometimes it happened again in typing exercises, and by trying
    to find the right key combination, I could recover it again.
    By trying to recover to normal mode I went so fast that I cannot tell
    the exact key combination. What I know is, that it is in the area of CTRL ALT a to f and z to b.
    Very sorry cannot tell the exact keys
    I am running XP Pro
  • Anonymous Feb 10, 2009
    I have a monitor with exactly the same behavior. Any new information?
    Problem Solver:
  • 8 Answers
Is it an HP or a Viewsonic screen ?
Either way, looks like a power supply problem to me, some Viewsonic screens are known to have a problem with their inner power supply card, If your screen is still under warranty I suggest you don't lose time analysing the problem and just make them come and fix/replace it
Posted on Nov 07, 2008
You lifesaver...
CTRL ALT b restored my ViewSonic VE710b first time.
Well maybe not a lifesaver - but ceratainly an £80 new monitor cost saver.
Posted on Mar 26, 2009
Display not working, power button LED turns on blue for 1 second and won't turn on again
Have you tried checking with another monitor. Meaning that if the second monitor does not come on then the problem is with your computers mother board. But if the monitor other monitor you check it with comes on then of course it is your monitor.
Jun 12, 2016 | Acer 22" X223w LCD Monitor
After i open my monitor then after few seconds its turn black.model hp1702
. Please explain what you mean, after i open my monitor then after few seconds its turn black.model hp1702
Aug 30, 2009 | Acer AL1715 17" LCD Monitor
I have a samsung 920nw monitor bought it new. It has worked great for months, this morning I went to turn it on and it only came on for a second then turned off. I have restarted the PC and the monitor...
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Corporate Computer
Over 21 years of computer and printer support/repair
Jun 30, 2009 | Samsung SyncMaster 920NW Monitor
I have a 20 sceptre widescreen lcd monitor
Have you tried any other monitor connected to your computer since your current problem? Check your connections, make sure your VGA cable/DVI cable are in good condition. If none of that works try to RMA it to sceptre if your still within the 1 year period.
Apr 07, 2009 | Sceptre X20g-Naga III 20.1" LCD Monitor
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
My acer,mod. 1715
Rich most likely this monitor needs capacitor replacement if you can solder you can do it, you just need to order or get the bad capacitors that need replacement so you need to open the case and get at the power board. once you can get at the blown caps you can see whats damaged and what is OK usually it is 1 or 2 capacitors at about 50 cents each. and about 1 hour of your time.
let me know what your doing, good luck
Oct 18, 2008 | Acer AL1715 17" LCD Monitor
HP Pavilion F1703 17 inch LCD
The way you can see its a backlight problem is after it goes off after that 1 min.
Grab a flashflight shine it on the screen and c if you can c the desktop if you can than its the backlight.
Aug 24, 2008 | HP Pavilion F1703 17" LCD Monitor
Princeton VL1919 repeatedly pops when turned on
If you feel confident take the monitor back cover off and replace the 3 bulged out capacitors
Jan 26, 2008 | Princeton Digital VL1916 19" LCD Monitor
Monitor goes blank less than a second after turning on.
I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up?
I got my rosewill flatscreen as a hand me down from my father. I've had it for several years now. Was working fine until a month ago. When I turn the computer on the screen goes black after 1/4 of a saecond. I have to turn it off and on anywhere from 10 to 20 times before it stays on. I have checked all plugs to the computer and outlets. I have absolutely no idea whats causing this.
Dec 28, 2007 | Rosewill R700J 17" Flat Panel LCD Monitor
ViewSonic VE710b 17" Flat Panel LCD Monitor Logo
593 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
