Question about Samsung 7.3 Cu. Ft. Electric Dryer
Samsung dv4006 dryer belt
Want to know how the belt goes around the tensioner pulley. I am on my third belt.First belt on dryer lasted 2 years but have replaced 2 belts in 4 months and they are not cheap . please help
  • 14 more comments
  • Anonymous Dec 02, 2008
    I have the same Problem!! I am on my second belt in 2 months and I was told that a dryer can not break the belt, the only way that it could be breaking them is if the pullies are off line and it's causing it to snap... So I think that it was a big mistake buying Samsung and I think that I'll be buying a different brand next time!!
  • Anonymous Dec 21, 2008
    You are right, I think this brand is a pile of ****. I have just blown through my second belt, the first lasted 3 years, the second 4 weeks. They are stupidly expensive here in Vancouver (like $50+). I am mechanically pretty sharp (I have rebuild Porsche engines in my shop) but this just looks like its a bad design. The surface area of the drive surface on the electric motor is very large, and is prone to burning the belt.
    I am not sure what my next steps are other then get another belt and try again. I tried a name brand belt last time, this time I will go for cheapest as possible and more than one.
  • Anonymous Jan 25, 2009
    Same problem guys... My fourth belt just went about 30 minutes ago. Apparently Samsung knows about the problem and isn't doing anything about it. The original belt had a steel bead. The replacement belts have a fiberglass bead.
    If you're in the Vancouver area and buy the belt from Reliable Parts they have a 90 day warranty. I paid for the first belt the other three have been free of charge.
    1st belt: 4+years
    2nd belt: 13 days
    3rd belt 3 days
    4th belt: 63 days (Used belt dressing. Increased friction between belt and drive pulley)
    Good luck to all... I'm now down to 13 minutes to replace the belt. Practice makes perfect!
  • Anonymous Feb 01, 2009
    I see the comment about "Samsung knows about this". Can we get more info about it? I am going to machine a new pulley for the motor, the crappy design needs to be fixed or I will just throw this pile of garbage away. At $50 a belt, I am tired of fixing this.
    I would like like to launch a complaint to Samsung if i had a contact.
    Cheers,
    Mike
  • mm512455 Mar 07, 2009
    Same problem here... replacement belt was $42 in Toronto at various stores.
    The design of the dryer is poor -- it's too easy for the belt to move side-to-side on the drum.  Also it is quite a hassle to change the belt as it requires the removal of many screws.
    Not to mention, samsung will not give out service manuals to the general public.  So a belt snapping could end up costing almost as much as 75% of a new dryer.
  • ericb666 Mar 30, 2009
    Hi
    I just bought the same dryer with the belt broken. Now I'm trying to replace the part... Removed the top and the little door on the back. Do I have to remove the front too so I can hang the ******** the drum ? Does someone have a step by step guide to do this ?
    Thank you very much
  • Anonymous Mar 30, 2009
    Does anyone know where to buy a original belt?
    I'm looking for the part MEGADYNE PIII 1975 H7.
    I live in Vancouver, BC CANADA.
    I blew 5 replacement belts ($50 each) and really tired of changing monthly or bi-monthly.
    It seems like I really need the belt with a steel bead.
  • suckysamsung Apr 02, 2009
    This dryer sucks! We have the same problem with the belt and are now wondering if we should buy a new dryer. Sounds like we'll be needing $50.00 belts a few times a year. We've already replaced 4 in 3 years.
  • btefitch Apr 09, 2009
    Same model, same issue... only mine has just gone for the first time.
    I'm not feeling confident about my fix. Anyone who has experience (like the individual who has the fix down to 13 minutes), can you advise on how to best disassemble for the easiest replacement of the belt? I presume from the front, but a quick step-by-step would be sincerely appreciated.
    What a bother.
  • mdnagel Apr 12, 2009
    Has anyone found a replacement steel belted belt?
