Question about Gateway 700 XL PC Desktop
My gateway 700 xl doesnt boot
When i tried to boot my computer it didnt boot up. I noticed that the green light on the on button was yellow. I tested my power supply and it seem to be bad. I purchased the correct power supply from gateway. As soon as I installed it it booted up right away. However it computer functioned for only 3 days. When I tried to boot he compueter today the powr button was yellow again as opposed to green. I can hear the fan to the processor working and the hard drive but the system wont boot. I cant believe that the power supply would fail after only 3 d ays.
  • Anonymous Dec 15, 2008
    yellow light, processor fan is running, but no boot up. removed all RAM and tried to power up; nothing including no beeps.
    Problem Solver:
  • 8 Answers
Unplug the power from you 700xl and from you monitor. Try removing the cmos battery and reinstalling it. Then, plug everything back in and try restarting. If it continues to give you the yellow light, you may need to replace the CMOS battery, especially if it is more than two years old.
Another thing to consider is if your power supply is underpowered for the number of external devices you have plugged into it (i.e., cd, dvd, external hard drives, printers, pci cards, etc). Gateway installed very low powered power supplies in their 700xl desktop computers. Usually only around 250 watts maximum.
If you are replacing the power supply with another 250 watt maximum power supply, and you have a lot of external devices plugged in, you may need at least a 350 watt power supply....if your CMOS battery is not the problem.
Posted on Jan 27, 2013
  • Scottie Jan 27, 2013
  • 3,940 Answers
If replacing the power supply resolve for a couple days, there could be a fault in the motherboard or another device connected to the power supply causing the power supply to fail or go off line.
If disconnecting power from all devices except motherboard shows no change, then remove all cards from MB and see if any change. If still no change, replace the motherboard
Posted on Nov 06, 2008
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
It seems you have a motherboard problem which is very common with gateway/emachine and the power supply issue. I hope your pc is under warrenty if not don't spend any more on that machine. Time to look for another or get a new motherboard.
I could not turn on my computer, it did not any light in front,but when I pulled out the hard drive, I saw a light in the back. I pushed in all the cords in the back. Then I was pushing the turn on button...
i think you should replace the power supply or try another different just in case to be sure that theres nothing wrong...some times the computer doesnt come because of change in cmos configuration, clear cmos could help..if you dont have any experience doing it dont do it..and ask in fixya .com
a i forgot you cant test unpluging all the drives just letting pluged the mother board cables and run a test...if it comes on b
Jun 06, 2011 | Gateway 700 XL (700XLDFM) PC Desktop
Why won't my gateway 700 s boot from cd
You need to open your from its BIOS page. The way you can do this is to restart it and once it starts up press the delete button repeatly until your BIOS page comes up.. From here you have to change what your comptuer boots from. Change it to boot from CD DVD rom first then the harddrive. once you have this done save and quit the bios and pop in your cd.
Jun 11, 2010 | Gateway 700 XL PC Desktop
Power light flashs off and on and pc clicks
Most newer models of Dell computers now have a diagnostic LED surrounding the power button on the from of the computer. When you press the power button to boot the PC, the light should be green and remain green under normal circumstances. Any other lights will help you troubleshoot the power issue you are having.
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data. This could mean there is a problem with the CPu or another component on the motherboard.
A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly. This generally means the power supply itself is bad and should be tested or replaced.
A blinking green light means the computer is in standby mode.
So use the LED power light codes if your Dell computer has them. Also pay attention to any unusual beeps or sounds coming from the computer. Well, I was sure that the voltage selection switch was in the right place. And I found it highly unlikely that the processor power cable would suddenly unseat itself. Ugh.
Then I had an idea. I flipped off the surge protector and then flipped it back on. Tada! No more orange lights. Weird. The moral of the story: try the simple stuff first.
I hope this helps and please dont forget to rate my answer. Thank you! :D
Apr 28, 2010 | Dell OptiPlex SX280 PC Desktop
Gateway yellow power button, nothing starts, no fan, nothing. opened up computer and see mobo led light is lit. newton ps has a test button. tried to test with various components plugged in and the test...
Power supply has several voltages. Just because the 5v power is active doesn't mean all the voltages are OK. You need to have the power supply tested for 12v and 3.3v. A quick test is to unplug all the wires from the power supply. There is a single green wire on the motherboard main plug. Connect (use a bent paper clip) that green switch wire and any black wire. Plug in the power supply and it should run (fan starts)
Oct 26, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
503GR Gateway
i would say try swapping your motherboard for another one to test and see if your motherboard is bad if that doesnt work take it to a computer repair store
Oct 17, 2009 | Gateway 503GR PC Desktop
Gateway 500xl pc will not turn on power button is lit up yellow
A LOT of Gateway computers will go into this catatonic state because of a dead battery. The battery is on the motherboard -- it looks like a metal disk about 1" in diamter. Check it or replace it. This applies to laptops too (not the actual laptop battery, the CMOS battery -- a laptop will have one on the motherboard too)
Hope this helps
Mar 13, 2009 | Gateway 500XL PC Desktop
Maybe a bad HD. western digital 80gig, about 7 yrs old
Probably this disk is bad, but try using another testing tool to be sure before replace it.
Jan 22, 2009 | Gateway 700 XL (700XLDFM) PC Desktop
Gateway GT1040 will not start
Try shorting the power pins on the Motherborad. (establish contact manual. use screw drivers such that they touch both the pins). The power pins are the one the Start button are connected to. Remove this connection alone. If this powers up the system, you would have to get the Button replaced. Else there's something wrong with the motherboard. Kindly get back for any clarifcation.
Jan 09, 2009 | Computers & Internet
Gateway 700XL, yellow light only when power is pushed on.
You are on the right track. First, swap out the power supply. That normally is the issue. If that's not the issue, verify that the power switch indeed is working. You can do that by determining which color wires are for the power switch, then hold a multimeter set to resistance on the ends of those two wires. When the button is pressed, it should go to zero. If not, then the switch is fautly. That is an unlikely scenario, however. If the new power supply fails to work and the switch is okay then the problem is the motherboard.
Thanks and please take a moment to rate as fixya.
Dec 12, 2008 | Gateway 700 XL (700XLDFM) PC Desktop
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Gateway 700 XL PC Desktop Logo
572 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
