Question about LG (451158) Consumer Headset
Can't Hear I just bought a brand new headset for the LG phone and at first everythng was fine but a couple days later, i cannot hear anything at all! I can still talk into it and the other person will hear me on the other line but i can't hear them speak... please help!
4 Suggested Answers
SOURCE: Can't Pair With Phone
I had the same thing happen twice just recently and had to call my network and have them walk through some steps over the phone with me. They had to have me enter some numbers they gave me while talking to them and it came on. Be sure to call from a different phone than the one you are having the problem with. I also had it happen again a few weeks ago and I just removed the battery from my cell after disconnecting the bluetooth and then when I put it back together and reconnected the bluetooth it worked fine. I have had it for over a year and never had any trouble with it until this.
Posted on Jan 20, 2008
  • 6 Answers
SOURCE: LG HBM Bluetooth
headset cannnot pair too two phone at the same time
Posted on Jun 21, 2008
SOURCE: I can set up my headset to my new phone
Posted on Mar 01, 2009
  • 8 Answers
SOURCE: After putting the headset into pairing mode, my
According to a VzWireless Tech, take the battery out for 30 seconds and then put it back in. The phone should reset itself to pair the bluetooth headset with the phone. If that does't work remove the device from the phone and start from step 1. I removed the device from the phone then I took the battery out for 30 seconds. Then I paired the bluetooth and followed the next steps to complete the sync.
Posted on Jun 10, 2009
0 characters
1 Points
LG Headset can pair with PC and I can hear but the mic is not working
I have this sale problem. I am using a rocketfish micro dongle to connect my LG tone to my PC and I can hear fine. However, when I set the bluetooth mic to default, I only hear these random blips and pings and it shows nothing received in the audio bar.
Feb 04, 2013 | LG hbs-730 Tone Stereo Bluetooth Headset
I have tried all configurations settings with my new Plantronics S11 headset, and with some I can hear on the headset, but the caller can't hear me. With others the caller can hear me, but I can't...
You need to remember a couple of things when using amplifiers and headsets. Normally they will not work if you connect them to a phone with cordless accessories. Also, you need to make sure that you're connecting the amplifier to the HANDSET jack on the phone (this requires removing the handset off of the phone to access an open line). Give that a try and you should be fine. If not, contact your retailer or Plantronics at 800-544-4660 x5538 for warranty service.
Good luck from Headsets Direct!
Jul 02, 2011 | Plantronics S11 Consumer Headset
I have a brand new Motorola H710 Bluetooth headset. My previous headset was also this model so I know how they work. I paired it with my Razr and I can hear people talking but they can't hear me. Is...
Hello Steve. This is a common problem with the H710, with no available explanation. I recommend that you take the bluetooth and your phone into the phone store where you bought the bluetooth and have the technician there check it out. Joe
Thanks for choosing FIxya!
Nov 18, 2010 | Motorola Mobility H710 Bluetooth Headset
Cant hear music through my LG HBS-200 Bluetooth Stereo Headset
I have the same problem with my HBS-250. It was working fine on my iPod Touch. It worked the first couple of weeks on my iPhone 4 then stopped playing music. Phone funtion works. No music or podcasts or streaming from the web
Sep 12, 2009 | LG SGBS0001606 Bluetooth HBS-200 Stereo...
I cant hear anyone on ps3
call logitech  3464543200 tell them the problem then he will help u when he ask to go to settings then he will ask u to test it then say it doesnt work then he  will ask for ur billing information such as adress phone number and zip code then he will send u a new one for free in 7 to ten days
my problem was that i could hear people but they couldnt hear me
Feb 18, 2009 | Logitech 250 Headset
No one can hear me when I call out or have a call come in but, I can hear them. This just started a couple of days ago. I've had this bluetooth for several months now
I had the same problem, and my solution was a new phone and/or new bluetooth headset...It was very odd how it started later though...incompatibility.
Jun 25, 2008 | Plantronics - Bluetooth Headset Plus Base...
Ring Tone Won't Stop
I had this problem with my old phone, it was a Samsung Sch-950 I recently upgraded my phone and new phone doesn't do it so I don't have an answer other than to get a new phone.
Oct 26, 2007 | Motorola Mobility H350 Wireless Headset
I cant hear anything out of my headset
Is the headset paired and connected to your phone? Is bluetooth turned on in your phone? Look for the bluetooth icon on top of your phone's screen. Let me know what model phone you have and I can help you troubleshoot.
Sep 03, 2007 | Motorola Mobility H700 Wireless Headset
Cannot hear anything out of the earpiece of my GN netcom 9120 wireless headset
I was also experiencing the same problem (also after a power failure / storm) -- apparently good battery charge, connections ok, etc. I then tried removing the battery from the headset itself, waited 30 seconds, and then reinstalled the battery. This seems to have resolved the problem.
It is fairly easy to open the clamshell, but you will need a very fine Phillips screwdriver to remove the battery hold-in (it's really not a hold-down, it just keeps the battery in place. Reassemble the same way -- be sure to keep positive to positive and negative to negative.
Sep 01, 2007 | GN Netcom (9120-48) Wireless Headset
The microphone
My only suggestion is go back to place where you bought it and exchange for a new one. Most place have a 30 day return policy. I would try that.
Jul 25, 2007 | Motorola Mobility H700 Wireless Headset
LG (451158) Consumer Headset Logo
Top LG Headsets Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
sonic boom...
sonic boom...
Sudeep Chatterjee
Sudeep Chatterjee
Are you a LG Headset Expert? Answer questions, earn points and help others