  • mdnagel Apr 13, 2009
    Just some additional information... The replacement belt that broke after only a few months had a significant deformation in it that suggested that it was formed by sitting on the motor pulley for an extended period of time (dryer doesn't get used a lot). I suspect that this might add to some initial startup friction and that might be a reason for the belts to snap. The guy at the parts store suggested that the problem might be caused by the pulleys having residual debris on them; I didn't recall that being the case, and felt that that was just an attempt to encourage me to buy another belt. After one replacement, and after reading all of the problems listed here, I am opting to sh$t-can this thing and go with something else: this is clearly a bad enginerring design (something I initially thought when I first looked at it when replacing the belt the first time).
    BTW - It's a DV4015J (which, I believe, is the same product group)
  • eric_aimee
    eric_aimee Jul 31, 2012
    I have had the dryer for 3 years and have gone through 3 belts.
  • gwash253
    gwash253 Oct 11, 2012
    Do you know brand of belt you or the appliance repair toronto guy is using? Could it just be the brand?
  • gwash253
  • george rich
    george rich Apr 06, 2014
    For DV4006 dryer, the belt you can buy can be anything labelled 1975 H7 for any machine. 1975 is the width and circumference, while H7 means 7 horizonal groves. You now have a wider variety of belts you can buy on ebay. I bought one made for the Zanussi dryers made in the UK for about $20. While too soon to tell seems to be an exact fit and is working. Putting the belt onto the pulley and motor is challenging. Wrap the metal drum (where clothes go in) with the belt with groves face down. From bottom of the metal drum make it go around the white spinning wheel bottom left to top to bottom right then pull the pull to the left to stretch the spring, and wrap it around the metal part groves that comes out of the motor (top left first, then bottom then top right), then belt will continue going up to the metal drum. My suggestion is NEVER dirty up the inside of the metal drum with tools or screws or you will ruin your clothes. You only need to remove the front panel of the machine, including the electronic circuitboard and the inside plastic shroud that goes over the motor exhaust. You dont need to remove the metal drum (no need). And dont be surprised if you only see 1 pulley instead of 2 pullies on this machine - this samsung design sucks and the belts keep needing to be replaced because of this crappy design. Samsung shaves off a fraction of a dollar of cost while you keep needing to replace the belt once a year.
  • george rich
    My other suggestion is to take detailed notes as to which type of screw goes where. They got 3-4 different types of screws some very similar looking but not the same.
  • 41 Answers
Possible replacement belt quality problem for the Samsung DV4006 / DV4006J / DV4015J / DV665JW and the Maytag MDE2400AZW dryers:
The original belt for the Samsung DV4006 / DV4006J / DV4015J / DV665JW dryers is a Megadyne 1975 H7. The part number is DC66-00121A, but when ordered, a Dongil 7PH1975 belt may be shipped instead of the original Megadyne. The Maytag MDE2400AZW dryer uses the same belt. The part number is 35001010, but when ordered, a Dongil 7PH1975 belt may be shipped. It seems that the Dongil belts are inadequate for these dryers. They delaminate and may fail prematurely. Even new, they cause a thumping sound each time the seam goes over the motor pulley. Other than Megadyne, another good belt is the Hutchinson 1975H7. The appliance part number is 1258288107.
Where to get an original Megadyne 1975 H7 belt:
eBay member 'appliance-parts' in Colorado, USA has emailed me that their Samsung DC66-00121A belts are Megadyne. Website: http://appliancefactory.com Email address: partsonline@appliancefactory.com
eBay member 'ladydi1975' in Ohio, USA has emailed me that their Maytag 35001010 belts are Megadyne. eBay store: Discount Appliance Parts.
Where to get a Hutchinson 1975H7 belt:
eBay member: 'zodiac300_0' in Brighton, United Kingdom. I have ordered a 1975H7 belt from them and received a Hutchinson.
Other possible causes for belt failure:
--Motor pulley designed too small. The belt may be flexed beyond it's minimum rated radius.
