Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424
Freezer defrosts and unfreezes everything. A day or so later it refreezes.
Every couple of months this freezer defrosts and allows everything to thaw.
In a day or so it begins to freeze again.
I have two of these freezers next to each other in a relatively small space
    Novelist:
  • 124 Answers
Most domestic freezers do not have a defrost control. .90 percent of them freeze and every few years enough ice builds up that you have to unload and manually defrost them. so what is probably happening is the stat is sticking in hte off position and not recognizing the call for cool when the temp gets up. if you catch it off and thawed try tapping the stat gently after the temp is getting way warm. if the box comes on and starts freezing again then the stat is sticking in the off cycle and needs to be replaced. usually under 75 dollars and fairly easy. two wires connect in any order.the stat itself has no in and out requirements. power in and power out when it closes. there may be a ground wire usually green and smaller connector attached to some newer stats. look close and you can see the difference. usually the voltage connections are next to each other and the ground is off to the side or end. stat is usually behind a plastic cover inside the freezer. good luck, disconnect power when you change stat of course.
Posted on Nov 06, 2008
Is my defrost timer broken or my thermostat? The freezer was holding -30 temp but now is at +30.
Is the compressor running? If not - the timer could be stuck in defrost mode. If it is ruinning, then the freezer coil should be cold. If it is choked with frost & ice - then the defrost heater isn't getting powered (bad timer or defrost terminator - or is getting powered but has burned out.
You should allow the ice and frost to melt completely before turning back on again. Typically ice and frost don't build up so bad in a few days time to cause the temperature rise you're describing If getting cold - the compressor and refrigerant is likely OK, if not the defrost circuit is suspect. If compressor running but not getting cold - a refrigerant leak / charge level may be causing the problem.
May 18, 2015 | Arctic Air 22 cu. ft. Commercial Freezer...
Maytag freezer keeps thawing food
I am no pro on these but it sounds like your defrost heating coils are coming on to often. You may want to check them. Aslo just for good measure>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 20, 2010 | Freezers
Kenmore chest freezer - why is there a 1/2 inch of ice in bottom
Hello. If your freezer is not a self defroster, you must have had a power failure for a few hours that caused a melt with water ending up on the floor of the freezer and then refreezing. IF you have a self-defrost model, your defrost cycle produces some water which should make it's way down to the evaporator tray just above the floor... in your case, the small hole in the floor is plugged and the water is accumulating on the floor rather than making it's way to the evaporator tray. The fix is to clean the evaporator tray, defrost the ice with a blow dryer, locate the hole and clean it out with a couple of pipe cleaners or cotton swabs. Regards, Joe
PS please rate my answer. thank you.
Jan 28, 2010 | Freezers
BEKO Frost free freezer not as cold as it should be!
Sorry I don't have a solution for you, however would like to know if you found out what was wrong. I have an identical problem with my Beko fridge/freezer. It's only 14 months old and the freezer just wont freeze. I've turn it off for 24 hour and let it defrost completely (even had the panel off to make sure there was no ice left). I've turned it back on again and it still wont freeze. Everything seems ok, ie fan blowing, motor running etc. I really am beginning to regret buying Beko. thanks
Apr 12, 2009 | Freezers
Ice forming on pipes in back of freezer
you could have a freon leak allowing the pipes to freeze up
Dec 31, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezes for 7 to 14 days then just quits!
hate to tell you but your compressor is going out on your freezer ,,, i'd look for another freezer.
Larry
Oct 28, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Kenmore freezer peeing on my floor
  • if the door was not closed correctly for a while then a lot of condensation will be accumulated on the freezer coils.
  • then when going into defrost it melts this ice/frost and overflows the pan or container under the machine which relies on evaporation to dispel  of the water.
  • empty the pan under the refrigerator if you can, then give it another day, it will get back to normal.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 12, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezer freezing up
If its a frost free upright freezer and the evaporator is frosting up with a snow like frost you have a defrost problem.. defrost themostate, heaters, or timmmer
Sep 16, 2007 | Freezers
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424 Logo
139 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
