Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
Very slow, or no connection to internet, on wired computer, not wireless one
Have run this router for a year with no problems, suddenly internet connection is lost daily, regained after shutdown, and reboot of both computers, and router, and speedstream 4100 modem.
currently cannot connect to internet with router connected. Loose all Yahoo access . Passwords, homepage, etc.
At&t advises to "re-configure router"......have no idea on how to do these steps. Any help would be appreciated.
  • 52 Answers
Yes, it would be best to reconfigure it. Try the following but note.. resetting the router will erase all previously given settings.
First, reset the router - when the unit is on, press the reset button (using a paper clip) for 20 seconds then let go of the button. Once the WLAN light is solid, it means that router has rebooted.
Go to a computer wired to the router and open Internet Explorer, enter http://192.168.0.1 on the address bar. Enter admin for the username and leave the password blank.
Once you're in the Dlink page, this is where you can configure your Internet and Wireless settings again. Just run through the setup process (as if you just got the device out it's box).
Posted on Nov 06, 2008
Laptops stopped connecting wireless
how about to reset your router and setup it the proper address by your internet provider..
laptops only connect to the router automatically if you enable it reconnect and detect its network without manually connect internet, this procedure can see in your wireless properties by enabling it.
And also ask your internet provider if theres a problem also with their internet connection.
Jul 18, 2009 | Linksys WRT160N Wireless Router
Tip
Solution on a slow Internet connections Problem  The major  causes for a slow...
The major  causes for a slow Internet connections. A poor-performing connection can be caused by broadband router configuration issues, wireless interference, or any of several other technical issues with your home network. Follow these steps to diagnose slow Internet connections.
 1. Broadband Router Settings
As the centerpiece of a network, a broadband router can be responsible for slow Internet connections if configured improperly. For example, the MTU setting of your router will lead to performance issues if set too high or too low. Ensure your router's settings are all consistent with the manufacturer's and your Internet Service Provider (ISP) recommendations. Carefully record any changes you make to your router's configuration so that you can undo them later if necessary.
 2. Wireless Signal Interference
Wi-Fi and other types of wireless connections may perform poorly due to signal interference, which requires computers to continually resend messages to overcome signal issues. Household appliances and even your neighbors' wireless networks can interfere with your computers. To avoid slow Internet connections due to signal interference, reposition your router for better performance and change your Wi-Fi channel number.
 3. Internet Worms
An Internet worm is a malicious software program that spreads through computer networks. If any of your computers are infected by an Internet worm, they may begin spontaneously generating network traffic without your knowledge, causing your Internet connection to appear slow. Run antivirus software regularly to diagnose and remove these worms from your computers.
 4. Running Background Applications
Some software applications you install on a computer run in the background, quietly consuming network resources. Unlike worms, these are programs designed to do useful work. Peer to peer (P2P) programs in particular can heavily utilize your network and cause connections to appear slow. It's easy to forget these applications are running. Always check computers for any programs running in the background when troubleshooting a slow network.
 5. Faulty Network Equipment
When routers, modems or cables fail, they typically won't support connections. Certain technical glitches in network equipment, however, adversely affect performance even though connections are maintained. To troubleshoot potentially faulty equipment, temporarily re-arrange and re-configure your gear while experimenting with different configurations. Try bypassing the router, swapping cables and changing network adapters to isolate the slow performance to a specific component of the system.
 6. Service Provider Issues
Internet speed ultimately depends on the service provider. Your ISP may change their network's configuration, or suffer technical difficulties, that inadvertently cause your Internet connection to run slow. ISPs may also intentionally install filters or controls on the network that can lower your performance. Don't hesitate to contact your service provider if you suspect they are responsible for a slow Internet connection.
 www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
Wireless computers work fine, wired desktop extremely slow
On your old desktop, go to Control Panel > Internet Options > Connections > LAN Settings make sure no check on boxes there. Click OK and Apply. Click on General tab, click on Delete File (delete all offline content), Clear History and Delete Cookies. Click Apply and OK.
Jun 29, 2009 | Linksys Wireless-G WRT54G Router
Internet Connection Problem on One Computer
By any chance, are you trying to use something other than Windows to manage the wireless adapter? If you are, remove it.
Now, Click on Start, right click on Network highlight properties, and click on manage network connections on the Tasks menu.
Your two options will be the icons for your LAN and Wireless Network. Is it enabled and without red or yellow marks? It could be disable, it could be not connected and you can't view wireless networks because the switch is off, or it may just nut see your unsecure network (unlikely).
If the above is clear, right click on the wireless and highlight Properties and left click so it brings up the Networking tab. Highlight IPv4 and click on Properties. Make sure the Obtain dots are ticked. That should work, since you are running unsecured.
If it already is, check the red X or if it isn't click OK and close down the box.
Now, back to where your Wireless card is showing, right click it and you have Disable, Connect/Disconnect, Status, Diagnose etc.
If you're still Disconnected but not Disabled, click on Connect/Disconnect. Does it show your wireless network?
By this time, it should. If it doesn't post back. The other possibility is that you take your computer to a wireless internet cafe, McDonalds, Panera Bread, or motel with WiFi and test it there.
Carl
Jun 21, 2009 | Linksys Wireless-G Broadband Router
My internet is unusually slow, and unresponsive.
well it sounds like you need either to reset your wireless router(little blue utton on the back of the router) or you need to clear your safari history/cashe.
good luck
ryan
Mar 18, 2009 | Apple MacBook Mac Notebook
My Belkin F5D8053 is working in low strength
If you're encountering a very internet connection on your router, this is can be a problem with either the internet connection from your modem or the firmware of the router should be updated, first thing that you can try is to update the firmware of the firmware of the router, you can download the latest firmware of it from Belkin web site then after that observe the connection if you still have a slow internet using the router , Try to check now the internet from your modem by connecting a computer directly to your modem and if you still have the same problem internet connection from your ISP is the problem so you can contact them about that..........
Nov 11, 2008 | Belkin Wireless-N Wireless Router with...
Slow connection
Your slow connection could be affected by poor location wireless router (therefore poor signal strength), electrical interference, or even someone else with a wireless router transmitting on the same channel as your wireless router.
Try relocating your router away from solid walls, and/or move your computer or router to another location.
If your connection speed varies, could be electrical interference with appliance/s in your house, turn off all appliances, test your internet speed connecting then turn on one appliance at a time to determine which appliance is at fault (could have a faulty capacitor in the appliance)
Jul 24, 2008 | NetGear MR814 Wireless Router
Internet runs slow or freezes on my wired desktop when I use the internet on my wireless laptop.
Hi tech_newbie.... Need a little more info... how is your wireless connected.. ethernet /Usb... or true wireless... and vice versa for desktop. where is your wireless router situated... what times are you experiencing the slow connection!
In addition.. first try running a good Spyware/ adaware programme such as Spybot.. and alongside side another programme called... a-square.. and with AVG.. all of which are free... see links below..
http://www.safer-networking.org/en/download/index.html
http://free.grisoft.com/doc/2/
http://www.emsisoft.com/en/software/free/
Try this first.. they are all pretty good programmes when used in conjunction with each other, you;ll be surorised at what you find.... Get back to me if this does not eliminate your problem
Regards Faggly
Mar 19, 2008 | Computers & Internet
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
242 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