--Excessive heat in the dryer due to lint in the vent line or vent line too long. The Dongil belt may be less heat resistant than the Megadyne.
--Worn drum bushing DC66-00062A.
--Metal burrs on the steel motor pulley. Deburr by inserting a small screwdriver in each groove while the motor is turning without the belt.
--Belt on the wrong track. The motor pulley has nine grooves and the belt has seven ribs. The belt must be in the middle. It's easy to place it one groove forward or backward by error.
--Small scratches on the drum where the belt contacts it. The scratches may be like small knives and damage the belt. Sand with a fine sandpaper.
--Idler pulley damaged or bearing worn.
How to replace the belt:
--Remove top cover.
--Remove vent panel (in back).
--Unclip door switch from front panel.
--Disconnect wire harness from door switch.
--Unscrew panel left of control console (from behind the panel).
--Unclip panel left of control console (from behind the panel).
--Unscrew control console.
--Unclip plastic panel on bottom, front
--Remove screws behind door. Remove door.
--Unscrew large front panel, remove.
--Inspect vent line for lint buildup, drum bushing (back of dryer) for wear, motor pulley for burrs and debris, drum for scratches, and idler pulley/bearing for damage.
--Vacuum all lint.
--Install belt around drum, idler pulley, and motor pulley. The ribbed side of the belt contacts the drum. The flat side of the belt contacts the idler pulley. Press on idler pulley to stretch the spring, and line up the seven belt ribs in the center of the nine motor pulley grooves.
--Reassemble.
Posted on Jul 01, 2009
  • 2 more comments
  • dumb-stump Aug 06, 2011
    My DV419AGW/XAA is generally the same, but a little different.
    To Replace my belt:
    -Remove Top Cover - two screws at the top of the back. Slide Cover straight back a few inches, then lift off.
    -Unclip Control Panel assembly (I left my wires attached and then just laid it on top out of the way.
    -Remove 4 screws holding down the plastic shiny piece, which also hods the from cover of dryer. (plastic piece does not come off, but you need to remove the screws)
    -Open Dryer door. Remove the two lowest screws on the door circle (they are not visible when door is closed). No need to remove the door.
    -Lift front dryer cover, with door, up and out - only a little because the dryer door switch is still attached.
    -Unplug dryer door switch (my need pliers to get a decent grip on it) and then set the from cover assembly asside.
    -facing the dryer, there are 4 screws that hold the the front assmbly on (this is the assembly that the drum lines up with and rides on. once the 4 screws are out you can lift it up and pull it back a little out of the securing guides. I didn't remove this, only pulled it back enough to be able to push the dryer drun up and down a little.
    -There is a felt gasket / seal that the drum rides on / in. by pulling the front assembly back a little (see previous step), I found that there was enough room for me to squeeze the new belt between the drum and this assembly to get it around the drum. It took a little pushing of the belt thru the opening, but I though it was easier than taking the whole thing off.
    -As you get the new belt in and around the drum, there are tow pulleys at the bottom that sit towards the from of the drum. The belt needs to go behind these pulleys, so I had to lift on the drum and slip the belt behind these pulleys.
    -These previous two steps are the most difficult, but really not too bad.
    -Make sure the belt is around the drum, and that it hangs approximately where the old belt was (there was an obvious mark on my drum from my old belt).
    -At this point, the belt is still loose, but you can reassemble the front.
    -Finally - Remove rear vent panel (3 screws at bottom, pull straight back) - this is where you will put the belt thru the tensioner and drive pulley after it is on the drum....last step)
    -The belt goes around the tensioner pulley and drive gear a certain way so that the belt is tight. Make sure the spring is on as you lift the tensioner pulley. Hard to explain the belt route thru the pulleys, so do a search and find a picture, it didn't take me long to locate it.
    -Also, make sure you have the grooved part of the belt facing towards the inside of the drum and that the grooves ride in the grooves on the drive gear.
