Question about Planar PL1700M (White) 17 in. Flat Panel LCD Monitor
Just bright it turns on ,,no adjustments work ,it has a real bright ,clear screen
0 characters
1 Points
Monitor brightness contrast problem
Turn Off auto-adjustment screen
Jul 29, 2009 | Proview PL19Wb Monitor
Problem with brightness of monitors SyncMaster 710n
HelIo! right after computer inclusions on the monitor screen have a tablet with the message which disturbs to work. The message: brightness of the monitor of 100 %! A problem: how to clean from the screen this tablet so she prevents to read the information. I have not found adjustment in the menu of the monitor brightness. And what should be brightness: 100 % or another? have not found adjustment in the menu of the monitor brightness. And what should be brightness: 100 % or another?Thanks and sorry about my bad english. Afzal.
Sep 06, 2008 | Samsung SyncMaster 710N 17 in. Flat Panel...
Display problem
the adjustment box for colour, brightness and contrast stays fixed on the screen. i tried pressing the exit button.... after a few times it disappears only to reappear within a few minutes. also the auto adjustment option, for which we are supposed to manually press the i button, keeps auto adjusting the screen whenever it feels like it. the box appears right in middle of the screen and is a real nuisance as it blocks out the main portion.
Jun 28, 2008 | BenQ FP547 - 15" LCD Monitor
Too Bright
It could.Check the screen voltage G2,If its high more then 400v this fix could work.
Mar 09, 2008 | Dell P1130 21" CRT Monitor
Dark image
Flyback transformers usually have 2 adjustable rods - 1 is for focus the other is for screen (G2) voltage. try turning Clockwise the Screen adjust with brightness-contrast at max. Till you see white diagonal lines, then go back until the lines disappear - then tune the brightness to your desired level.
Apr 27, 2007 | LG Flatron Ez T710BH 17" CRT Monitor
Monitor Screen Bright with horizontal white lines
I have an emachine 17" Flat Panel Monitor and I accidently touched the Standby Mode on my keyboard and now my menu won't work right. I can't adjust the color enough. If there is anything I can do to fix my problem it would be appreciated.
Oct 08, 2006 | E-Machines 17F2 17" CRT Monitor
Getting More Brightness/Contrast ?
problem with my monitor Viewsonic E70....Memory recall keep flashing......any help out there.....
Mar 15, 2006 | HP 90 19 in.CRT Conventional Monitor
Ultrascan P1110 to Bright....
hi sounds like you have weak picture tubes do not open the screen ***DANGER OF ELECTROCUTION AND DEATH*** try taking to some1 who knows how 2 fix it good luck
Feb 22, 2006 | Dell UltraScan P1110 21" CRT Monitor
Planar PL1700M (White) 17 in. Flat Panel LCD Monitor Logo
21 people viewed this question
Top Planar Computer Monitors Experts
Clive Gray
William Miller
William Miller
Joe Goldman
Joe Goldman
Are you a Planar Computer Monitor Expert? Answer questions, earn points and help others