    Good luck.
  • josiepk Feb 03, 2013
    Your description is spot on. Although yours is a bit different the directions were perfect with one small omission. There is an aluminum cover that the lint tray goes into that makes the process easier if removed. It is oblong in shape under the drum in the front held in place by 4 screws. Removing it allows for more play in the drum assembly to squeeze the belt behind the drum.
  • Graham Feb 09, 2013
    The Dongil belt is garbage! I went to a Industrial supply shop in the near by City of Whitby, Ontario. I order the same size belt, with same specs (Made in Germany not China) NO PROBLEMS FOR 2.5 YEARS NOW! The dryer works great! The problem is the replacement belt from Dongil. Save yourself lots of time and money and source out a new belt.
  • Jen Johnson
    Jen Johnson Aug 05, 2014
    Could u tell me the name of that supply store near Whitby Ontario pls? I'm in the same boat.
This dryer is a piece of junk. Just bought a house with one...belt has broken twice now. It's a goner.
Posted on Nov 01, 2009
  • 1 more comment
  • geoalves Dec 30, 2010
    I bought a replacement belt (DC66-00121A) and installed it but after reassembling it I found that the belt is too loose and there is no way of increasing the tension (about 2 - 3 inches too much). There is no play unless I unhook the spring.. ...Help
  • micacidyl
    micacidyl Mar 12, 2013
    Did you find a solution to this? I had the same problem?
  • micacidyl
    I'm having the same problem... did you solve this issue?
    New Friend:
Buy a new dryer belt from a different manufacturer, other that Dongil!
Call around some industrial supply shops. Use the yellow pages and give them the same specs as the Dongil belt. Better yet, take the belt with you and let the experts find a replacement for you.
My new belt was made in Germany, not CHINA and cost $12.00 and has been working fine for 2.5 years.
The Dongil Belt is Garbage, don't use is! I have learned from experience.
Posted on Feb 09, 2013
  • Brian Mar 18, 2013
    Do you still have the contact to the industrial supply shop? and do you know the specs of the Dongil belt?
  • george rich
    george rich Apr 08, 2014
    Any belt with the same dimensions like: 1975 H7 will fit. Doesnt matter if it's for the maytag or for the LG. It's the same size (1975) and same number of horizontal groves (H7). LM Electrical spares on Ebay has this belt and it works fine for the DV4006. Made in UK for $20 after shipping.
Two helpful videos:
1) How to disassemble the dryer
http://www.youtube.com/watch?v=N9rU046503M&feature=related
2) At the end of this video is how to reattach the belt to the pulleyhttp://www.youtube.com/watch?v=obaoSDbzYrM
Posted on Sep 30, 2012
  • Mike Johnson
    Mike Johnson Sep 30, 2012
    Two helpful videos:
    1) How to disassemble the dryerhttp://www.youtube.com/watch?v=N9rU04650...
New drive belt on LG dryer to loose?
belt goes around drum the to the right of the tensioner and then to the motor pulley. you have to move the tensioner to the left to get the belt to the motor pulley. so the belt goes to the top of the tensioner, and around it in a clockwise manner, to the motor, not just under the motor and under the tensioner.
Sep 20, 2016 | LG Dryers
NEED TO PUT THE DRUM BELT BACK ON ASAP
The other pulley is spring loaded it puts tension on the belt.
Pull the pulley back and the belt will slip ight over then release the tension pulley and your done!
Apr 17, 2014 | Haier HLP140E Electric Portable Dryer
Changing the belt
goes around idler pulley and motor. idler pulley fits into slots on bottom of dryer and the belt tension holds it in place. looking at it from the front and going clockwise the belt goes around the drum and then around the motor pulley and thru the idler pulley. in fact if you put the bottom loop of the belt thru the pulley from the left you then loop it around the motor pulley.
Jun 26, 2010 | Estate TEDX640JQ Electric Dryer
Need to replace drum belt
Most dryers have a tensioner pulley that the belt needs to go around to keep it tight. The belt goes around the motor pulley and the drum, but it goes around the tensioner pulley in a way that would keep it tight (you also need to release the tension on the tensioner to get the belt around it) If there's not a tensioner pulley there has to be some other means of putting tension on that belt, look around the the other pulleys that the belt goes around.
May 07, 2010 | Whirlpool 6.5 Cu. Ft. Super Capacity Gas...
The belt broke on my Whirlpool super capacity dryer (23 years old)model number LG7686XPO. we are able to get the belt could you plase send us a diagram of how the belt goes on? and some directions...my...
Your belt will use one of these configurations. Just right click on the picture, copy & paste it into a document or save as and them open it with a photo viewer.
Jun 30, 2009 | Dryers
White belt wheel came off
The bottom of the tension roller goes in 2 slots under the motor pulley.
The wheel will be at your left facing the motor.
Reroute the belt around the drum...through the tension roller then on to the motor pulley.
Mar 12, 2009 | Whirlpool ET8CHEXSQ Dryer
Need a btlt route so i can put the new drum back in my ge profile
route the belt around the drum, pull the spring loaded idler pulley to the postion that requires you to hold it there..
put the belt : 1 through the motor pulley and around the idler pulley, or 2. around the idler pulley which ever works to keep the tensioner tight. (Idler pulley, tensioner same thing its the pulley not on the motor.
Once you put the belt on the durm, pull the idler pull so there is tension on it it should be clear how it goes.
Doc
Feb 08, 2009 | GE Profile Harmony DPGT750EC Electric...
How to route the belt
hi there, I am a dryer repairman of some six years experience.
I used to have this problem also, at the beginning of my work!
Firstly, put the "belt guide" in its correct postion, that is with the 2 metal prongs fitted into the 2 slots on the mounting plate below the motor. If it doesnt stay in place, remove and bend the 2 metal prongs outwards slightly. (belt guide = idler pulley assembly)
Secondly, feed the belt in, through the middle of the metal idler pulley arm, and loop it over the bottom pulley of the motor. Next, pull the belt out to the side, to check that its properly located on the pulley. You can pull the belt to the side with one hand, while feeling with the other, if the belt is neatly on the pulley.
Thirdly, while keeping a little tension always on the belt, slip it over the drum while keeping the idler pulley on the outside (RH side ) of the belt. Now reposition the belt on the idler pulley. While doing this, you are always keeping a little tension on the belt, by pulling out to the side, taking up the slack with left hand. Always keep a little tension on the belt, until spring is in place. Next, you push the belt down into its normal running position on the drum, this can be just approximate for now.
Fourthly, you fit the tensioning spring, between the idler pulley arm, and the hole in the seam of the dryer case. (or if there is a belt-break switch, you put it around that) This is a bit tricky, as you need a strong right hand to stretch the spring. Can use pliers to help, but sometimes makes it harder!
Lastly, after you have done all this and finished, must check that all is firmly in place before closing up the dryer. Rotate the motor pulley by hand, carefully, to see if the belt is running smoothly, not twisted or misaligned. Correct as needed. If there is a loud TWANG, then the idler pulley has come out of its seat, and you begin again from step one, being more careful, checking as you go.
Apr 23, 2008 | Dryers
Replacing maytag dryer belt
looking at the back of the motor where the belt pulley is you would grasp belt coming down from the left side of drum then come across the top of belt pulley that is on motor shaft going clockwise around that pulley then continue back to your left and over the top of belt tension pulley going counterclockwise around that pulley this is when you will have to raise pulley against spring pressure to get belt on then release belt tension pulley make sure that belt is still in belt groove on the drum hope this helps ed
Feb 28, 2008 | Dryers
Samsung 7.3 Cu. Ft. Electric Dryer Logo
12,878 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
